Probleme serveur moddé minecraft
Bonjour, je voudrai faire un serveur moddé minecraft avec mes amis mais le serveur crash avec un message de crash."---- Minecraft Crash Report ----
// Uh... Did I do that?
Time: 2/17/21 2:30 AM
Description: Exception in server tick loop
net.minecraftforge.fml.common.LoaderExceptionModCrash: Caught exception from Notes (notes)
Caused by: java.lang.NoClassDefFoundError: net/minecraft/client/gui/GuiScreen
at com.chaosthedude.notes.Notes.preInit(Notes.java:30)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at net.minecraftforge.fml.common.FMLModContainer.handleModStateEvent(FMLModContainer.java:637)
at sun.reflect.GeneratedMethodAccessor10.invoke(Unknown Source)
at com.google.common.eventbus.Subscriber.invokeSubscriberMethod(Subscriber.java:91)
at com.google.common.eventbus.Subscriber$SynchronizedSubscriber.invokeSubscriberMethod(Subscriber.java:150)
at com.google.common.eventbus.Subscriber$1.run(Subscriber.java:76)
at com.google.common.util.concurrent.MoreExecutors$DirectExecutor.execute(MoreExecutors.java:399)
at com.google.common.eventbus.Subscriber.dispatchEvent(Subscriber.java:71)
at com.google.common.eventbus.Dispatcher$PerThreadQueuedDispatcher.dispatch(Dispatcher.java:116)
at com.google.common.eventbus.EventBus.post(EventBus.java:217)
at net.minecraftforge.fml.common.LoadController.sendEventToModContainer(LoadController.java:219)
at net.minecraftforge.fml.common.LoadController.propogateStateMessage(LoadController.java:197)
at net.minecraftforge.fml.common.LoadController.distributeStateMessage(LoadController.java:136)
at net.minecraftforge.fml.common.Loader.preinitializeMods(Loader.java:629)
at net.minecraftforge.fml.server.FMLServerHandler.beginServerLoading(FMLServerHandler.java:99)
at net.minecraftforge.fml.common.FMLCommonHandler.onServerStart(FMLCommonHandler.java:333)
at net.minecraft.server.dedicated.DedicatedServer.func_71197_b(DedicatedServer.java:125)
at net.minecraft.server.MinecraftServer.run(MinecraftServer.java:486)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.ClassNotFoundException: net.minecraft.client.gui.GuiScreen
at net.minecraft.launchwrapper.LaunchClassLoader.findClass(LaunchClassLoader.java:191)
at java.lang.ClassLoader.loadClass(Unknown Source)
... 36 more
Caused by: net.minecraftforge.fml.common.asm.ASMTransformerWrapper$TransformerException: Exception in class transformer net.minecraftforge.fml.common.asm.transformers.SideTransformer@2d84cb86 from coremod FMLCorePlugin
at net.minecraftforge.fml.common.asm.ASMTransformerWrapper$TransformerWrapper.transform(ASMTransformerWrapper.java:260)
at net.minecraft.launchwrapper.LaunchClassLoader.runTransformers(LaunchClassLoader.java:279)
at net.minecraft.launchwrapper.LaunchClassLoader.findClass(LaunchClassLoader.java:176)
... 38 more
Caused by: java.lang.RuntimeException: Attempted to load class blk for invalid side SERVER
at net.minecraftforge.fml.common.asm.transformers.SideTransformer.transform(SideTransformer.java:62)
at net.minecraftforge.fml.common.asm.ASMTransformerWrapper$TransformerWrapper.transform(ASMTransformerWrapper.java:256)
... 40 more
A detailed walkthrough of the error, its code path and all known details is as follows:
-- System Details --
Details:
Minecraft Version: 1.12.2
Operating System: Windows 10 (amd64) version 10.0
Java Version: 1.8.0_281, Oracle Corporation
Java VM Version: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
