Problème card driver 'minecraft'
help Window Xp
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 26/08/11 13:09
Minecraft: Minecraft Beta 1.7.3
OS: Windows XP (x86) version 5.1
Java: 1.6.0_27, Sun Microsystems Inc.
VM: Java HotSpot(TM) Client VM (mixed mode), Sun Microsystems Inc.
LWJGL: 2.4.2
[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at
org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelForma
t(Native Method)
at
org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat
(WindowsPeerInfo.java:52)
at
org.lwjgl.opengl.WindowsDisplay.createWindow(Windo
wsDisplay.java:185)
at
org.lwjgl.opengl.Display.createWindow(Display.java
:311)
at
org.lwjgl.opengl.Display.create(Display.java:856)
at
org.lwjgl.opengl.Display.create(Display.java:784)
at
org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:294)
at
net.minecraft.client.Minecraft.run(SourceFile:716)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT 7419128a ----------
où est le problème svp
cordialement X_xray95
  1. Le probleme est surement par rapport a ta carte graphique.
    Met la a jour et ca marchera nikel.
    Sinon c'est java, met aussi java a jour si la premiere solution ne marche pas
    et tu pourra jouer a ton jeu.
    1. le truc c'est comment la mettre a jour la carte graphique U_u
