Minecraft gros probleme ca deviens .....
Bonjour, svp aidé moi je suis calé depuis presque 3 mois mon problème est que quand j'ai reformaté mon Pc j'ai tous remis comme il fallait mais mon minecraft que j'ai payé ne m'ouvre plus pourquoi ? j'ai ça qui s'affiche svp ça me gonfle merci à vous
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x509cef40, pid=4036, tid=6100
# JRE version: 7.0_09-b05
# Java VM: Java HotSpot(TM) Client VM (23.5-b02 mixed mode windows-x86 )
# Problematic frame:
# C 0x509cef40
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x4c142800): JavaThread "Minecraft main thread" daemon [_thread_in_native, id=6100, stack(0x4f5d0000,0x4f620000)]
siginfo: ExceptionCode=0xc0000005, ExceptionInformation=0x00000008 0x509cef40
Registers:
EAX=0xf0da891a, EBX=0x50812940, ECX=0x507c8300, EDX=0x00000004
ESP=0x4f61f33c, EBP=0x507b0328, ESI=0x4ff89800, EDI=0x4f61f38c
EIP=0x509cef40, EFLAGS=0x00010246
Top of Stack: (sp=0x4f61f33c)
0x4f61f33c: 69088ec3 50812940 507b0328 00000000
0x4f61f34c: 4f61f3f4 509cae3c 00000001 00000004
0x4f61f35c: 507b10a8 509c40dc 00000000 ffffffff
0x4f61f36c: 00000001 00000001 00000000 509cef40
0x4f61f37c: 00000000 507b0328 4ff89800 507c8300
0x4f61f38c: f0da891a 000014c3 4ebc8990 4f61f3d0
0x4f61f39c: 4f9320e0 6907578e 4f9a5820 4f61f3c0
0x4f61f3ac: 690936d4 4f61f38c 00000000 00001fa0
Instructions: (pc=0x509cef40)
0x509cef20: ef 62 51 80 89 71 3f 08 00 00 00 00 00 00 00 00
0x509cef30: 00 00 00 00 28 ef 9c 50 05 05 00 00 01 00 00 00
0x509cef40: 55 8b ec 53 56 57 8b d9 8b ca 8b 75 08 81 e1 fc
0x509cef50: ff ff ff 66 66 66 66 66 66 66 90 66 66 66 66 66
Register to memory mapping:
EAX=0xf0da891a is an unknown value
EBX=0x50812940 is an unknown value
ECX=0x507c8300 is an unknown value
EDX=0x00000004 is an unknown value
ESP=0x4f61f33c is pointing into the stack for thread: 0x4c142800
EBP=0x507b0328 is an unknown value
ESI=0x4ff89800 is an unknown value
EDI=0x4f61f38c is pointing into the stack for thread: 0x4c142800
Stack: [0x4f5d0000,0x4f620000], sp=0x4f61f33c, free space=316k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C 0x509cef40
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j org.lwjgl.opengl.GL11.nglClear(IJ)V+0
j org.lwjgl.opengl.GL11.glClear(I)V+15
j org.lwjgl.opengl.Display.initContext()V+16
j org.lwjgl.opengl.Display.create(Lorg/lwjgl/opengl/PixelFormat;Lorg/lwjgl/opengl/Drawable;Lorg/lwjgl/opengl/ContextAttribs;)V+97
j org.lwjgl.opengl.Display.create(Lorg/lwjgl/opengl/PixelFormat;)V+9
j net.minecraft.client.Minecraft.a()V+174
j net.minecraft.client.Minecraft.run()V+6
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
=>0x4c142800 JavaThread "Minecraft main thread" daemon [_thread_in_native, id=6100, stack(0x4f5d0000,0x4f620000)]
