Probleme wlm
je je vouler savoir si on pouver retrouver un mot de passe sur wlm sans le changer?
WLM error code 5102 (connection problem with server) = WLM Database in local computer is crashed.
1> i have vista and xp (C: = Vista, D: = XP)
2> WLM in xp was crashed, it had sown error code 5102
3> i deinstalled WLM and tried enough time on xp platform, but no use
4> then i startet WLM.EXE in VISTA PARTITION ( C:\programme\windows live.........
5> as i expected, it showed me xxx.dll error and some other errors and finaly something about "moving wlm database"
6> i clicked OK for eveything, after some errors its closed automaticly
7> i startet my old WLM ( xp D:\programme\windows live\.....
8> bravooooooo... wlm has alert me " a new database was created / wlm database was moved/changed"
after that wlm reloaded all my mails from the server and it works now perfect.
thx...
christian -
C'est impossible, il faut que tu cliques sur "Mot de Passe oublié".
Mais tu pourras remettre ton ancien mot de passe en cliquant dessus.
