Java swing comment afficher un jpanel
comment faire pour afficher une fenetre apres un clic sur un bouton
voici ce que j ai essayer de faire et qui ne marche pas
interfanceun.java
    private void boutonunActionPerformed(java.awt.event.ActionEvent evt) {
panel test = new panel();
        // TODO add your handling code here:
panel.java
 * To change this template, choose Tools | Templates
 * and open the template in the editor.
 * panel.java
 * Created on 9 sept. 2010, 09:45:42
package intro;
 * @author sofiene
public class panel extends javax.swing.JPanel {
    /** Creates new form panel */
    public panel() {
    setVisible(true);
        initComponents();
    /** This method is called from within the constructor to
     * initialize the form.
     * WARNING: Do NOT modify this code. The content of this method is
     * always regenerated by the Form Editor.
    @SuppressWarnings("unchecked")
    // <editor-fold defaultstate="collapsed" desc="Generated Code">
    private void initComponents() {
        javax.swing.GroupLayout layout = new javax.swing.GroupLayout(this);
        this.setLayout(layout);
        layout.setHorizontalGroup(
            layout.createParallelGroup(javax.swing.GroupLayout.Alignment.LEADING)
            .addGap(0, 400, Short.MAX_VALUE)
        layout.setVerticalGroup(
            .addGap(0, 300, Short.MAX_VALUE)
    }// </editor-fold>
    // Variables declaration - do not modify
    // End of variables declaration
merci de votre aide
  1. Tu dois declarer une fenetre "JFrame" et ajouter a la fenetre ton JPanel.
    par exemple:
    fenetre.getContentPane.add(panel);
    1. bonjour
      j ai enfin compris
      je te remercie
      c est sympa de m'avoir aidé
