Enregistrer et filtrer un audio sous java
J'ai un programme java qui fait de l'enregistrement audio, mais quand je l'exécute je trouve pas le fichier audio enregistré :( !!
package com.javasrc.audio;
import javax.sound.sampled.*;
import java.io.File;
* Sample audio recorder
public class Recorder extends Thread
double i1, i2, o1, o2; /* temporary variables */
double a0, a1, a2; /* coefficients */
double b0, b1, b2; /* coefficients */
double f; /* last Frequency used */
double q; /* last Q used */
double g; /* last Gain used */
long t; /* last Type used */
static int maxfilterunits=10;
double FilterCell(long Unit, double Input, double Frequency, double Q, double Gain, int Type)
double Output=0,S,omega,A,sn,cs,alpha,beta,temp1,temp2,temp3,temp4;
/* -- check if frequency, Q, gain or type has changed.. and, if so, update coefficients */
if ( ( Frequency != f ) || ( Q != q ) || ( Gain != g ) || ( Type != t ) ) {
f = Frequency; q = Q; g = Gain; t = Type; /* remember last frequency, q, gain and type */
switch (Type) {
case 0: /* no filtering */
b0 = Math.pow( 10.0, Gain / 20.0 ); /* convert from dB to linear */
break;
case 1: /* lowpass */
Gain = Math.pow( 10.0, Gain / 20.0 ); /* convert from dB to linear */
omega = ( Math.PI*2 * Frequency ) / 44100;
sn = Math.sin( omega ); cs = Math.cos( omega );
alpha = sn / ( 2.0 * Q );
a0 = 1.0 / ( 1.0 + alpha );
a1 = ( -2.0 * cs ) * a0;
a2 = ( 1.0 - alpha ) * a0;
b1 = ( 1.0 - cs ) * a0 * Gain;
b0 = b1 * 0.5;
break;
case 2: /* highpass */
b1 = -( 1.0 + cs ) * a0 * Gain;
b0 = -b1 * 0.5;
break;
case 3: /* bandpass */
sn =Math.sin( omega ); cs = Math.cos( omega );
b0 = alpha * a0 * Gain;
break;
case 4: /* notch */
b0 = a0 * Gain;
b1 = a1 * Gain;
break;
case 5: /* lowshelf */
/* "shelf slope" 1.0 = max slope, because neither Q nor bandwidth is used in */
/* those filters (note: true only for lowshelf and highshelf, not peaking). */
S = 1.0; /* used only by lowshelf and highshelf */
A = Math.pow( 10.0 , ( Gain / 40.0 ) ); /* Gain is expressed in dB */
temp1 = A + 1.0; temp2 = A - 1.0; temp3 = temp1 * cs; temp4 = temp2 * cs;
beta = sn * Math.sqrt( ( A * A + 1.0 ) / S - temp2 * temp2 );
a0 = 1.0 / ( temp1 + temp4 + beta );
a1 = ( -2.0 * ( temp2 + temp3 ) ) * a0;
a2 = ( temp1 + temp4 - beta ) * a0;
b0 = ( A * ( temp1 - temp4 + beta ) ) * a0;
b1 = ( 2.0 * A * ( temp2 - temp3 ) ) * a0;
b2 = ( A * ( temp1 - temp4 - beta ) ) * a0;
break;
case 6: /* highshelf */
A = Math.pow( 10.0, ( Gain / 40.0 ) ); /* Gain is expressed in dB */
a0 = 1.0 / ( temp1 - temp4 + beta );
a1 = ( 2.0 * ( temp2 - temp3 ) ) * a0;
a2 = ( temp1 - temp4 - beta ) * a0;
b0 = ( A * ( temp1 + temp4 + beta ) ) * a0;
b1 = ( -2.0 * A * ( temp2 + temp3 ) ) * a0;
b2 = ( A * ( temp1 + temp4 - beta ) ) * a0;
break;
case 7: /* peaking */
temp1 = alpha * A;
temp2 = alpha / A;
a0 = 1.0 / ( 1.0 + temp2 );
a2 = ( 1.0 - temp2 ) * a0;
b0 = ( 1.0 + temp1 ) * a0;
b2 = ( 1.0 - temp1 ) * a0;
break;
/* -- filter loop: if you don't change the parameters of the filter dynamically, ~only this code will be executed. */
switch (Type) {
Output = b0*Input;
Output = Input;
break;
Output = b0*Input + b1*i1 + b0*i2 - a1*o1 - a2*o2;
break;
Output = b0*Input - b0*i2 - a1*o1 - a2*o2;
break;
case 4: /* notch */
break;
case 5: /* low shelving */
case 6: /* high shelving */
Output = b0*Input + b1*i1 + b2*i2 - a1*o1 - a2*o2;
break;
Output = b0*Input + a1*i1 + b2*i2 - a1*o1 - a2*o2;
