Problème paquets Kubuntu
J'aurai besoin de votre aide car je n'arrive pas à installer le paquet language-support-fr. Je tape "sudo aptitude install -fy kubuntu-restricted-extras kcalc kmymoney2 firefox gimp language-pack-kde-fr language-pack-kde-en-base language-pack-kde-en language-pack-kde-fr-base language-pack-kde-fr" pour installer mes paquets mais ça me renvoye toujours que les paquets ne se sont pas installés:
firefox [Not Installed]
gimp [Not Installed]
gimp-data [Not Installed]
gimp-svg [Not Installed]
language-pack-kde-fr [Not Installed]
libgimp2.0 [Not Installed]
Voici le message exact:
robin@Portable-Maison:~$ sudo aptitude install -fy kubuntu-restricted-extras kcalc kmymoney2 firefox gimp language-pack-kde-fr language-pack-kde-en-base language-pack-kde-en language-pack-kde-fr-base language-pack-kde-fr
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances
Reading state information... Fait
Reading extended state information
Initializing package states... Fait
Building tag database... Fait
No candidate version found for kubuntu-restricted-extras
Couldn't find any package whose name or description matched "kcalc"
Couldn't find any package whose name or description matched "kmymoney2"
No candidate version found for language-pack-kde-fr-base
The following packages are BROKEN:
firefox gimp gimp-svg language-pack-kde-fr libgimp2.0
The following NEW packages will be automatically installed:
gimp-data libnspr4 libnss3
The following packages have been kept back:
adept-batch adept-installer adept-manager adept-notifier adept-updater
foo2zjs gtk-qt-engine openoffice.org-calc openoffice.org-common
openoffice.org-core openoffice.org-draw openoffice.org-impress
openoffice.org-kde openoffice.org-math openoffice.org-style-crystal
openoffice.org-style-default openoffice.org-writer python-uno
The following NEW packages will be installed:
0 packages upgraded, 8 newly installed, 0 to remove and 18 not upgraded.
Need to get 17.3MB of archives. After unpacking 69.0MB will be used.
The following packages have unmet dependencies:
language-pack-kde-fr: Dépend: language-pack-kde-fr-base which is a virtual package.
gimp-svg: Dépend: gimp (= 2.2.13-1ubuntu4.3) but 2.2.13-1ubuntu4.4 is to be installed.
Dépend: libpango1.0-0 (>= 1.16.2) but 1.15.6-0ubuntu1 is installed.
Dépend: librsvg2-2 (>= 2.14.4) which is a virtual package.
firefox: Dépend: libpango1.0-0 (>= 1.16.2) but 1.15.6-0ubuntu1 is installed.
gimp: Dépend: libaa1 (>= 1.2) which is a virtual package.
Dépend: libwmf0.2-7 (>= 0.2.8.4) which is a virtual package.
libgimp2.0: Dépend: libpango1.0-0 (>= 1.16.2) but 1.15.6-0ubuntu1 is installed.
Resolving dependencies...
The following actions will resolve these dependencies:
Keep the following packages at their current version:
Score is -76
0 packages upgraded, 0 newly installed, 0 to remove and 18 not upgraded.
Need to get 0B of archives. After unpacking 0B will be used.
Writing extended state information... Fait
P.-S. Je télécharge les paquets depuis medibuntu.
Configuration: Linux
Konqueror 3.5
  1. langage-support-fr tu le tape dans la fenetre recherche de adept
    la des paquets apparaisse essai cet voie!
    et coche tes fr souhaité applique et dit si cela installe bien:
    1. Il y a tout sauf code sources... Je veux juste mettre la langue en français...
      1. dans ton menu k =========system prends gestionnaire de package adept ouvre vas à source ====modifier les sources .....et regarde d'abord si tout es coché excepter code source
