Probleme de Crash Minecraft
Voila aufaite , j'ai un nouveau Ordinateur ( Msi avec windows 7 ) et j'installe minecraft et quand je lance Minecraft , j'appuye sur le bouton ''Play'' Sa attend un peut et la je vois sa
---- Minecraft Crash Report ----
// Ouch. That hurt :(
Time: 09/04/14 18:59
Description: Initializing game
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:244)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at atv.O(SourceFile:297)
at atv.d(SourceFile:599)
at net.minecraft.client.main.Main.main(SourceFile:101)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.6.4
Operating System: Windows 7 (x86) version 6.1
Java Version: 1.7.0_51, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode, sharing), Oracle Corporation
Memory: 5853024 bytes (5 MB) / 26808320 bytes (25 MB) up to 518979584 bytes (494 MB)
JVM Flags: 2 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx512M
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: 1.6.4
LWJGL: 2.9.0
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Resource Pack: Default
Current Language: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null
Merci de bien Vouloir m'aider S'il vous plait , merci si vous trouverez la reponse :)
-- Head --
Stacktrace:
Details:
Stacktrace:
Details:
LWJGL: 2.9.0
Contributeur'lut, disposes-tu d'une carte graphiques avec des drivers pour à jour?
Non , je n'en dispose pas , pourrait-tu m'aider s'il te plait ?
ContributeurDans ce cas là il va falloir t'en procurer une, sinon, tu ne pourras pas jouer à Minecraft.
Si tu veux de l'aide dans ton choix, le forum Matériel informatique, particulièrement Carte Graphique est à ta disposition.
Sa s'achette ou on la telecharge ?
