Minecraft ne se lance pas
voici le message qu'il me dit :
Minecraft has crashed!
Minecraft has stopped running because it encountered a problem; Failed to start game
A full error report has been saved to /home/micheline/.minecraft/crash-reports/crash-2012-11-23_17.23.07-client.txt - Please include a copy of that file (Not this screen!) if you report this crash to anyone; without it, they will not be able to help fix the crash :(
--- BEGIN ERROR REPORT a8d31879 --------
Full report at:
Please show that file to Mojang, NOT just this screen!
Generated 23/11/12 17:23
-- System Details --
Details:
Minecraft Version: 1.4.5
Operating System: Linux (i386) version 3.2.0-32-generic-pae
Java Version: 1.6.0_24, Sun Microsystems Inc.
Java VM Version: OpenJDK Server VM (mixed mode), Sun Microsystems Inc.
Memory: 38346608 bytes (36 MB) / 61603840 bytes (58 MB) up to 913440768 bytes (871 MB)
JVM Flags: 0 total;
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
LWJGL: 2.4.2
OpenGL: ~~ERROR~~ NullPointerException: null
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Texture Pack: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: X Error - disp: 0x6db06590 serial: 31 error: BadRequest (invalid request code or no such operation) request_code: 154 minor_code: 14
at org.lwjgl.opengl.LinuxDisplay.globalErrorHandler(LinuxDisplay.java:268)
at org.lwjgl.opengl.LinuxDisplayPeerInfo.initDefaultPeerInfo(Native Method)
at org.lwjgl.opengl.LinuxDisplayPeerInfo.<init>(LinuxDisplayPeerInfo.java:52)
at org.lwjgl.opengl.LinuxDisplay.createPeerInfo(LinuxDisplay.java:684)
at org.lwjgl.opengl.Display.create(Display.java:854)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:232)
at net.minecraft.client.Minecraft.run(SourceFile:515)
at java.lang.Thread.run(Thread.java:679)
--- END ERROR REPORT 118797d4 ----------
est ce que quelqu'un a une solution pour le faire fonctionner?
Full report at:
Details:
JVM Flags: 0 total;
LWJGL: 2.4.2
ModérateurLà c'est un bug dans le programme (null pointer exception) ou dans la jvm. Ici ils suggèrent d'utiliser openjdk, est-ce ce que tu utilises ?
http://forum.ubuntu-fr.org/viewtopic.php?pid=11600581
Bonne chance
