Problème Java au démarrage de la consol
Alors voila, j'ai installé la dernière version de java.. 6 update 5...
mais le problème persiste.. j'ai désinstalé et réinstalé..
et voila le problème lorsque je veux lancé un applet java sous firefox 2.0.0.12 ...
Recharger la configuration du proxy ...
network: Chargement de la configuration du proxy définie par l'utilisateur ...
network: Terminé.
network: Chargement de la configuration du proxy à partir de Netscape Navigator ...
network: Terminé.
java.lang.NullPointerException
at com.sun.deploy.net.proxy.DynamicProxyManager.reset(Unknown Source)
at sun.plugin.util.PluginConsoleController.reloadProxyConfig(Unknown Source)
at com.sun.deploy.util.ConsoleWindow$5.actionPerformed(Unknown Source)
at javax.swing.JComponent$ActionStandin.actionPerformed(Unknown Source)
at javax.swing.SwingUtilities.notifyAction(Unknown Source)
at javax.swing.JComponent.processKeyBinding(Unknown Source)
at javax.swing.KeyboardManager.fireBinding(Unknown Source)
at javax.swing.KeyboardManager.fireKeyboardAction(Unknown Source)
at javax.swing.JComponent.processKeyBindingsForAllComponents(Unknown Source)
at javax.swing.JComponent.processKeyBindings(Unknown Source)
at javax.swing.JComponent.processKeyEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.KeyboardFocusManager.redispatchEvent(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(Unknown Source)
at java.awt.DefaultKeyboardFocusManager.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Terminé.
si quelqu'un pourrais m'aidé..
et j'espère avoir posté dans la bonne section, c'est mon premier msg... ..
si tel n'est pas le cas, j'en suis désolé..
encore merci pour ceux qui prendront la peine de me lire et de répondre ;)
firefox 2.0.0.12
  1. Re,
    J'ai jamais utilisé Eclipse, je préfèree la ligne de commande, normalement vous aurez "appletviewer.exe" fourni avce le JDK, donc vous le lancez comme la commande "java" qui execute un programme java, et à la fois s'il y a des erreurs vous pourrez les voirs.
    1. Salut,
      Aucune idée, en tout les cas vous êtes dans le bon forum.
      essaie votre applet en utilisant AppletViewer, peut être que le truc ne dépe,d pas seulement de Java.
      1. Arf, j'ai essayé de trouvé comment on lançai se appletviewer en vain..
        suis désolé lol
        me sens noob sur se coup la, mais j'ai bien trouvé l'exécutable mais la petite fenêtre dos se referme aussitôt..
        me doute donc que ce n'est pas par la qu'il se lance..
        si quelqu'un pouvais m'indiquer la marche a suivre..
