Problème d'éxcution
svp quand je clique sur Run , l'émulateur m'affiche c'ette erreur :
Installation failed with message Failed to finalize session : INSTALL_FAILED_SHARED_USER_INCOMPATIBLE: Package couldn't be installed in /data/app/com.android.smi.test-1: Package com.android.smi.test has no signatures that match those in shared user android.uid.shared; ignoring!.
It is possible that this issue is resolved by uninstalling an existing version of the apk if it is present, and then re-installing.
qu'est ce que je dois faire pour résoudre ce problème ? et merci
