{MySQL} Probleme fonction
j'essaye de creer une fonction moteur de recherche, pour avoir plusieurs champs, et chercher ainsi en fonction de ce qu'on veut. voila mon code :
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
<head>
<title>Information writer</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<link rel="stylesheet" media="screen" type="text/css" title="Design" href="design_index.css" />
</head>
<body>
<?php
$field= "company";
function search_by($field)
if(isset($_POST['requete']) && $_POST['requete'] != NULL)
mysql_connect('localhost','root','');
mysql_select_db('nasforce');
$requete = htmlspecialchars($_POST['requete']);
$query = mysql_query("SELECT * FROM investors WHERE $field LIKE '%$requete%' ORDER BY id DESC") or die (mysql_error());
$nb_resultats = mysql_num_rows($query);
if($nb_resultats != 0)
<h3>Here is your result research.</h3>
<p>We found <?php echo $nb_resultats;
if($nb_resultats > 1) { echo ' results which are'; } else { echo 'result which is'; }
<br/><br /><br /><br />
<?php
while($donnees = mysql_fetch_array($query))
$company_name_tranmitted = $donnees['$field'];
<a href="affichage_result_details.php? request=<?php echo $company_name_tranmitted;?>"><strong><?php echo $field ?></strong> : <?php echo $donnees['$field']; ?><br /></a></p>
<?php
<br/><br/>
<a href="search_engine_test.php">New Research</a></p>
<?php
else
<p> sorry there are no such entries there </p>
<?php
else
<p>search by <?php echo $field ?></p>
<form action="search_engine_test.php" method="Post">
<input type="text" name="requete" size="20">
<input type="submit" value="Ok">
</form>
<?php
search_by(date); <br/>
search_by(entered_by);<br/>
search_by(type);
</body>
</html>
le moteur de recherche marche sans probleme et je pourrais faire 3 ou 4 copier coller, mais je preferais le faire en etant un peu moins bourrin :)
Merci !
Firefox 3.0.13
  1. Tu n'a qu'a recherché tout d'un coup ...
    SELECT *
    FROM investors
    WHERE
        `date` LIKE '%$requete%'
        OR `entered_by` LIKE '%$requete%'
        OR `type` LIKE '%$requete%'
    ORDER BY id DESC
    bien sur, tu peux aussi personnaliser, voire même appeler ta fonction en lui passant une liste des champs à tester, générer la requête dynamiquement ...
    1. Peut etre que je me trompe, mais je me disais que pour une recherche, c'est peut etre pas la meilleure solution de tout selectionner d'un coup...?
      1. c'est toujours mieux que de faire 3 fois la recherche ...
        Après ça dépend ce que tu veux faire.
        Si tu dois séparer l'affichage des recherches, évidemment, il faudra le faire plusieurs fois.
        Avec la méthode donnée, tu aura tout les résultats mélangé ... mais forcément plus rapide.
