Problème CSS Kicked by console !!!HELP !
Voila , en faite , je joue a counter strike source depuis un moment , et en faite , depuis 3 jour , je suis bloqué sur un serveur , et je comprend pas pourquoi , le message qu'ils m'affichent est : Kicked by console : You were Autokicked . Et voila le message qu'ils m'affichent dans ma console :
SetConVar: No such cvar ( view_rates set to 2.4), skipping
SetConVar: No such cvar ( disco_version set to 3.0.0b), skipping
SetConVar: No such cvar ( rank_cut set to 1.224p), skipping
SetConVar: No such cvar ( gore_effects_version set to 1.0 by L'in20Cible), skipping
SetConVar: No such cvar ( Messiah_ResetRank set to 1), skipping
SetConVar: No such cvar ( Nombre_survivants set to 1.1), skipping
SetConVar: No such cvar ( ba_jail set to 1.2), skipping
SetConVar: No such cvar ( mani_nextmap set to ba_extreme_jail), skipping
SetConVar: No such cvar ( mani_tickrate set to 100), skipping
SetConVar: No such cvar ( Es_loads_MondialServers.com set to 2), skipping
SetConVar: No such cvar ( es_corelib_ver set to 2.0.0.250i), skipping
SetConVar: No such cvar ( eventscripts_ver set to 2.0.0.250i), skipping
No pure server whitelist. sv_pure = 0
CAsyncWavDataCache: 530 .wavs total 0 bytes, 0.00 % of capacity
Begin loading faces (loads materials)
End loading faces (loads materials)
default error texture maps/ba_deep_prison_b3/cubemapdefault
Initializing renderer...
You have been autokicked
Disconnect: Kicked by Console : You were autokicked.
AIDER MOI PLEEEEASE SIIIIL VOUS PLAIIIIT !!!
Configuration: Windows 7 / Internet Explorer 8.0
alors, je croit qu'il faut supprimer la map ba_deel_prison_b3 de ton cstrike
après tu tape dans ta console - rate 30000
- cl_cmdrate 100
- cl_updaterate 100
J'espere que cela marchera -
bonjour,
quand je vais dans un serveur, on m'affiche ceci
et puis dans la console sa me met sa:
Counter-Strike: Source
Map: de_dust2
Players: 1 / 6
Build 4100
Server Number 6
SetConVar: No such cvar ( mani_nextmap set to de_piranesi), skipping
SetConVar: No such cvar ( mani_tickrate set to 66), skipping
Got pure server whitelist: sv_pure = 1.
CAsyncWavDataCache: 2 .wavs total 0 bytes, 0.00 % of capacity
Warning: using WorldTwoTextureBlend on a non-displacement surface.
Support for this will go away soon.
- Material : de_dust/groundsand_blend
- Surface center : -1920 2440 0
Warning: using WorldTwoTextureBlend on a non-displacement surface (material: de_dust/groundsand_blend). Support for this will go away soon.
File 'downloads/b2081aad.dat' requested from server 77.111.198.128:27015.
est ce que vous pouvez m'aidez svp?
