Probleme Minecraft crash report
J'ai un gros probléme je n'arrive pas a jouer a minecraft alors que tous mes drivers sont a jour et que java est installe correctement quand je lance mon launcher et que j'appuie sur play sa me ferme le launcher , plus rien et ensuite sa me mets le crash report suivant :
---- Minecraft Crash Report ----
// Oh - I know what I did wrong!
Time: 04/05/14 19:42
Description: Initializing game
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:244)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at azd.Z(SourceFile:367)
at azd.e(SourceFile:689)
at net.minecraft.client.main.Main.main(SourceFile:103)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.7.2
Operating System: Windows 7 (amd64) version 6.1
Java Version: 1.7.0_55, Oracle Corporation
Java VM Version: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
Memory: 83875496 bytes (79 MB) / 120061952 bytes (114 MB) up to 477102080 bytes (455 MB)
JVM Flags: 3 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx1G -Xmx512M
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: 1.7.2
LWJGL: 2.9.0
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Resource Packs: []
Current Language: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null
Anisotropic Filtering: Off (1)
Svp aidez moi je ne sais plus quoi faire après de nombreuse tentative
PS: J'ai un pc acer Windows 7 ultimate et une carte graphyque nvidia aussi un pc sous core i5 voila
j'aimerai beaucoup que quelqun maide svp
Le problème porte sur un échec au démarrage de Minecraft, affichant une erreur LWJGL 'Pixel format not accelerated' et 'No OpenGL context found' sous Windows 7 avec une carte Nvidia et Java installé. Des solutions évoquées incluent l’utilisation du launcher officiel, la réduction de la distance de vue et, pour certains, l’ajout d’une variable _JAVA_OPTIONS afin de limiter l’usage mémoire. D’autres retours évoquent un antivirus perturbant le lancement ou des incohérences entre versions du launcher et du jeu, avec des mises à jour récentes du launcher officiel et des divergences entre versions. En cas de persistance, certains recommandent de vérifier les pilotes graphiques et la configuration OpenGL, car le souci peut provenir de la compatibilité LWJGL et du contexte OpenGL manquant.
  1. Prenez le launcher officiel pour voir si c'est bon
    1. Oui normalement je devrais l'avoir mais avant cela marche sans le launcher officiel
      merci de votre reponse
    2. Normal ils ont mis a jour le launcher officiel y'a 2 ou 3 jours le launcher officiel est 1.4.3 et la version de minecraft est 1.7.9 pour le normal ou 14w18a pour la version experimentale de la 1.8
    3. ben oui mais dans ce cas yaurai pas que moi qui aurait le probleme
    4. Comment ça ?
    5. ben si vous dites que c'est normal car ils ont fait une mise a jour y'aurai pas que moi qui pourai pas joue a minecraft y'aurai tt ce qui ont une version cracké et ce n'est pas le cas.