break;
o2=o1; o1=Output; i2=i1; i1=Input; /* update variables for recursion */
return(Output);
* The TargetDataLine that we'll use to read data from
private TargetDataLine line;
* The audio format type that we'll encode the audio data with
private AudioFileFormat.Type targetType = AudioFileFormat.Type.WAVE;
* The AudioInputStream that we'll read the audio data from
private AudioInputStream inputStream;
* The file that we're going to write data out to
File file=new File("Test.wav");
static final String fsPath = "D:/test/";
// private File file;
* Creates a new Audio Recorder
public Recorder( String outputFilename )
try
// Create an AudioFormat that specifies how the recording will be performed
// In this example we'll 44.1Khz, 16-bit, stereo
AudioFormat audioFormat = new AudioFormat(
AudioFormat.Encoding.PCM_SIGNED, // Encoding technique
44100.0F, // Sample Rate
16, // Number of bits in each channel
2, // Number of channels (2=stereo)
4, // Number of bytes in each frame
44100.0F, // Number of frames per second
false ); // Big-endian (true) or little-
// endian (false)
// Create our TargetDataLine that will be used to read audio data by first
// creating a DataLine instance for our audio format type
DataLine.Info info = new DataLine.Info( TargetDataLine.class, audioFormat );
// Next we ask the AudioSystem to retrieve a line that matches the
// DataLine Info
this.line = ( TargetDataLine )AudioSystem.getLine( info );
// Open the TargetDataLine with the specified format
this.line.open( audioFormat );
// Create an AudioInputStream that we can use to read from the line
this.inputStream = new AudioInputStream( this.line );
// Create the output file
this.file = new File( outputFilename );
catch( Exception e )
e.printStackTrace();
public void startRecording()
// Start the TargetDataLine
this.line.start();
// Start our thread
start();
public void stopRecording()
// Stop and close the TargetDataLine
this.line.stop();
this.line.close();
public void run()
try
// Ask the AudioSystem class to write audio data from the audio input stream
// to our file in the specified data type (PCM 44.1Khz, 16-bit, stereo)
AudioSystem.write( this.inputStream, this.targetType, this.file );
public static void main( String[] args )
if( args.length == 0 )
System.out.println( "Usage: Recorder <filename>" );
System.exit( 0 );
try
// Create a recorder that writes WAVE data to the specified filename
Recorder r = new Recorder( args[ 0 ] );
System.out.println( "Press ENTER to start recording" );
System.in.read();
// Start the recorder
r.startRecording();
System.out.println( "Press ENTER to stop recording" );
System.in.read();
// Stop the recorder
r.stopRecording();
System.out.println( "Recording complete" );
et j'ai un un bout de code qui fait le filtrage d'un fichier audio mais je sais pas comment lui faire passer le fichier enregistré (dans le premier programme) pour le filtrer.
static int maxfilterunits=10; /* set it to the max number of filter units you may use (10 units = use units 0..9) */
switch (Type) {
break;
b0 = b1 * 0.5;
break;
b0 = -b1 * 0.5;
break;
break;
case 4: /* notch */
b0 = a0 * Gain;
b1 = a1 * Gain;
break;
break;
break;
temp1 = alpha * A;
temp2 = alpha / A;
break;
switch (Type) {
Output = b0*Input;
Output = Input;
break;
break;
break;
case 4: /* notch */
break;
break;
break;
return(Output);
Quelqu'un peut m'aider SVP!
