Comment je peux faire une interface graphique pour ce code sur python
import numpy as np
import networkx as nx
import matplotlib.pyplot as plt
class PL:
def __init__(self, A = np.empty([0,0]), b = np.empty([0,0]), c = np.empty([0,0]), minmax = "MAX"):
self.A = A
self.b = b
self.c = c
self.x = [float(0)] * len(c)
self.minmax = minmax
self.printIter = False
self.optimalValue = None
self.transform = False
def addA(self, A):
self.A = A
def addB(self, b):
self.b = b
def addC(self, c):
self.c = c
def setObj(self, minmax):
if(minmax == "MIN" or minmax == "MAX"):
else:
print("Objectif invalide.")
def setPrintIter(self, printIter):
self.printIter = printIter
def printSoln(self):
print("La solution optimal du PL:\n\n X* =", end=" ",sep="")
print(self.x)
print("\n")
print("La cardinalité du transversal minimum :\n\n Z* = ", end=" ",sep="")
print(int(self.optimalValue))
print("\n")
def printTableau(self, tableau):
print("ind \t\t", end = "")
for j in range(0, len(c)):
print("x_" + str(j), end = "\t")
for j in range(0, (len(tableau[0]) - len(c) - 2)):
print("s_" + str(j), end = "\t")
print()
for j in range(0, len(tableau)):
for i in range(0, len(tableau[0])):
if(not np.isnan(tableau[j, i])):
if(i == 0):
print(int(tableau[j, i]), end = "\t")
else:
print(round(tableau[j, i], 2), end = "\t")
else:
print(end = "\t")
print()
def getTableau(self):
# construct starting tableau
if(self.minmax == "MIN" and self.transform == False):
self.c[0:len(c)] = 1 * self.c[0:len(c)]
t1 = np.array([None, 0])
numVar = len(self.c)
numSlack = len(self.A)
t1 = np.hstack(([None], [0], self.c, [0] * numSlack))
basis = np.array([0] * numSlack)
for i in range(0, len(basis)):
basis[i] = numVar + i
A = self.A
if(not ((numSlack + numVar) == len(self.A[0]))):
B = np.identity(numSlack)
A = np.hstack((self.A, B))
t2 = np.hstack((np.transpose([basis]), np.transpose([self.b]), A))
tableau = np.vstack((t1, t2))
tableau = np.array(tableau, dtype ='float')
return tableau
def optimize(self):
for i in range(len(self.c)):
self.c[i] = -1 * self.c[i]
transform = False
tableau = self.getTableau()
if(self.printIter == True):
print("Tableau de départ:")
self.printTableau(tableau)
# assume initial basis is not optimal
optimal = False
# keep track of iterations for display
iter = 1
while(True):
print("----------------------------------")
print("Itération :", iter)
if(self.minmax == "MAX"):
for profit in tableau[0, 2:]:
if profit > 0:
optimal = False
break
optimal = True
else:
for cost in tableau[0, 2:]:
if cost < 0:
optimal = False
break
optimal = True
# if all directions result in decreased profit or increased cost
if optimal == True:
break
# nth variable enters basis, account for tableau indexing
if (self.minmax == "MAX"):
n = tableau[0, 2:].tolist().index(np.amax(tableau[0, 2:])) + 2
else:
n = tableau[0, 2:].tolist().index(np.amin(tableau[0, 2:])) + 2
# minimum ratio test, rth variable leaves basis
minimum = 99999
r = -1
for i in range(1, len(tableau)):
if(tableau[i, n] > 0):
val = tableau[i, 1]/tableau[i, n]
if val<minimum:
minimum = val
r = i
pivot = tableau[r, n]
# perform row operations
# divide the pivot row with the pivot element
tableau[r, 1:] = tableau[r, 1:] / pivot
# pivot other rows
for i in range(0, len(tableau)):
if i != r:
mult = tableau[i, n] / tableau[r, n]
