Probleme java
ce matin au demarrage de l ordi impossible de faire quoi que ce soit :
la souris se transforme en sablier sur la barre des taches, msn ne se lance pas en connection automatique, impossible de faire une restauration systeme, et ce fichier texte est apparu sur mon bureau:
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x0316c41f, pid=5624, tid=5768
# JRE version: 6.0_15-b03
# Java VM: Java HotSpot(TM) Client VM (14.1-b02 mixed mode, sharing windows-x86 )
# Problematic frame:
# C 0x0316c41f
# If you would like to submit a bug report, please visit:
# https://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x031c2c00): JavaThread "thread applet-JavaFX-1" [_thread_in_native, id=5768, stack(0x04240000,0x04290000)]
siginfo: ExceptionCode=0xc0000005, writing address 0x04283101
Registers:
EAX=0x00000000, EBX=0x26c57f30, ECX=0x7c34218f, EDX=0x00000000
ESP=0x0428f6a0, EBP=0x255a255a, ESI=0x26c57f30, EDI=0x031c2c00
EIP=0x0316c41f, EFLAGS=0x00210202
Top of Stack: (sp=0x0428f6a0)
0x0428f6a0: 0316c41c fffffffe 0428f6a8 26c57f30
0x0428f6b0: 0428f6dc 26c58600 00000000 26c57f30
0x0428f6c0: 00000000 0428f6d8 0428f704 00992e83
0x0428f6d0: 00000000 00998269 23201f30 22a9eb58
0x0428f6e0: 22a9eb58 0428f6e4 26c57e8f 0428f714
0x0428f6f0: 26c58600 00000000 26c57eb0 0428f6d8
0x0428f700: 0428f710 0428f738 00992da1 22aa0328
0x0428f710: 23201f30 22a9eb58 0428f718 26c57439
Instructions: (pc=0x0316c41f)
0x0316c40f: 2b 58 ac 19 2b 00 8d 19 2b b0 80 9b 2a 30 7f c5
0x0316c41f: 26 c8 83 c5 26 b0 80 9b 2a 48 90 c5 26 58 90 c5
Stack: [0x04240000,0x04290000], sp=0x0428f6a0, free space=317k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C 0x0316c41f
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j com.sun.media.sound.HeadspaceSoundbank.nOpenResource(Ljava/lang/String;)J+0
j com.sun.media.sound.HeadspaceSoundbank.initialize(Ljava/lang/String;)V+7
j com.sun.media.sound.HeadspaceSoundbank.<init>(Ljava/net/URL;)V+89
j com.sun.media.sound.HsbParser.getSoundbank(Ljava/net/URL;)Ljavax/sound/midi/Soundbank;+5
j javax.sound.midi.MidiSystem.getSoundbank(Ljava/net/URL;)Ljavax/sound/midi/Soundbank;+36
j JavaFXTrueColor.init(Ljava/net/URL;)V+52
j JavaFX.init()V+1060
j sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run()V+916
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x032ce000 JavaThread "Java Sound Event Dispatcher" daemon [_thread_blocked, id=6124, stack(0x042e0000,0x04330000)]
0x031cf800 JavaThread "Image Fetcher 1" daemon [_thread_blocked, id=5228, stack(0x04410000,0x04460000)]
0x031cf000 JavaThread "Image Fetcher 0" daemon [_thread_blocked, id=3528, stack(0x04330000,0x04380000)]
0x031c6400 JavaThread "D3D Screen Updater" daemon [_thread_blocked, id=1544, stack(0x04380000,0x043d0000)]
0x031b4400 JavaThread "thread applet-quote.GReader.class-2" [_thread_blocked, id=2136, stack(0x04290000,0x042e0000)]
=>0x031c2c00 JavaThread "thread applet-JavaFX-1" [_thread_in_native, id=5768, stack(0x04240000,0x04290000)]
0x031a2000 JavaThread "AWT-EventQueue-3" [_thread_blocked, id=3364, stack(0x041f0000,0x04240000)]
0x0319e800 JavaThread "Applet 2 LiveConnect Worker Thread" [_thread_blocked, id=4332, stack(0x04190000,0x041e0000)]