Memory: 1117464776 bytes (1065 MB) / 2387607552 bytes (2277 MB) up to 5726797824 bytes (5461 MB)
JVM Flags: 2 total; -Xms512M -Xmx6144M
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
FML: MCP 9.42 Powered by Forge 14.23.5.2854 76 mods loaded, 76 mods active
States: 'U' = Unloaded 'L' = Loaded 'C' = Constructed 'H' = Pre-initialized 'I' = Initialized 'J' = Post-initialized 'A' = Available 'D' = Disabled 'E' = Errored
| State | ID | Version | Source | Signature |
| LCH | minecraft | 1.12.2 | minecraft.jar | None |
| LCH | mcp | 9.42 | minecraft.jar | None |
| LCH | FML | 8.0.99.99 | forge.jar | e3c3d50c7c986df74c645c0ac54639741c90a557 |
| LCH | forge | 14.23.5.2854 | forge.jar | e3c3d50c7c986df74c645c0ac54639741c90a557 |
| LCH | actuallyadditions | 1.12.2-r149 | ActuallyAdditions-1.12.2-r151-2.jar | None |
| LCH | aether_legacy | 1.4.4 | aether_legacy-1.12.2-v1.4.4.jar | None |
| LCH | jei | 4.15.0.283 | jei_1.12.2-4.15.0.283.jar | None |
| LCH | appleskin | 1.0.9 | AppleSkin-mc1.12-1.0.9.jar | None |
| LCH | appliedenergistics2 | rv6-stable-7 | Applied-Energistics-2-Mod-1.12.2.jar | dfa4d3ac143316c6f32aa1a1beda1e34d42132e5 |
| LCH | baubles | 1.5.2 | Baubles-1.12-1.5.2.jar | None |
| LCH | biomesoplenty | 7.0.1.2441 | BiomesOPlenty-1.12.2-7.0.1.2441-universal.jar | None |
| LCH | bookshelf | 2.3.590 | Bookshelf-1.12.2-2.3.590.jar | d476d1b22b218a10d845928d1665d45fce301b27 |
| LCH | botania | r1.10-363 | Botania-Mod-1.12.2.jar | None |
| LCH | codechickenlib | 3.2.0.345 | CodeChickenLib-1.12.2-3.2.0.345-universal.jar | f1850c39b2516232a2108a7bd84d1cb5df93b261 |
| LCH | redstoneflux | 2.1.1 | RedstoneFlux-1.12-2.1.1.1-universal.jar | None |
| LCH | brandonscore | 2.4.12 | BrandonsCore-1.12.2-2.4.12.205-universal.jar | None |
| LCH | buildcraftlib | 7.99.24.2 | buildcraft-all-7.99.24.2.jar | None |
| LCH | buildcraftcore | 7.99.24.2 | buildcraft-all-7.99.24.2.jar | None |
| LCH | buildcraftbuilders | 7.99.24.2 | buildcraft-all-7.99.24.2.jar | None |
| LCH | buildcrafttransport | 7.99.24.2 | buildcraft-all-7.99.24.2.jar | None |
| LCH | buildcraftsilicon | 7.99.24.2 | buildcraft-all-7.99.24.2.jar | None |
| LCH | buildcraftcompat | 7.99.24.2 | buildcraft-all-7.99.24.2.jar | None |
| LCH | buildcraftenergy | 7.99.24.2 | buildcraft-all-7.99.24.2.jar | None |
| LCH | buildcraftfactory | 7.99.24.2 | buildcraft-all-7.99.24.2.jar | None |
| LCH | buildcraftrobotics | 7.99.24.2 | buildcraft-all-7.99.24.2.jar | None |
| LCH | campfire | 1.2 | campfire-1.12-v1.2.jar | None |
| LCH | carryon | 1.7 | CarryOn+MC1.12+v1.7.jar | None |
| LCH | chameleon | 1.12-4.1.3 | Chameleon-1.12-4.1.3.jar | None |
| LCH | cofhcore | 4.6.6 | CoFHCore-1.12.2.jar | None |
| LCH | cofhworld | 1.2.0 | CoFHWorld-1.12.2-1.2.0.5-universal.jar | 8a6abf2cb9e141b866580d369ba6548732eff25f |
| LCH | compactmachines3 | 3.0.18 | Compact-Machines-Mod-1.12.2.jar | None |
| LCH | computercraft | 1.80pr1 | ComputerCraft-Mod-1.12.2.jar | None |
| LCH | cookingforblockheads | 6.4.71 | CookingForBlockheads_1.12.2-6.4.71.jar | None |
| LCH | cucumber | 1.1.3 | Cucumber-Mod-1.12.2.jar | None |
| LCH | waila | 1.8.26 | Hwyla-1.8.26-B41_1.12.2.jar | None |
| LCH | darkutils | 1.8.230 | DarkUtils-1.12.2-1.8.230.jar | d476d1b22b218a10d845928d1665d45fce301b27 |
| LCH | props | 2.6.2 | Decocraft-1.12.2.jar | None |
| LCH | thermalfoundation | 2.6.7 | ThermalFoundation-1.12.2-2.6.7.1-universal.jar | None |