0x4c142400 JavaThread "Timer hack thread" daemon [_thread_blocked, id=4520, stack(0x4ebf0000,0x4ec40000)]
0x4c141c00 JavaThread "Snooper Timer" daemon [_thread_blocked, id=2568, stack(0x4ec90000,0x4ece0000)]
0x4c077800 JavaThread "Keep-Alive-Timer" daemon [_thread_blocked, id=1020, stack(0x4da80000,0x4dad0000)]
0x4c073000 JavaThread "Image Fetcher 0" daemon [_thread_blocked, id=3660, stack(0x4e750000,0x4e7a0000)]
0x02b3ac00 JavaThread "DestroyJavaVM" [_thread_blocked, id=2820, stack(0x01f80000,0x01fd0000)]
0x4c044400 JavaThread "D3D Screen Updater" daemon [_thread_blocked, id=5136, stack(0x4e4c0000,0x4e510000)]
0x4bf75400 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=2220, stack(0x4b760000,0x4b7b0000)]
0x4bf17000 JavaThread "TimerQueue" daemon [_thread_blocked, id=5792, stack(0x4b970000,0x4b9c0000)]
0x4bf4a000 JavaThread "SwingWorker-pool-1-thread-1" daemon [_thread_blocked, id=5872, stack(0x4b080000,0x4b0d0000)]
0x4b04f000 JavaThread "AWT-Windows" daemon [_thread_in_native, id=3204, stack(0x4b3f0000,0x4b440000)]
0x4b04e400 JavaThread "AWT-Shutdown" [_thread_blocked, id=2120, stack(0x01ad0000,0x01b20000)]
0x4b04b800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=3200, stack(0x4b350000,0x4b3a0000)]
0x4aedcc00 JavaThread "Service Thread" daemon [_thread_blocked, id=3300, stack(0x4b0e0000,0x4b130000)]
0x4aeda400 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=4780, stack(0x4ade0000,0x4ae30000)]
0x4aed9400 JavaThread "Attach Listener" daemon [_thread_blocked, id=5916, stack(0x4ad80000,0x4add0000)]
0x4aed6000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=4128, stack(0x01f30000,0x01f80000)]
0x02afe800 JavaThread "Finalizer" daemon [_thread_blocked, id=4496, stack(0x4ad20000,0x4ad70000)]
0x02afc000 JavaThread "Reference Handler" daemon [_thread_blocked, id=4312, stack(0x4ae30000,0x4ae80000)]
Other Threads:
0x02af7000 VMThread [stack: 0x4acd0000,0x4ad20000] [id=5968]
0x4aefac00 WatcherThread [stack: 0x4b160000,0x4b1b0000] [id=1112]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 157248K, used 85739K [0x04b40000, 0x0f5e0000, 0x1a090000)
eden space 139776K, 61% used [0x04b40000, 0x09efac40, 0x0d3c0000)
from space 17472K, 0% used [0x0d3c0000, 0x0d3c0000, 0x0e4d0000)
to space 17472K, 0% used [0x0e4d0000, 0x0e4d0000, 0x0f5e0000)
tenured generation total 349568K, used 0K [0x1a090000, 0x2f5f0000, 0x44b40000)
the space 349568K, 0% used [0x1a090000, 0x1a090000, 0x1a090200, 0x2f5f0000)
compacting perm gen total 12800K, used 12759K [0x44b40000, 0x457c0000, 0x48b40000)
the space 12800K, 99% used [0x44b40000, 0x457b5f08, 0x457b6000, 0x457c0000)
No shared spaces configured.
