Problème avec mon graver. Help!
Voici mon souci lorsque je veux graver avec un DVD virege (DVD-R ou DVD+R), l'operation commence bien et au bout de quelque 2mn il me met echec de l'opération!
ET il ne veux plus lire aucun Films DVD.
Voici le rapport:
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 1999-09-10 12:06
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004-11-02 12:54
Nero Version: 6.6.0.8 (Nero Express)
Recorder: <_NEC DVD+-RW ND-6650A> Version: 1.42 - HA 1 TA 0 - 6.6.0.8
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <_NEC DVD+-RW ND-6650A>Version: 1.42 - HA 1 TA 0 - 6.6.0.8
=== Scsi-Device-Map ===
DiskPeripheral : FUJITSU MHU2100AT atapi Port 0 ID 0 DMA: On
CdRomPeripheral : _NEC DVD+-RW ND-6650A atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
_NEC DVD+-RW ND-6650A D: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1023MB (1047920kB)
Free physical memory: 384MB (393884kB)
Memory in use : 62 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
8.3.2008
Compilation UDF/ISO
16:00 #1 Phase 112 File dlgbrnst.cpp, Line 1832
DVD-Video files reallocation started
16:00 #2 Phase 114 File dlgbrnst.cpp, Line 1832
DVD-Video files reallocation completed (no file modified)
16:00 #3 Text 0 File Isodoc.cpp, Line 6179
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet :FALSE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
16:00 #4 Phase 111 File dlgbrnst.cpp, Line 1832
DVD-Video files sorted
16:00 #5 Text 0 File Reader.cpp, Line 127
Reader running
16:00 #6 Text 0 File Writer.cpp, Line 122
Writer _NEC DVD+-RW ND-6650A running
16:00 #7 ISO9660GEN -11 File geniso.cpp, Line 3293
First writeable address = 0 (0x00000000)
16:00 #8 ISO9660GEN -11 File geniso.cpp, Line 3293
16:00 #9 Text 0 File Burncd.cpp, Line 3153
Turn on Disc-At-Once, using DVD media
16:00 #10 Text 0 File DlgWaitCD.cpp, Line 260
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2080047 (462:13.72, 4062MB)
16:00 #11 Text 0 File DlgWaitCD.cpp, Line 272
Write in overburning mode: NO (enabled: CD)
16:00 #12 Text 0 File DlgWaitCD.cpp, Line 2339
Recorder: _NEC DVD+-RW ND-6650A, Media type: DVD+R
16:00 #13 Text 0 File DlgWaitCD.cpp, Line 438
>>> Protocol of DlgWaitCD activities: <<<
16:00 #14 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2080048 (2080048) = #2080048/462:13.73
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2080048 blocks [_NEC DVD+-RW ND-6650A]
16:00 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [_NEC DVD+-RW ND-6650A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4259938304, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2080048 | lead-out | 1 | 0x41 | 0x00
16:00 #16 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
16:00 #17 Text 0 File Burncd.cpp, Line 4040
Cache writing successful.
16:00 #18 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
16:00 #19 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 6x (8,310 Ko/s)
16:00 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
16:00 #21 SCSI -1066 File Cdrdrv.cpp, Line 1181
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0C1D0600
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x24 0x00
16:00 #22 SCSI -1065 File Cdrdrv.cpp, Line 1181
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03C85600
Sense Code: 0x20
Sense Qual: 0x00
CDB Data: 0xFA 0x10 0x00 0x00 0x00 0x00 0x00 0x00 0x06 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x20 0x00
16:00 #23 SCSI -1065 File Cdrdrv.cpp, Line 1181
Sense Code: 0x20
Sense Qual: 0x00
16:00 #24 Text 0 File DVDPlusRW.cpp, Line 648
Start write address at LBA 0
DVD high compatibility mode: Yes
16:04 #25 SCSI -1135 File Cdrdrv.cpp, Line 1435
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0BA10000
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x04 0x06 0x80 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
16:04 #26 CDR -1135 File Writer.cpp, Line 311
Write error
16:04 #27 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
16:04 #28 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
16:04 #29 SCSI -1135 File Cdrdrv.cpp, Line 1181
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x5B 0x01 0x01 0x00 0x00 0x01 0x00 0x00 0x00 0x00 0x00 0x00
16:04 #30 SCSI -1176 File Cdrdrv.cpp, Line 1181
Sense Code: 0x72
Sense Qual: 0x03
CDB Data: 0x5B 0x01 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x72 0x03
16:04 #31 Phase 127 File dlgbrnst.cpp, Line 1832
Generating DVD high compatibility borders
16:04 #32 Phase 129 File dlgbrnst.cpp, Line 1832
Generating DVD borders completed successfully
16:04 #33 SCSI -1065 File Cdrdrv.cpp, Line 1181
Sense Code: 0x20
Sense Qual: 0x00
16:04 #34 SCSI -1065 File Cdrdrv.cpp, Line 1181
Sense Code: 0x20
Sense Qual: 0x00
16:04 #35 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 6x (8,310 Ko/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 2006-05-19 22:16
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 1999-09-10 12:06
File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 2007-12-11 23:34 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 2004-08-05 13:00 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Je ne sais pas si sa vous parle on tout cas je n'y comprend rien!
Aidez moi SVP...
Voici le rapport:
Windows XP 5.1
IA32
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Use Inquiry : 1
8.3.2008
Compilation UDF/ISO
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet :FALSE
Reader running
DAO infos:
MCN: ""
Tracks 1 to 1:
DAO layout:
Sense Code: 0x24
Sense Qual: 0x00
Sense Code: 0x20
Sense Qual: 0x00
Sense Code: 0x20
Sense Qual: 0x00
Sense Code: 0x0C
Sense Qual: 0x00
Write error
Sense Code: 0x0C
Sense Qual: 0x00
Sense Code: 0x72
Sense Qual: 0x03
Sense Code: 0x20
Sense Qual: 0x00
Sense Code: 0x20
Sense Qual: 0x00
Existing drivers:
Registry Keys:
Aidez moi SVP...
Configuration: Windows XP Firefox 2.0.0.4
MERCI
Le problème c'est que c'est PC portable.
Bonjour, J’ai eu ce soucis aussi, c’était un manque de mémoire. J'espère t'avoir aidé.
@tihihiore,
si ton lecteur n'apparait plus dans ton psote de travail, c'est que Windows ne reconnait plus le périphérique.
Dévisse ton boitier pc et regarde s'il est bien branché ou rebranche le.
En le rallumant, windows devra détecter un nouveau matériel.
nb: si tes dvd n'apparaissent pas dans ton poste de travail, c'est que tu as un problème du périphérique lecteur et non de nero 6
j'essaye de comprendre ton rapport mais je vois 2 choses:
Write error
et Registry Keys:
Pour ne pas te faire faire de bêtises, je te conseille de :
1 verifier si tes dvd sont lus, notamment les vidéos avec vlc par exemple
2 désinstaller nero 6
3 nettoyer ta base de registre et les anciennes clés avec ccleaner
4 de réinstaller nero
cordialement-
@tihihioComment puis-je nettoyer tous ca avec Ccleaner?