0x0319d800 JavaThread "AWT-EventQueue-2" [_thread_blocked, id=5592, stack(0x03500000,0x03550000)]
0x0319a000 JavaThread "Applet 1 LiveConnect Worker Thread" [_thread_blocked, id=2996, stack(0x04140000,0x04190000)]
0x0319a400 JavaThread "Image Fetcher 3" daemon [_thread_blocked, id=544, stack(0x040f0000,0x04140000)]
0x03198400 JavaThread "Browser Side Object Cleanup Thread" [_thread_blocked, id=3040, stack(0x040a0000,0x040f0000)]
0x0318a400 JavaThread "AWT-Shutdown" [_thread_blocked, id=5384, stack(0x03640000,0x03690000)]
0x03165800 JavaThread "Windows Tray Icon Thread" [_thread_in_native, id=3972, stack(0x03550000,0x035a0000)]
0x0316a000 JavaThread "CacheCleanUpThread" daemon [_thread_blocked, id=1724, stack(0x03400000,0x03450000)]
0x031b7400 JavaThread "CacheMemoryCleanUpThread" daemon [_thread_blocked, id=4836, stack(0x035f0000,0x03640000)]
0x02bbe400 JavaThread "Java Plug-In Heartbeat Thread" [_thread_blocked, id=3780, stack(0x035a0000,0x035f0000)]
0x03167000 JavaThread "AWT-Windows" daemon [_thread_in_native, id=4084, stack(0x03450000,0x034a0000)]
0x03164800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=4684, stack(0x033b0000,0x03400000)]
0x02bce000 JavaThread "Java Plug-In Pipe Worker Thread (Client-Side)" daemon [_thread_in_native, id=6100, stack(0x03110000,0x03160000)]
0x02b52c00 JavaThread "traceMsgQueueThread" daemon [_thread_blocked, id=3892, stack(0x03030000,0x03080000)]
0x02b4ec00 JavaThread "Timer-0" [_thread_blocked, id=5496, stack(0x02fe0000,0x03030000)]
0x02b38c00 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=5772, stack(0x02db0000,0x02e00000)]
0x02b32c00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=5360, stack(0x02d60000,0x02db0000)]
0x02b31400 JavaThread "Attach Listener" daemon [_thread_blocked, id=248, stack(0x02d10000,0x02d60000)]
0x02b30000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=5868, stack(0x02cc0000,0x02d10000)]
0x02aee000 JavaThread "Finalizer" daemon [_thread_blocked, id=5520, stack(0x02c70000,0x02cc0000)]
0x02aecc00 JavaThread "Reference Handler" daemon [_thread_blocked, id=3084, stack(0x02c20000,0x02c70000)]
0x00886800 JavaThread "main" [_thread_blocked, id=4372, stack(0x00910000,0x00960000)]
Other Threads:
0x02aeb000 VMThread [stack: 0x02bd0000,0x02c20000] [id=2400]
0x02b43000 WatcherThread [stack: 0x02e00000,0x02e50000] [id=2908]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 4544K, used 1091K [0x22990000, 0x22e70000, 0x22e70000)
eden space 4096K, 26% used [0x22990000, 0x22aa0d08, 0x22d90000)
from space 448K, 0% used [0x22d90000, 0x22d90000, 0x22e00000)
to space 448K, 0% used [0x22e00000, 0x22e00000, 0x22e70000)
tenured generation total 60544K, used 50772K [0x22e70000, 0x26990000, 0x26990000)
the space 60544K, 83% used [0x22e70000, 0x26005290, 0x26005400, 0x26990000)
compacting perm gen total 12288K, used 2929K [0x26990000, 0x27590000, 0x2a990000)
the space 12288K, 23% used [0x26990000, 0x26c6c4b8, 0x26c6c600, 0x27590000)
ro space 8192K, 63% used [0x2a990000, 0x2aea9920, 0x2aea9a00, 0x2b190000)
rw space 12288K, 53% used [0x2b190000, 0x2b804dd0, 0x2b804e00, 0x2bd90000)
Dynamic libraries:
0x00400000 - 0x00424000 C:\Program Files\Java\jre6\bin\java.exe
0x7c910000 - 0x7c9c9000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c906000 C:\WINDOWS\system32\kernel32.dll
0x77da0000 - 0x77e4c000 C:\WINDOWS\system32\ADVAPI32.dll
0x77e50000 - 0x77ee2000 C:\WINDOWS\system32\RPCRT4.dll
0x77fc0000 - 0x77fd1000 C:\WINDOWS\system32\Secur32.dll
0x5cea0000 - 0x5cec6000 C:\WINDOWS\system32\ShimEng.dll
0x715c0000 - 0x71639000 C:\WINDOWS\AppPatch\AcLayers.DLL
0x7e390000 - 0x7e421000 C:\WINDOWS\system32\USER32.dll
0x77ef0000 - 0x77f39000 C:\WINDOWS\system32\GDI32.dll
0x7c9d0000 - 0x7d1f5000 C:\WINDOWS\system32\SHELL32.dll
0x77be0000 - 0x77c38000 C:\WINDOWS\system32\msvcrt.dll
0x77f40000 - 0x77fb6000 C:\WINDOWS\system32\SHLWAPI.dll
0x774a0000 - 0x775dd000 C:\WINDOWS\system32\ole32.dll
0x76960000 - 0x76a16000 C:\WINDOWS\system32\USERENV.dll
0x72f50000 - 0x72f76000 C:\WINDOWS\system32\WINSPOOL.DRV
0x76320000 - 0x7633d000 C:\WINDOWS\system32\IMM32.DLL
0x77390000 - 0x77493000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll
0x7c340000 - 0x7c396000 C:\Program Files\Java\jre6\bin\msvcr71.dll
0x6d800000 - 0x6da8b000 C:\Program Files\Java\jre6\bin\client\jvm.dll
0x76ae0000 - 0x76b0f000 C:\WINDOWS\system32\WINMM.dll
0x6d7b0000 - 0x6d7bc000 C:\Program Files\Java\jre6\bin\verify.dll
0x6d330000 - 0x6d34f000 C:\Program Files\Java\jre6\bin\java.dll
0x6d290000 - 0x6d298000 C:\Program Files\Java\jre6\bin\hpi.dll
0x76ba0000 - 0x76bab000 C:\WINDOWS\system32\PSAPI.DLL
0x6d7f0000 - 0x6d7ff000 C:\Program Files\Java\jre6\bin\zip.dll
0x6d430000 - 0x6d436000 C:\Program Files\Java\jre6\bin\jp2native.dll
0x6d1d0000 - 0x6d1e3000 C:\Program Files\Java\jre6\bin\deploy.dll
0x779e0000 - 0x77a77000 C:\WINDOWS\system32\CRYPT32.dll
0x77a80000 - 0x77a92000 C:\WINDOWS\system32\MSASN1.dll
0x770e0000 - 0x7716b000 C:\WINDOWS\system32\OLEAUT32.dll
0x404a0000 - 0x40586000 C:\WINDOWS\system32\WININET.dll
0x02e50000 - 0x02e59000 C:\WINDOWS\system32\Normaliz.dll
0x45180000 - 0x452b3000 C:\WINDOWS\system32\urlmon.dll
0x40b40000 - 0x40d28000 C:\WINDOWS\system32\iertutil.dll
0x6d6b0000 - 0x6d6f3000 C:\Program Files\Java\jre6\bin\regutils.dll
0x77bd0000 - 0x77bd8000 C:\WINDOWS\system32\VERSION.dll
0x7d200000 - 0x7d4bc000 C:\WINDOWS\system32\msi.dll
0x6d610000 - 0x6d623000 C:\Program Files\Java\jre6\bin\net.dll
0x719f0000 - 0x71a07000 C:\WINDOWS\system32\WS2_32.dll
0x719e0000 - 0x719e8000 C:\WINDOWS\system32\WS2HELP.dll
0x6d630000 - 0x6d639000 C:\Program Files\Java\jre6\bin\nio.dll
0x6d000000 - 0x6d14a000 C:\Program Files\Java\jre6\bin\awt.dll
0x5b090000 - 0x5b0c8000 C:\WINDOWS\system32\uxtheme.dll
0x74690000 - 0x746dc000 C:\WINDOWS\system32\MSCTF.dll
0x77b50000 - 0x77b72000 C:\WINDOWS\system32\apphelp.dll
0x75140000 - 0x7516e000 C:\WINDOWS\system32\msctfime.ime
0x6d230000 - 0x6d284000 C:\Program Files\Java\jre6\bin\fontmanager.dll
0x4fcf0000 - 0x4fe96000 C:\WINDOWS\system32\d3d9.dll
0x6de60000 - 0x6de66000 C:\WINDOWS\system32\d3d8thk.dll
0x71990000 - 0x719d0000 C:\WINDOWS\System32\mswsock.dll
0x76ed0000 - 0x76ef7000 C:\WINDOWS\system32\DNSAPI.dll
0x76f60000 - 0x76f68000 C:\WINDOWS\System32\winrnr.dll
0x76f10000 - 0x76f3d000 C:\WINDOWS\system32\WLDAP32.dll