| LCH | draconicevolution | 2.3.24 | Draconic-Evolution-1.12.2-2.3.24.349-universal.jar | None |
| LCH | enhancedarmaments | 1.3.15 | EnhancedArmaments-1.3.15.jar | None |
| LCH | extrautils2 | 1.0 | extrautils2-1.12-1.7.4.jar | None |
| LCH | fairylights | 2.1.1 | fairylights-2.1.1-1.12.jar | None |
| LCH | fastfurnace | 1.3.1 | FastFurnace-1.12.2-1.3.1.jar | None |
| LCH | flying_things | 1.5.1 | flying_things-1.5.1-1.12.jar | None |
| LCH | fp | 26.3.488 | Futurepack-1.12.jar | 3ad693059337b95c41b649ec9f29c4a6e8282586 |
| LCH | fp.api | 1.1.0 | Futurepack-1.12.jar | None |
| LCH | hopperducts | 1.5 | Hopper-Ducts-Mod-1.12.2.jar | None |
| LCH | ic2 | 2.8.221-ex112 | Industrial-Craft-2-Mod-Experimental-1.12.2.jar | de041f9f6187debbc77034a344134053277aa3b0 |
| LCH | ironchest | 1.12.2-7.0.67.844 | ironchest-1.12.2-7.0.69.845.jar | None |
| LCH | journeymap | 1.12.2-5.7.1 | journeymap-1.12.2-5.7.1.jar | None |
| LCH | mcwdoors | 1.0 | Macaws-Doors-Mod-1.12.2.jar | None |
| LCH | mcwbridges | 1.0 | mcw-bridges-1.0.3-mc1.12.2.jar | None |
| LCH | megaloot | 0.1.4 | megaloot-1.12.2-0.1.4.jar | None |
| LCH | mysticalagriculture | 1.7.5 | Mystical-Agriculture-Mod-1.12.2.jar | None |
| LCE | notes | 1.1.1 | Notes-1.12-1.1.1.jar | None |
| LC | nuclearcraft | 2.15a | NuclearCraft-Mod-1.12.2.jar | None |
| LC | oreexcavation | 1.4.137 | OreExcavation-1.4.137.jar | None |
| LC | railcraft | 12.0.0 | railcraft-12.0.0.jar | a0c255ac501b2749537d5824bb0f0588bf0320fa |
| LC | roguelike | 1.8.0 | Roguelike-Dungeons-Mod-1.12.2.jar | None |
| LC | silentlib | 3.0.13 | Silent-Lib-1.12.2.jar | None |
| LC | scalinghealth | 1.3.37 | Scaling-Health-Mod-1.12.2.jar | None |
| LC | spartanshields | 1.3a | SpartanShields-1.12-1.3a.jar | None |
| LC | spartanweaponry | beta 1.3.8 | SpartanWeaponry-1.12.2-beta-1.3.8.jar | None |
| LC | storagedrawers | 1.12-5.2.5 | StorageDrawers-1.12.1-5.3.3.jar | None |
| LC | switchbow | 1.5 | switchbow-1.5-1.12.2.jar | None |
| LC | thermalexpansion | 5.5.4 | Thermal-Expansion-Mod-1.12.2.jar | 8a6abf2cb9e141b866580d369ba6548732eff25f |
| LC | thermalsolars | 1.12.2 V1.9.5 | Thermal-Solars-Mod-1.12.2.jar | None |
| LC | twilightforest | 3.10.1013 | twilightforest-1.12.2-3.10.1013-universal.jar | None |
| LC | uteamcore | 2.2.5.147 | u_team_core-1.12.2-2.2.5.147.jar | None |
| LC | uncraftingtable | 1.8-beta6 | Uncrafting-Table-Mod-1.12.2.jar | None |
| LC | usefulbackpacks | 1.5.3.59 | Useful-Backpacks-Mod-1.12.2.jar | None |
| LC | vc | 5.9.13 | ViesCraft-1.12.2-5.9.13.jar | None |
| LC | wawla | 2.6.275 | Wawla-1.12.2-2.6.275.jar | d476d1b22b218a10d845928d1665d45fce301b27 |
| LC | woot | 1.12.2-1.4.11 | woot-1.12.2-1.4.11.jar | None |
| LC | zeiyocraft | 0.8.4 | ZeiyoCraft-Mod-1.12.2.jar | None |
| LC | mbm | 1.9.0.3 | Master-Builders-Mod-1.12.jar | None |
Loaded coremods (and transformers):
AE2 Version: stable rv6-stable-7 for Forge 14.23.5.2768
Profiler Position: N/A (disabled)
Is Modded: Definitely; Server brand changed to 'fml,forge'
Type: Dedicated Server (map_server.txt)"
Du coup voila si vous pouvez m'aider merci.
  1. Merci ça fonctionne, c'était effectivement le mode notes, merci pour votre retour bonne journée.
    1. Bonjour, le serveur ne parvient pas à construire le mod Notes (Notes-1.12-1.1.1.jar), ce qui est normal étant donné que c'est un mod côté client et non côté serveur, donc supprimez-le de votre serveur.