Card table byte_map: [0x4a940000,0x4ab70000] byte_map_base: 0x4a91a600
Polling page: 0x001e0000
Code Cache [0x02b40000, 0x02d50000, 0x04b40000)
total_blobs=1341 nmethods=1020 adapters=254 free_code_cache=30663Kb largest_free_block=31399808
Compilation events (10 events):
Event: 6.527 Thread 0x4aeda400 1011 java.net.URLClassLoader$1::<init> (15 bytes)
Event: 6.527 Thread 0x4aeda400 nmethod 1011 0x02d48288 code [0x02d48380, 0x02d48420]
Event: 6.527 Thread 0x4aeda400 1013 java.net.URLClassLoader$1::run (5 bytes)
Event: 6.528 Thread 0x4aeda400 nmethod 1013 0x02d48488 code [0x02d48580, 0x02d4860c]
Event: 6.528 Thread 0x4aeda400 1014 ! java.net.URLClassLoader$1::run (73 bytes)
Event: 6.528 Thread 0x4aeda400 nmethod 1014 0x02d48688 code [0x02d487d0, 0x02d48a08]
Event: 6.628 Thread 0x4aeda400 1015 java.security.MessageDigest::update (45 bytes)
Event: 6.629 Thread 0x4aeda400 nmethod 1015 0x02d48c88 code [0x02d48db0, 0x02d48f54]
Event: 6.680 Thread 0x4aeda400 1016 ! sun.security.util.ManifestEntryVerifier::setEntry (299 bytes)
Event: 6.682 Thread 0x4aeda400 nmethod 1016 0x02d4c308 code [0x02d4c600, 0x02d4d050]
GC Heap History (0 events):
No events
Deoptimization events (0 events):
No events
Internal exceptions (10 events):
Event: 6.646 Thread 0x4c142800 Threw 0x09ddc590 at C:\jdk7u1_32P\jdk7u9_3984_new\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 6.646 Thread 0x4c142800 Threw 0x09ddc950 at C:\jdk7u1_32P\jdk7u9_3984_new\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 6.677 Thread 0x4c142800 Threw 0x09dfd4c0 at C:\jdk7u1_32P\jdk7u9_3984_new\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 6.677 Thread 0x4c142800 Threw 0x09dfd8e8 at C:\jdk7u1_32P\jdk7u9_3984_new\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 6.678 Thread 0x4c142800 Threw 0x09e00850 at C:\jdk7u1_32P\jdk7u9_3984_new\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 6.678 Thread 0x4c142800 Threw 0x09e00c48 at C:\jdk7u1_32P\jdk7u9_3984_new\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 6.679 Thread 0x4c142800 Threw 0x09e03c70 at C:\jdk7u1_32P\jdk7u9_3984_new\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 6.679 Thread 0x4c142800 Threw 0x09e04098 at C:\jdk7u1_32P\jdk7u9_3984_new\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 6.681 Thread 0x4c142800 Threw 0x09e076c8 at C:\jdk7u1_32P\jdk7u9_3984_new\hotspot\src\share\vm\prims\jvm.cpp:1166
Event: 6.681 Thread 0x4c142800 Threw 0x09e07a88 at C:\jdk7u1_32P\jdk7u9_3984_new\hotspot\src\share\vm\prims\jvm.cpp:1166
Events (10 events):
Event: 6.648 Executing VM operation: RevokeBias
Event: 6.648 Executing VM operation: RevokeBias done
Event: 6.677 loading class 0x4ecfbeb8
Event: 6.677 loading class 0x4ecfbeb8 done
Event: 6.678 loading class 0x4ed06518
Event: 6.678 loading class 0x4ed06518 done
Event: 6.679 loading class 0x4ecfc900
Event: 6.679 loading class 0x4ecfc900 done
Event: 6.681 loading class 0x4c1ba220
Event: 6.681 loading class 0x4c1ba220 done
Dynamic libraries:
0x00c40000 - 0x00c6f000 C:\Program Files\Java\jre7\bin\javaw.exe
0x77a10000 - 0x77b38000 C:\Windows\system32\ntdll.dll
0x75bf0000 - 0x75ccc000 C:\Windows\system32\kernel32.dll
0x76fa0000 - 0x77066000 C:\Windows\system32\ADVAPI32.dll