0x76f70000 - 0x76f76000 C:\WINDOWS\system32\rasadhlp.dll
0x6d1a0000 - 0x6d1c3000 C:\Program Files\Java\jre6\bin\dcpr.dll
0x62e40000 - 0x62e99000 C:\WINDOWS\system32\hnetcfg.dll
0x719d0000 - 0x719d8000 C:\WINDOWS\System32\wshtcpip.dll
0x68000000 - 0x68036000 C:\WINDOWS\system32\rsaenh.dll
0x6fee0000 - 0x6ff35000 C:\WINDOWS\system32\netapi32.dll
0x6d520000 - 0x6d544000 C:\Program Files\Java\jre6\bin\jsound.dll
0x6d550000 - 0x6d558000 C:\Program Files\Java\jre6\bin\jsoundds.dll
0x73e60000 - 0x73ebc000 C:\WINDOWS\system32\DSOUND.dll
0x72c70000 - 0x72c79000 C:\WINDOWS\system32\wdmaud.drv
0x76be0000 - 0x76c0e000 C:\WINDOWS\system32\WINTRUST.dll
0x76c40000 - 0x76c68000 C:\WINDOWS\system32\IMAGEHLP.dll
0x72c60000 - 0x72c68000 C:\WINDOWS\system32\msacm32.drv
0x77bb0000 - 0x77bc5000 C:\WINDOWS\system32\MSACM32.dll
0x77ba0000 - 0x77ba7000 C:\WINDOWS\system32\midimap.dll
0x76e90000 - 0x76ecc000 C:\WINDOWS\system32\RASAPI32.dll
0x76e40000 - 0x76e52000 C:\WINDOWS\system32\rasman.dll
0x76e60000 - 0x76e8f000 C:\WINDOWS\system32\TAPI32.dll
0x76e30000 - 0x76e3e000 C:\WINDOWS\system32\rtutils.dll
0x77c40000 - 0x77c65000 C:\WINDOWS\system32\msv1_0.dll
0x76730000 - 0x7673c000 C:\WINDOWS\system32\cryptdll.dll
0x76d10000 - 0x76d29000 C:\WINDOWS\system32\iphlpapi.dll
0x72220000 - 0x72225000 C:\WINDOWS\system32\sensapi.dll
0x76cf0000 - 0x76d08000 C:\WINDOWS\system32\MPRAPI.dll
0x77c90000 - 0x77cc2000 C:\WINDOWS\system32\ACTIVEDS.dll
0x76dc0000 - 0x76de5000 C:\WINDOWS\system32\adsldpc.dll
0x76ac0000 - 0x76ad1000 C:\WINDOWS\system32\ATL.DLL
0x71b50000 - 0x71b63000 C:\WINDOWS\system32\SAMLIB.dll
0x778e0000 - 0x779d8000 C:\WINDOWS\system32\SETUPAPI.dll
VM Arguments:
jvm_args: -D__jvm_launched=21693445829 -Xbootclasspath/a:C:\PROGRA~1\Java\jre6\lib\deploy.jar;C:\PROGRA~1\Java\jre6\lib\javaws.jar;C:\PROGRA~1\Java\jre6\lib\plugin.jar
java_command: sun.plugin2.main.client.PluginMain write_pipe_name=jpi2_pid5216_pipe4,read_pipe_name=jpi2_pid5216_pipe3
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\Program Files\Adobe\Reader 9.0\Reader\plug_ins;C:\Program Files\Adobe\Reader 9.0\Reader\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
USERNAME=USER
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 11, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 3
CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 15 stepping 11, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3
Memory: 4k page, physical 2097151k(1292036k free), swap 4194303k(3262204k free)
vm_info: Java HotSpot(TM) Client VM (14.1-b02) for windows-x86 JRE (1.6.0_15-b03), built on
que faire ? aidez moi svp ?
    Pas grand chose à te dire sur cette erreur.
    Tu pourrais si tu le désires, télécharger cette version:
    https://www.java.com/fr/download/manual.jsp
    A partir de ton ordinateur si tu peux ou un autre et le mettre sur une clé.
    Passez en mode sans echec, panneau de config et supprimez toutes les versions de JAVA.
    Revenir en mode normale:
    Ensuite téléchargez JAVARA, pour tout nettoyer.
    https://www.commentcamarche.net/faq/15645-supprimer-les-anciennes-versions-de-java-avec-javara
    Et enfin installez java
    Bon courage
    A+Lusche Philippe