tableau[i, 1:] = tableau[i, 1:] - mult * tableau[r, 1:]
# new basic variable
tableau[r, 0] = n - 2
iter += 1
print("Le tableau final parvenu en", iter, "itérations")
else:
print('\n\n' + '\033[32m' + ' >>> Résolu! <<<' + '\x1b[0m')
self.x = np.array([0] * len(c), dtype = int)
# save coefficients
for key in range(1, (len(tableau))):
if(tableau[key, 0] < len(c)):
self.x[int(tableau[key, 0])] = tableau[key, 1]
for i in range(0,len(self.x)):
if(self.x[i]==0):
self.x[i]=1
else:
self.x[i]=0
self.optimalValue = len(c) - 1 * tableau[0,1]
a = 0
class b():
global a
a = self.x
model = PL()
A = np.array([ [1,0,1,0],[1,1,0,0],[0,1,0,1],[0,0,1,1] ])
B = A.transpose()
n = len(B)
m = len(B[1])
b=np.ones(n,dtype=int)
c=np.ones(m,dtype=int)
model.addA(B)
model.addB(b)
model.addC(c)
model.setObj("MIN")
C = np.zeros([m,m], dtype = int)
for i in range(0,n):
h =-1
k =-1
for j in range(0,m):
if(B[i][j]==1):
if(h==-1):
h=j
else:
k=j
C[h][k]=1
C[k][h]=1
print("La matrice d'incidence :\n\nM1 =\n", A, "\n")
print("La matrice d'adjacence :\n\nM2 =\n", C, "\n")
print("Le graphe correspondant :\n\nG >>\n")
G=nx.from_numpy_matrix(C)
nx.draw(G,with_labels=1,node_color='c',font_size=12)
plt.show()
print("Le PL correspondant:\n\n(P) >>\n")
objf = "( Min(Z) = "
for i in range(0,m):
objf += "X" + str(i) + " + "
d = len(objf)
y = slice(d-2)
objf = objf[y]
print(objf)
print("|")
st = "| "
if(B[i][j]==1):
st += "X" + str(j) + " + "
x = slice(10)
st = st[x]
st += " >= 1"
print(st)
print("|")
print("( xᵢ >= 0, ∀ i ∈ {0,...," + str(m-1) + "}")
model.optimize()
print("\n")
model.printSoln()
print("Le transversal minimum est:\n\n T* = ", end=" ",sep="")
v = len(a)
Tm = "{"
for i in range(0,v):
if(a[i]==1):
Tm += "X" + str(i) + ", "
p = len(Tm)
z = slice(p-2)
Tm = Tm[z]
Tm += "}"
print(Tm)
class PL:
self.A = A
self.b = b
self.c = c
def addA(self, A):
self.A = A
def addB(self, b):
self.b = b
def addC(self, c):
self.c = c
else:
print(self.x)
print("\n")
print("\n")
print()
if(i == 0):
else:
else:
print(end = "\t")
print()
A = self.A
return tableau
def optimize(self):
transform = False
optimal = False
iter = 1
while(True):
if profit > 0:
optimal = False
break
optimal = True
else:
if cost < 0:
optimal = False
break
optimal = True
if optimal == True:
break
else:
minimum = 99999
r = -1
if val<minimum:
minimum = val
r = i
# pivot other rows
if i != r:
iter += 1
else:
# save coefficients
if(self.x[i]==0):
self.x[i]=1
else:
self.x[i]=0
a = 0
class b():
global a
a = self.x
model = PL()
B = A.transpose()
n = len(B)
m = len(B[1])
model.addA(B)
model.addB(b)
model.addC(c)
model.setObj("MIN")
h =-1
k =-1
if(B[i][j]==1):
if(h==-1):
h=j
else:
k=j
C[h][k]=1
C[k][h]=1
plt.show()
d = len(objf)
y = slice(d-2)
objf = objf[y]
print(objf)
print("|")
st = "| "
if(B[i][j]==1):
x = slice(10)
st = st[x]
st += " >= 1"
print(st)
print("|")
model.optimize()
print("\n")
model.printSoln()
v = len(a)
Tm = "{"
if(a[i]==1):
p = len(Tm)
z = slice(p-2)
Tm = Tm[z]
Tm += "}"
print(Tm)
Ah oui, tu as raison Arthur, il y a ça aussi :
https://www.commentcamarche.net/infos/25899-demander-de-l-aide-pour-vos-exercices-sur-ccm/
import bonjour
import s'il vous plaît
import merci
Bonjour wahida98,
Les indentations étant importantes en Python, pourrais-tu reposter ton code en utilisant les balises de code ?