0x76ed0000 - 0x76f93000 C:\Windows\system32\RPCRT4.dll
0x76e30000 - 0x76ecd000 C:\Windows\system32\USER32.dll
0x76b00000 - 0x76b4b000 C:\Windows\system32\GDI32.dll
0x743d0000 - 0x7456e000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.6002.18305_none_5cb72f2a088b0ed3\COMCTL32.dll
0x76c70000 - 0x76d1a000 C:\Windows\system32\msvcrt.dll
0x76aa0000 - 0x76af9000 C:\Windows\system32\SHLWAPI.dll
0x6a180000 - 0x6a19e000 C:\Windows\system32\ShimEng.dll
0x754d0000 - 0x754fc000 C:\Windows\system32\apphelp.dll
0x66a50000 - 0x66ad8000 C:\Windows\AppPatch\AcLayers.dll
0x75e60000 - 0x76971000 C:\Windows\system32\SHELL32.dll
0x75730000 - 0x75875000 C:\Windows\system32\ole32.dll
0x76da0000 - 0x76e2d000 C:\Windows\system32\OLEAUT32.dll
0x75580000 - 0x7559e000 C:\Windows\system32\USERENV.dll
0x75560000 - 0x75574000 C:\Windows\system32\Secur32.dll
0x70f20000 - 0x70f62000 C:\Windows\system32\WINSPOOL.DRV
0x750d0000 - 0x750e4000 C:\Windows\system32\MPR.dll
0x65f90000 - 0x661a4000 C:\Windows\AppPatch\AcGenral.DLL
0x74390000 - 0x743cf000 C:\Windows\system32\UxTheme.dll
0x74230000 - 0x74262000 C:\Windows\system32\WINMM.dll
0x741f0000 - 0x7422e000 C:\Windows\system32\OLEACC.dll
0x75390000 - 0x75406000 C:\Windows\system32\NETAPI32.dll
0x756c0000 - 0x756c7000 C:\Windows\system32\PSAPI.DLL
0x74810000 - 0x74824000 C:\Windows\system32\MSACM32.dll
0x74e70000 - 0x74e78000 C:\Windows\system32\VERSION.dll
0x70720000 - 0x70725000 C:\Windows\system32\sfc.dll
0x70710000 - 0x7071d000 C:\Windows\system32\sfc_os.dll
0x75cd0000 - 0x75e5a000 C:\Windows\system32\SETUPAPI.dll
0x73000000 - 0x7300c000 C:\Windows\system32\dwmapi.dll
0x76b50000 - 0x76c61000 C:\Windows\system32\urlmon.dll
0x759e0000 - 0x75b98000 C:\Windows\system32\iertutil.dll
0x76980000 - 0x76a9b000 C:\Windows\system32\WININET.dll
0x771e0000 - 0x771e3000 C:\Windows\system32\Normaliz.dll
0x70db0000 - 0x70db5000 C:\Windows\system32\SHUNIMPL.dll
0x75710000 - 0x7572e000 C:\Windows\system32\IMM32.DLL
0x75910000 - 0x759d8000 C:\Windows\system32\MSCTF.dll
0x77b40000 - 0x77b49000 C:\Windows\system32\LPK.DLL
0x770f0000 - 0x7716d000 C:\Windows\system32\USP10.dll
0x66910000 - 0x669ce000 C:\Program Files\Java\jre7\bin\msvcr100.dll
0x61900000 - 0x61c4d000 C:\Program Files\Java\jre7\bin\client\jvm.dll
0x73470000 - 0x73477000 C:\Windows\system32\WSOCK32.dll
0x771f0000 - 0x7721d000 C:\Windows\system32\WS2_32.dll
0x75700000 - 0x75706000 C:\Windows\system32\NSI.dll
0x73ff0000 - 0x73ffc000 C:\Program Files\Java\jre7\bin\verify.dll
0x6a950000 - 0x6a970000 C:\Program Files\Java\jre7\bin\java.dll
0x69df0000 - 0x69e03000 C:\Program Files\Java\jre7\bin\zip.dll
0x64f10000 - 0x65052000 C:\Program Files\Java\jre7\bin\awt.dll
0x726f0000 - 0x728aa000 C:\Windows\system32\d3d9.dll
0x726e0000 - 0x726e6000 C:\Windows\system32\d3d8thk.dll
0x722d0000 - 0x725a2000 C:\Windows\system32\atiumdag.dll
0x4b9e0000 - 0x4bc82000 C:\Windows\system32\atiumdva.dll
0x68b40000 - 0x68b6a000 C:\Program Files\Java\jre7\bin\fontmanager.dll
0x6a130000 - 0x6a144000 C:\Program Files\Java\jre7\bin\net.dll
0x74cd0000 - 0x74d0b000 C:\Windows\system32\mswsock.dll
0x74e60000 - 0x74e65000 C:\Windows\System32\wship6.dll
0x6e410000 - 0x6e41f000 C:\Program Files\Java\jre7\bin\nio.dll
