Problème OpenGL minecraft
bonjour,
je sais que ce problème a été posté des milliers de fois mais même en les lisant je n'ai pas encore trouver la réponse a mon probleme. c'est simple j'ai comme beaucoup de monde, en ouvrant minecraft cet erreur :
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 21/11/12 17:57
-- System Details --
Details:
Minecraft Version: 1.4.5
Operating System: Windows 8 (amd64) version 6.2
Java Version: 1.7.0_09, Oracle Corporation
Java VM Version: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
Memory: 417875856 bytes (398 MB) / 514523136 bytes (490 MB) up to 954466304 bytes (910 MB)
JVM Flags: 2 total; -Xms512m -Xmx1024m
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
LWJGL: 2.4.2
OpenGL: ~~ERROR~~ NullPointerException: null
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Texture Pack: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java:311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:232)
at net.minecraft.client.Minecraft.run(SourceFile:515)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT 23d4985 ----------
j'ai bien sur bien fait toutes les mises a jour des mes cartes graphiques et le reste des composant, la mise a jour de JAVA 64-bits et un force update.
je suis sur windows 8 release preview, un mobil intel 965 express chipset family et 2Gb de ram
minecraft marchait avant que je passe sur windows 8 (j'étais sur windows vista qui tournait très mal)
j'espère avoir un réponse qui pourrait donner un bon résultat. :)
merci !
8 réponses
  1. yahoo jai enfin trouver la solution ! dites le moi si vous la voulez !
    1. C est quoi ?
    2. moi je la veux la solution!!!
    3. Réponse la plus inutile au monde, merci en tout cas.
    4. regarder ma remarque en bas dans les commentair, sa vous aidera :)
    5. super dit la nous sauf si tu nous sale noob je trouverai tout seul sinon xdddddddddddddddddddddd