10 réponses
    Rajoute une ligne dans ton main :
    System.out.println(file.getAbsolutPath());
    1. Je le trouve toujours pas, le chemin est affiché dans la console mais le fichier audio n'existe pas dans le dossier spécifié ! :(
      1. Voici le code original, avec ta ligne de code System.out.println(file.getAbsolutePath)
        //static File file=new File("Test.wav");
        private static File file;
        try
        // endian (false)
        // DataLine Info
        this.line.start();
        // Start our thread
        start();
        this.line.stop();
        this.line.close();
        public void run()
        try
        System.out.println(file.getAbsoluteFile());
        System.exit( 0 );
        try
        System.in.read();
        r.startRecording();
        System.in.read();
        r.stopRecording();
        Et voila ce que j'ai comme erreur :
        Exception in thread "main" java.lang.NullPointerException
        at com.javasrc.audio.Recorder.main(Recorder.java:115)
        Merci a tous
          Dans le premier code tu avais File file = new File("Test.wav"); et c'est le chemin absolu de ce fichier que je te demandais d'afficher (l est décrit par un chemin relatif et ce que tu veux c'est le chemin absolu)
          Or dans ce deuxième code tu fais File file; et tu ne l'initialises que bien plus tard dans le code, au moment du new Recorder(args[0]). Donc si ça plante c'est parce qu'au moment où tu affiches son chemin, file vaut null ! Ce qu'il te faut afficher c'est finalement new File(args[0]).getAbsolutPath(); ou alors mais ça revient normalement au même, faire l'affichage après le new Recorder(args[0])
      2. Merci pour tes explication, mais tu a raison ça revient au même.
        J'ai essayé tout et j'ai toujours cette erreur au moment de l'exécution de mon programme, et le fichier son ne pourra pas être enregistré, et le problème c'est que je vois pas ou est l'erreur dans mon code.
        quand j'ajoute System.out.println(file.getAbsolutPath());ou new File(args[0]).getAbsolutPath(); dans mon main c'est une erreur d'exception qu'il me renvoi et quand je les retire le programme exécute et le fichier son n'est nul part :('
        Je vais m'y mettre a nouveau
          Donne directement à args[0] un chemin absolu (D:\\Test.wav par exemple) chez moi le fichier Test.wav est alors bien enregistré dans D:\
          Mais chez moi ce code fonctionne pour savoir où est le chemin des anciens fichiers enregistré :
          System.out.println(file.getAbsolutePath());
      3. STP u peux me donner la ligne du code ou t'a modifié le args[0] à D:\\Test.wav (ce que tu a modifié toi )
        ça fait 3 jours que je travailles sur ce code :) et je voudrais bien voir mon résultat :)
          En fait ce n'est pas dans le code, c'est quand tu lances ton programme. En premier argument tu donnes directement un chemin absolu :
          java Recorder D:\test.wav
        2. Quand je lance mon programme voila ce qui m'affiche dans la console :
          C:\Users\workspace\Reco_Vocale\Test.wav
          Mais quand j'y vais a ce dossier je trouve rien.
          tu peux me dire il t'affiche quoi le programme quand tu le lance chez toi, et comment tu arrive a lui donner en premier argument un chemin absolu!?
          Merci beaucoup
        3. Modérateur
          Le problème c'est que tu ne passes pas d'arguments à ton programme !!!
          Du coup tu rentres dans le cas if (args.length==0) qui arrete le programme.
          Tu dois passer le nom de ton fichier en argument de ton programme comme je l'ai mis plus haut !