Mode d'emploi:
https://codes-sources.commentcamarche.net/faq/11288-les-balises-de-code
On y verrait plus clair ...-
import numpy as np import networkx as nx import matplotlib.pyplot as plt class PL: def __init__(self, A = np.empty([0,0]), b = np.empty([0,0]), c = np.empty([0,0]), minmax = "MAX"): self.A = A self.b = b self.c = c self.x = [float(0)] * len(c) self.minmax = minmax self.printIter = False self.optimalValue = None self.transform = False def addA(self, A): self.A = A def addB(self, b): self.b = b def addC(self, c): self.c = c self.transform = False def setObj(self, minmax): if(minmax == "MIN" or minmax == "MAX"): self.minmax = minmax else: print("Objectif invalide.") self.transform = False def setPrintIter(self, printIter): self.printIter = printIter def printSoln(self): print("La solution optimal du PL:\n\n X* =", end=" ",sep="") print(self.x) print("\n") print("La cardinalité du transversal minimum :\n\n Z* = ", end=" ",sep="") print(int(self.optimalValue)) print("\n") def printTableau(self, tableau): print("ind \t\t", end = "") for j in range(0, len(c)): print("x_" + str(j), end = "\t") for j in range(0, (len(tableau[0]) - len(c) - 2)): print("s_" + str(j), end = "\t") print() for j in range(0, len(tableau)): for i in range(0, len(tableau[0])): if(not np.isnan(tableau[j, i])): if(i == 0): print(int(tableau[j, i]), end = "\t") else: print(round(tableau[j, i], 2), end = "\t") else: print(end = "\t") print() def getTableau(self): # construct starting tableau if(self.minmax == "MIN" and self.transform == False): self.c[0:len(c)] = 1 * self.c[0:len(c)] self.transform = False t1 = np.array([None, 0]) numVar = len(self.c) numSlack = len(self.A) t1 = np.hstack(([None], [0], self.c, [0] * numSlack)) basis = np.array([0] * numSlack) for i in range(0, len(basis)): basis[i] = numVar + i A = self.A if(not ((numSlack + numVar) == len(self.A[0]))): B = np.identity(numSlack) A = np.hstack((self.A, B)) t2 = np.hstack((np.transpose([basis]), np.transpose([self.b]), A)) tableau = np.vstack((t1, t2)) tableau = np.array(tableau, dtype ='float') return tableau def optimize(self): if(self.minmax == "MIN" and self.transform == False): for i in range(len(self.c)): self.c[i] = -1 * self.c[i] transform = False tableau = self.getTableau() if(self.printIter == True): print("Tableau de départ:") self.printTableau(tableau) # assume initial basis is not optimal optimal = False # keep track of iterations for display iter = 1 while(True): if(self.printIter == True): print("----------------------------------") print("Itération :", iter) self.printTableau(tableau) if(self.minmax == "MAX"): for profit in tableau[0, 2:]: if profit > 0: optimal = False break optimal = True else: for cost in tableau[0, 2:]: if cost < 0: optimal = False break optimal = True # if all directions result in decreased profit or increased cost if optimal == True: break # nth variable enters basis, account for tableau indexing if (self.minmax == "MAX"): n = tableau[0, 2:].tolist().index(np.amax(tableau[0, 2:])) + 2 else: n = tableau[0, 2:].tolist().index(np.amin(tableau[0, 2:])) + 2 # minimum ratio test, rth variable leaves basis minimum = 99999 r = -1 for i in range(1, len(tableau)): if(tableau[i, n] > 0): val = tableau[i, 1]/tableau[i, n] if val<minimum: minimum = val r = i pivot = tableau[r, n] # perform row operations # divide the pivot row with the pivot element tableau[r, 1:] = tableau[r, 1:] / pivot # pivot other rows for i in range(0, len(tableau)): if i != r: mult = tableau[i, n] / tableau[r, n] tableau[i, 1:] = tableau[i, 1:] - mult * tableau[r, 1:] # new basic variable tableau[r, 0] = n - 2 iter += 1 if(self.printIter == True): print("----------------------------------") print("Le tableau final parvenu en", iter, "itérations") self.printTableau(tableau) else: print('\n\n' + '\033[32m' + ' >>> Résolu! <<<' + '\x1b[0m') self.x = np.array([0] * len(c), dtype = int) # save coefficients for key in range(1, (len(tableau))): if(tableau[key, 0] < len(c)): self.x[int(tableau[key, 0])] = tableau[key, 1] for i in range(0,len(self.x)): if(self.x[i]==0): self.x[i]=1 else: self.x[i]=0 self.optimalValue = len(c) - 1 * tableau[0,1] a = 0 class b(): global a a = self.x model = PL() A = np.array([ [1,0,1,0],[1,1,0,0],[0,1,0,1],[0,0,1,1] ]) B = A.transpose() n = len(B) m = len(B[1]) b=np.ones(n,dtype=int) c=np.ones(m,dtype=int) model.addA(B) model.addB(b) model.addC(c) model.setObj("MIN") C = np.zeros([m,m], dtype = int) for i in range(0,n): h =-1 k =-1 for j in range(0,m): if(B[i][j]==1): if(h==-1): h=j else: k=j C[h][k]=1 C[k][h]=1 print("La matrice d'incidence :\n\nM1 =\n", A, "\n") print("La matrice d'adjacence :\n\nM2 =\n", C, "\n") print("Le graphe correspondant :\n\nG >>\n") G=nx.from_numpy_matrix(C) nx.draw(G,with_labels=1,node_color='c',font_size=12) plt.show() print("Le PL correspondant:\n\n(P) >>\n") objf = "( Min(Z) = " for i in range(0,m): objf += "X" + str(i) + " + " d = len(objf) y = slice(d-2) objf = objf[y] print(objf) print("|") for i in range(0,n): st = "| " for j in range(0,m): if(B[i][j]==1): st += "X" + str(j) + " + " x = slice(10) st = st[x] st += " >= 1" print(st) print("|") print("( xᵢ >= 0, ∀ i ∈ {0,...," + str(m-1) + "}") model.optimize() print("\n") model.printSoln() print("Le transversal minimum est:\n\n T* = ", end=" ",sep="") v = len(a) Tm = "{" for i in range(0,v): if(a[i]==1): Tm += "X" + str(i) + ", " p = len(Tm) z = slice(p-2) Tm = Tm[z] Tm += "}" print(Tm)
