Probleme svchost.exe 100% UC
l'application svchot mange toute mes ressources voici mon hijack,
merci de me dire s'il s'agit d'un virus(avast et avira]ne trouvent rien) et si oui comment m'en dégbarrassé :)
Logfile of HijackThis v1.99.1
Scan saved at 15:53:17, on 19/12/2009
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\csrss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Alwil Software\Avast4\ashServ.exe
C:\Program Files\Avira\AntiVir Desktop\sched.exe
C:\Program Files\Alwil Software\Avast4\setup\avast.setup
C:\WINDOWS\SOUNDMAN.EXE
C:\Program Files\CD-R\DAEMON Tools\daemon.exe
C:\Program Files\Vtune\TBPanel.exe
C:\WINDOWS\system32\RUNDLL32.EXE
C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
C:\Program Files\Avira\AntiVir Desktop\avgnt.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Avira\AntiVir Desktop\avguard.exe
C:\WINDOWS\system32\nvsvc32.exe
C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
C:\WINDOWS\System32\alg.exe
C:\Documents and Settings\Administrateur\Bureau\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page =
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
R3 - Default URLSearchHook is missing
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O2 - BHO: FlashFXP Helper for Internet Explorer - {E5A1691B-D188-4419-AD02-90002030B8EE} - C:\PROGRA~1\FlashFXP\IEFlash.dll
O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [DAEMON Tools] "C:\Program Files\CD-R\DAEMON Tools\daemon.exe\" -lang 1033
O4 - HKLM\..\Run: [Gainward] C:\Program Files\Vtune\TBPanel.exe /A
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [KernelFaultCheck] %systemroot%\system32\dumprep 0 -k
O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
O4 - HKLM\..\Run: [avgnt] "C:\Program Files\Avira\AntiVir Desktop\avgnt.exe" /min
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe
O4 - Startup: siszyd32.exe
O8 - Extra context menu item: E&xporter vers Microsoft Excel - res://C:\PROGRA~1\MICROS~1\OFFICE11\EXCEL.EXE/3000
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06\bin\npjpi150_06.dll
O9 - Extra 'Tools' menuitem: Console Java (Sun) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06\bin\npjpi150_06.dll
O9 - Extra button: Recherche - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~1\OFFICE11\REFIEBAR.DLL
O18 - Protocol: msnim - {828030A1-22C1-4009-854F-8E305202313F} - "C:\PROGRA~1\MSNMES~1\msgrapp.dll" (file missing)
O23 - Service: Avira AntiVir Planificateur (AntiVirSchedulerService) - Avira GmbH - C:\Program Files\Avira\AntiVir Desktop\sched.exe
O23 - Service: Avira AntiVir Guard (AntiVirService) - Avira GmbH - C:\Program Files\Avira\AntiVir Desktop\avguard.exe
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - ALWIL Software - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: avast! Antivirus - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe" /service (file missing)
O23 - Service: avast! Web Scanner - Unknown owner - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe" /service (file missing)
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
Firefox 1.5.0.12
  1. Contributeur sécurité
    Télécharge Superantispyware (SAS)
    http://www.superantispyware.com/superantispywarefreevspro.ht%C2%ADml
    Choisis "enregistrer" et enregistre-le sur ton bureau.
    Double-clique sur l'icône d'installation qui vient de se créer et suis les instructions.
    Créé une icône sur le bureau.
    Double-clique sur l'icône de SAS (une tête dans un cercle rouge barré) pour le lancer.
    - Si l'outil te demande de mettre à jour le programme ("update the program definitions", clique sur yes.
    - Sous Configuration and Préférences, clique sur le bouton "Préférences"
    - Clique sur l'onglet "Scanning Control "
    - Dans "Scanner Options ", assure toi que la case devant les lignes suivantes est cochée :
    Close browsers before scanning (Fermer Navigateur avant le scan)
    Scan for tracking cookies (Scan pour dépister les cookies)
    Terminate memory threats before quarantining (Terminez les menaces de mémoire avant de mettre en quarantaine)
    - Laisse les autres lignes décochées.
    - Clique sur le bouton "Close" pour quitter l'écran du centre de contrôle.
    - Dans la fenêtre principale, clique, dans "Scan for Harmful Software", sur "Scan your computer".
    Dans la colonne de gauche, coche C:\Fixed Drive.
    Dans la colonne de droite, sous "Complète scan", clique sur "Perform Complète Scan"
    Clique sur "next" pour lancer le scan. Patiente pendant la durée du scan.
    A la fin du scan, une fenêtre de résultats s'ouvre . Clique sur OK.
    Assure toi que toutes les lignes de la fenêtre blanche sont cochées et clique sur "Next".
    Tout ce qui a été trouvé sera mis en quarantaine. S'il t'es demandé de redémarrer l'ordi ("reboot"), clique sur Yes.
    Pour recopier les informations sur le forum, fais ceci :
    - après le redémarrage de l'ordi, double-clique sur l'icône pour lancer SAS.
    - Clique sur "Préférences" puis sur l'onglet "Statistics/Logs ".
    - Dans "scanners logs", double-clique sur SuperAntiSpyware Scan Log.
    - Le rapport va s'ouvrir dans ton éditeur de texte par défaut.
    - Copie son contenu dans ta réponse.
    Regarde bien le tuto SuperAntiSpyware il est très bien expliqué.
    https://www.malekal.com/?s=SUPERAntiSpyware