      4. Modérateur
        Voici ton code, légèrement remanié, de sorte que tu ne devrais plus avoir de problème :
        import java.io.IOException;
        import java.util.Scanner;
        /** Sample audio recorder */
        	/** The TargetDataLine that we'll use to read data from */
        	private final TargetDataLine line;
        	/** The audio format type that we'll encode the audio data with */
        	private final AudioFileFormat.Type targetType = AudioFileFormat.Type.WAVE;
        	/** The AudioInputStream that we'll read the audio data from */
        	private final AudioInputStream inputStream;
        	/** The file that we're going to write data out to */
        	private File file;
        	* @param outputFilename
        	* @throws LineUnavailableException
        	public Recorder(String outputFilename) throws LineUnavailableException
        			false // Big-endian (true) or little-endian (false)
        		DataLine.Info info = new DataLine.Info(TargetDataLine.class, audioFormat);
        		// DataLine Info
        		line = (TargetDataLine) AudioSystem.getLine(info);
        		line.open(audioFormat);
        		inputStream = new AudioInputStream(line);
        		file = new File(outputFilename);
        		line.start();
        		// Start our thread
        		start();
        		line.stop();
        		line.close();
        	public void run()
        		try
        			AudioSystem.write(inputStream,targetType,file);
        		catch (IOException e)
        	public String getPath()
        		return file.getAbsolutePath();
        	public static void pressEnter(String text)
        		System.out.println(text);
        		new Scanner(System.in).nextLine();
        	public static void main(String...args)
        		// Setting fileName
        		String fileName = "default.wav"; // default;
        		if(args.length == 0)
        			System.out.println("Usage: java Recorder <filename>\n" +
        					"Default file will be used\n");
        		else
        			fileName = args[0];
        		try
        			Recorder r = new Recorder(fileName);
        			pressEnter("Press ENTER to start recording");
        			r.startRecording();
        			pressEnter("Press ENTER to stop recording");
        			r.stopRecording();
        			System.out.println("Recording complete : "+r.getPath());
        		catch (LineUnavailableException e)
        1. Enfin pas tout à fait fini !!! il reste a faire passer ce fichier son via filtre passe bande que j'ai déjà posté au début ! tout sera posté à la fin de ce programme.
          je le fait pour apprendre et les autres puissent en profiter!
          @plus
          1. pour filtrer le son passé via un micro j'ai fait une petite recherche et je suis tombé sur cet article http://membres.multimania.fr/amycoders/tutorials/maverick/sfftm.html qui propose un filtre en java
            switch (Type) {
            break;
            b0 = b1 * 0.5;
            break;
            b0 = -b1 * 0.5;
            break;
            break;
            case 4: /* notch */
            b0 = a0 * Gain;
            b1 = a1 * Gain;
            break;
            break;
            break;
            temp1 = alpha * A;
            temp2 = alpha / A;
            break;
            switch (Type) {
            Output = b0*Input;
            Output = Input;
            break;
            break;
            break;
            case 4: /* notch */
            break;
            break;
            break;
            return(Output);
            mais je sais pas trop comment l'utiliser et l'anglais n'est pas trop mon truc !
            Si on finit le boulot ?! :) :) :) !
            Je sais pas trop si c'est faisable déjà :( !
              Le code que tu as récupéré n'est pas du code Java !
              Alors il serait bon de te demander ce que tu souhaites faire, car les bibliothèques Java font déjà peut-être ce que tu veux sans avoir à reprendre ce code que tu ne sais toi même pas trop ce qu'il fait ou comment t'en servir !
          2. Un peu d'explication !!! dans le genre "un signal audio est composé de sons à différentes fréquences, je veux éliminer tous les sons qui ont des fréquences inférieures à 5kHz ou supérieures à 15kHz" (par exemple)
            je veux filtrer mon son pour avoir une bonne qualité d'enregistrement ! et si y a des bibliothèques java qui font ça ça sera mieux que de reprendre ce code !
            pour ceux qui s'intéressent au traitement de signal et au filtrage sonore je vous conseilles de voir ce lien ( en anglais bien évidemment) http://membres.multimania.fr/amycoders/tutorials/maverick/sfftm.html
              Moi perso je n'arrive pas à tester, mais comme j'ai pas de micro ceci explique surement cela ^^
              Pour avoir des exemples de code, le mieux c'est regarder sur le site officiel Java Sound Demo et de potasser le code source des parties qui t'intéressent...
