Probleme dans mon code aidez moi !
salut ! le sujet c'est que je dois executer une requete a partir d'une interface !!
error: unreported exception SQLException; must be caught or declared to be thrown
Statement st = con.createStatement();
import java.awt.*;
import javax.swing.*;
import java.awt.event.*;
import java.sql.*;
class gestion extends JFrame implements ActionListener {
public Connection con = null;
public Statement st= null;
public ResultSet rs= null;
JLabel lab = new JLabel("GESTION DE STOCK");
JButton but1 = new JButton("executer");
JPanel panel = new JPanel();
private String requete = "SELECT * FROM classe";
JLabel lab1 = new JLabel("Gestion");
private String requete1 = "SELECT * FROM classe";
JTextArea text = new JTextArea(requete1,8,30);
Box b1 = new Box(BoxLayout.Y_AXIS);
Box b2 = new Box(BoxLayout.Y_AXIS);
Box b3 = new Box(BoxLayout.Y_AXIS);
Box b4 = new Box(BoxLayout.Y_AXIS);
Box b5 = new Box(BoxLayout.Y_AXIS);
public gestion(){
super("gestion de stock");
setSize(400,400);
setVisible(true);
setDefaultCloseOperation(this.EXIT_ON_CLOSE);
panel.setSize(300,300);
b2.add(but1);
b3.add(text);
b4.add(lab);
b4.setSize(10,10);
b1.add(BorderLayout.NORTH,b4);
b1.add(BorderLayout.WEST,b2);
b1.add(BorderLayout.SOUTH,b3);
panel.add(b1);
this.add(panel);
but1.addActionListener(this);
public void actionPerformed(ActionEvent e){
Object src=e.getSource();
if(src instanceof JButton){
JButton var=(JButton) src;
if (var==but1) {
ResultSet rs = st.executeQuery(requete);
while (rs.next()) {
System.out.println("id ="+rs.getInt(1)+",\t");
System.out.println("nom ="+rs.getString(2)+",\t");
System.out.println("prenom ="+rs.getString(3)+",\n");
public void connection(){
try{
Class.forName("sun.jdbc.odbc.JdbcOdbcDriver");
catch(ClassNotFoundException e){
System.out.println("impossible de chargern les drivers");
try{
String url="jdbc:odbc:test";
con=DriverManager.getConnection(url, "","");
catch(SQLException e)
System.out.println("impossible de créer une connexion");
public void fermeture(){
try {
//rs.close();
st.close();
con.close();
catch(SQLException e){}
public static void main(String[] args) {
gestion gest1 = new gestion();
import java.awt.*;
import java.sql.*;
public gestion(){
setSize(400,400);
setVisible(true);
b2.add(but1);
b3.add(text);
b4.add(lab);
b4.setSize(10,10);
panel.add(b1);
this.add(panel);
if (var==but1) {
while (rs.next()) {
try{
try{
try {
//rs.close();
st.close();
con.close();
ContributeurBonjour,
S'il vous plaît
Au revoir
etc.
Sont monnaie courante quand on veut obtenir quelque chose !
Saine lecture...*
A voir aussi
Merci de votre compréhension.
* Bonus
desolé :) mais j'ai vraiment besoin d'aide et merci :)
ModérateurLe message d'erreur est pourtant très explicite !
Statement st = con.createStatement(); est une opération qui peux provoquer une SQLException que tu dois gérer, soit avec un try/catch, soit avec un throws.
try { Statement st = con.createStatement(); ResultSet rs = st.executeQuery(requete); while (rs.next()) { System.out.println("id ="+rs.getInt(1)+",\t"); System.out.println("nom ="+rs.getString(2)+",\t"); System.out.println("prenom ="+rs.getString(3)+",\n"); } } catch (SQLException e1) { e1.printStackTrace(); } -
merci beauoup KX ca marche comme ca :)