0x73de0000 - 0x73def000 C:\Windows\system32\NLAapi.dll
0x750b0000 - 0x750c9000 C:\Windows\system32\IPHLPAPI.DLL
0x74ea0000 - 0x74ed5000 C:\Windows\system32\dhcpcsvc.DLL
0x75180000 - 0x751ac000 C:\Windows\system32\DNSAPI.dll
0x750a0000 - 0x750a7000 C:\Windows\system32\WINNSI.DLL
0x74ef0000 - 0x74f12000 C:\Windows\system32\dhcpcsvc6.DLL
0x704a0000 - 0x704af000 C:\Windows\system32\napinsp.dll
0x6ef60000 - 0x6ef72000 C:\Windows\system32\pnrpnsp.dll
0x70490000 - 0x7049c000 C:\Windows\system32\wshbth.dll
0x74270000 - 0x74278000 C:\Windows\System32\winrnr.dll
0x75ba0000 - 0x75be9000 C:\Windows\system32\WLDAP32.dll
0x6ef90000 - 0x6ef96000 C:\Windows\system32\rasadhlp.dll
0x749b0000 - 0x749b5000 C:\Windows\System32\wshtcpip.dll
0x74a90000 - 0x74acb000 C:\Windows\system32\rsaenh.dll
0x688c0000 - 0x688e0000 C:\Program Files\Java\jre7\bin\sunec.dll
0x671e0000 - 0x67211000 C:\Program Files\Java\jre7\bin\t2k.dll
0x75880000 - 0x75904000 C:\Windows\system32\CLBCatQ.DLL
0x73910000 - 0x73a04000 C:\Windows\system32\WindowsCodecs.dll
0x72050000 - 0x72071000 C:\Program Files\AVAST Software\Avast\ashShell.dll
0x71a70000 - 0x71c97000 C:\Windows\system32\msi.dll
0x72030000 - 0x7204f000 C:\Windows\system32\EhStorShell.dll
0x73f30000 - 0x73feb000 C:\Windows\system32\PROPSYS.dll
0x6e090000 - 0x6e099000 C:\Program Files\Java\jre7\bin\sunmscapi.dll
0x74fa0000 - 0x75093000 C:\Windows\system32\CRYPT32.dll
0x75110000 - 0x75122000 C:\Windows\system32\MSASN1.dll
0x4e6b0000 - 0x4e71b000 C:\Users\Gene\AppData\Roaming\.minecraft\bin\natives\lwjgl.dll
0x65ec0000 - 0x65f8b000 C:\Windows\system32\OPENGL32.dll
0x682f0000 - 0x68313000 C:\Windows\system32\GLU32.dll
0x6f060000 - 0x6f145000 C:\Windows\system32\DDRAW.dll
0x747c0000 - 0x747c6000 C:\Windows\system32\DCIMAN32.dll
0x6dcb0000 - 0x6dcb6000 C:\Program Files\Java\jre7\bin\jawt.dll
0x69000000 - 0x69907000 C:\Windows\system32\atioglxx.dll
0x72b80000 - 0x72c5c000 C:\Windows\system32\dbghelp.dll
VM Arguments:
jvm_args: -Xms512m -Xmx1024m
java_command: C:\Users\dudu\Desktop\Minecraft.exe
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Program Files\ATI Technologies\ATI.ACE\Core-Static;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Windows Live\Shared;C:\Program Files\Java\jre7\bin
USERNAME=...
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 13, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 2
CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 15 stepping 13, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, tsc
Memory: 4k page, physical 2587140k(1340580k free), swap 5414720k(3484148k free)
vm_info: Java HotSpot(TM) Client VM (23.5-b02) for windows-x86 JRE (1.7.0_09-b05), built on Sep 24 2012 22:01:33 by "java_re" with unknown MS VC++:1600
  1. C'est un probleme avec java:
    As tu mit a jour java
    Enfin je pense, moi ca me l'avis fait quand j'avais pas mit a jour java
    PS: Ca peut etre aussi un Mod qui n'est pas pour ta version de MINECRAFT
    1. bonjour merci de me repondre ben j ais mis java a jour j ais tous fais mais rien ne vas toujour sle meme probleme le probleme ces que ca es survenu comme ca jamais eu probleme avec mon minecraft enfin merci
  2. C'est un probleme avec java:
