Problème crash Minecraft/Java
Depuis plus d'une semaine mon minecraft ne fait que crash sans cesse j'ai tenté plein de solutions: Réinstaller Java, réinstaller Minecraft, suprimer le .minecraft ext... Rien ne marche le crash report est
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000018002e336, pid=9756, tid=10732
# JRE version: Java(TM) SE Runtime Environment (8.0_25-b18) (build 1.8.0_25-b18)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.25-b02 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [LavasoftTcpService64.dll+0x2e336]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x000000001aeda000): JavaThread "HttpPipelineSender" daemon [_thread_in_native, id=10732, stack(0x0000000042510000,0x0000000042610000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x0000000000000000
Registers:
RAX=0x0000000000000000, RBX=0x0000000180046710, RCX=0x0000000000000000, RDX=0x0000000180046710
RSP=0x000000004260e340, RBP=0x000000004260e3c9, RSI=0x000000004843ae80, RDI=0x0000000000000048
R8 =0x0000000000000000, R9 =0x00000000ffffffff, R10=0x0000000000000fff, R11=0x0000000000000ff0
R12=0x000000004260e7d0, R13=0x000000000000155c, R14=0x0000000000000128, R15=0x000000004843ae80
RIP=0x000000018002e336, EFLAGS=0x0000000000010283
Top of Stack: (sp=0x000000004260e340)
0x000000004260e340: 000000004843ae80 0000000000000000
0x000000004260e350: 0000000000000000 0000000180005cfe
0x000000004260e360: 000000004260e978 000000004260e3c9
0x000000004260e370: 000000004843ae80 009300240006000c
0x000000004260e380: 36333a36303a3200 fffffffffffffffe
0x000000004260e390: 3f5adaf4001c0003 0000000000463a90
0x000000004260e3a0: 000000007fff07a8 00000000029c7a01
0x000000004260e3b0: 000000004260e410 00000000029c7a01
0x000000004260e3c0: ffffffffffffffff 000000004843ae80
0x000000004260e3d0: 000000000000155c 000000004260e7d0
0x000000004260e3e0: 0000000000001000 0000000000001000
0x000000004260e3f0: 000046f2f0beb4fd 0000000180030a03
0x000000004260e400: 0000000000000001 0000000000000128
0x000000004260e410: 000000000000155c 000000004260e7d0
0x000000004260e420: 00000000ffffffff 0000000180006c7c
0x000000004260e430: 000000004260e977 000000004260e978
Instructions: (pc=0x000000018002e336)
0x000000018002e316: c2 66 0f 3a 20 c0 0f 84 d2 74 05 48 ff c1 8a 11
0x000000018002e326: 49 ff c9 75 e4 49 8b c0 49 23 c2 49 3b c3 77 5a
0x000000018002e336: f3 41 0f 6f 08 66 0f 3a 63 c1 0c 76 06 49 83 c0
0x000000018002e346: 10 eb e2 73 6d 66 0f 3a 63 c1 0c 48 63 c1 4c 03
Register to memory mapping:
RAX=0x0000000000000000 is an unknown value
RBX=0x0000000180046710 is an unknown value
RCX=0x0000000000000000 is an unknown value
RDX=0x0000000180046710 is an unknown value
RSP=0x000000004260e340 is pointing into the stack for thread: 0x000000001aeda000
RBP=0x000000004260e3c9 is pointing into the stack for thread: 0x000000001aeda000
RSI=0x000000004843ae80 is an unknown value
RDI=0x0000000000000048 is an unknown value
R8 =0x0000000000000000 is an unknown value
R9 =0x00000000ffffffff is an unallocated location in the heap
R10=0x0000000000000fff is an unknown value
R11=0x0000000000000ff0 is an unknown value
R12=0x000000004260e7d0 is pointing into the stack for thread: 0x000000001aeda000
R13=0x000000000000155c is an unknown value
R14=0x0000000000000128 is an unknown value
R15=0x000000004843ae80 is an unknown value
Stack: [0x0000000042510000,0x0000000042610000], sp=0x000000004260e340, free space=1016k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [LavasoftTcpService64.dll+0x5cfe]
C [LavasoftTcpService64.dll+0x6c7c]
C [LavasoftTcpService64.dll+0x6b11]
C [LavasoftTcpService64.dll+0x1acce]
C [WS2_32.dll+0x7e4c]
C [WS2_32.dll+0x7d9e]
C [net.dll+0x758b]
C 0x00000000029d5b54
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j java.net.SocketOutputStream.socketWrite0(Ljava/io/FileDescriptor;[BII)V+0
j java.net.SocketOutputStream.socketWrite([BII)V+44
j java.net.SocketOutputStream.write([BII)V+4
J 4804 C1 java.io.BufferedOutputStream.flush()V (12 bytes) @ 0x0000000002d6060c [0x0000000002d604c0+0x14c]
j HttpPipelineConnection.getNextRequestSend()LHttpPipelineRequest;+23
j HttpPipelineSender.run()V+16
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x000000001aedc000 JavaThread "HttpPipelineReceiver" daemon [_thread_in_native, id=3048, stack(0x0000000042f10000,0x0000000043010000)]
=>0x000000001aeda000 JavaThread "HttpPipelineSender" daemon [_thread_in_native, id=10732, stack(0x0000000042510000,0x0000000042610000)]
0x000000001aede800 JavaThread "Thread-37" [_thread_blocked, id=1272, stack(0x0000000042380000,0x0000000042480000)]
0x000000001aed8800 JavaThread "Texture Downloader #25" daemon [_thread_blocked, id=5160, stack(0x0000000042250000,0x0000000042350000)]
0x000000001aedd000 JavaThread "Keep-Alive-Timer" daemon [_thread_blocked, id=12088, stack(0x0000000043390000,0x0000000043490000)]
0x000000001aed9000 JavaThread "Netty Client IO #6" daemon [_thread_in_native, id=10908, stack(0x0000000042970000,0x0000000042a70000)]
0x000000001aeef000 JavaThread "Netty Client IO #5" daemon [_thread_in_native, id=11388, stack(0x0000000041c60000,0x0000000041d60000)]
0x000000001aeee800 JavaThread "Netty Client IO #3" daemon [_thread_in_native, id=7968, stack(0x0000000027200000,0x0000000027300000)]
0x000000001aeed800 JavaThread "Netty Client IO #4" daemon [_thread_in_native, id=4180, stack(0x0000000026160000,0x0000000026260000)]
0x000000001aeed000 JavaThread "Netty Client IO #0" daemon [_thread_in_native, id=7568, stack(0x00000000270b0000,0x00000000271b0000)]
0x000000001aeec000 JavaThread "Netty Client IO #2" daemon [_thread_in_native, id=10784, stack(0x0000000026e40000,0x0000000026f40000)]
0x000000001aeeb800 JavaThread "Netty Client IO #1" daemon [_thread_in_native, id=3188, stack(0x0000000025e60000,0x0000000025f60000)]
0x000000001aeea000 JavaThread "Server Pinger #4" daemon [_thread_blocked, id=11044, stack(0x0000000026b70000,0x0000000026c70000)]
0x000000001aee9000 JavaThread "Server Pinger #3" daemon [_thread_blocked, id=7832, stack(0x0000000022d90000,0x0000000022e90000)]
0x000000001aee8800 JavaThread "Server Pinger #2" daemon [_thread_blocked, id=4200, stack(0x000000001fc00000,0x000000001fd00000)]
0x0000000034cc9000 JavaThread "Server Pinger #1" daemon [_thread_blocked, id=9528, stack(0x0000000026000000,0x0000000026100000)]
0x0000000034ccd800 JavaThread "Thread-24" daemon [_thread_in_native, id=8648, stack(0x0000000041890000,0x0000000041990000)]
0x0000000034ccd000 JavaThread "Server Pinger #0" daemon [_thread_blocked, id=7764, stack(0x0000000041760000,0x0000000041860000)]
0x0000000034ccc000 JavaThread "Thread-23" [_thread_blocked, id=11452, stack(0x000000003f510000,0x000000003f610000)]
0x0000000034cc8800 JavaThread "Thread-22" [_thread_blocked, id=12056, stack(0x0000000029cd0000,0x0000000029dd0000)]
0x0000000034cc7000 JavaThread "pool-2-thread-2" [_thread_blocked, id=11348, stack(0x0000000021470000,0x0000000021570000)]
0x0000000018d63000 JavaThread "LWJGL Timer" daemon [_thread_blocked, id=10988, stack(0x00000000238e0000,0x00000000239e0000)]
0x000000001ae9a800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=10252, stack(0x000000001fb00000,0x000000001fc00000)]
0x00000000192bc800 JavaThread "Timer hack thread" daemon [_thread_blocked, id=10748, stack(0x000000001a900000,0x000000001aa00000)]
0x0000000018bf3800 JavaThread "Snooper Timer" daemon [_thread_blocked, id=10944, stack(0x000000001d200000,0x000000001d300000)]
0x0000000016e55800 JavaThread "Service Thread" daemon [_thread_blocked, id=9468, stack(0x0000000017ba0000,0x0000000017ca0000)]
0x00000000169cf000 JavaThread "C1 CompilerThread2" daemon [_thread_blocked, id=6624, stack(0x0000000017aa0000,0x0000000017ba0000)]
0x00000000169c6000 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=10456, stack(0x00000000178d0000,0x00000000179d0000)]
0x0000000016dd7800 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=1404, stack(0x0000000017680000,0x0000000017780000)]
0x0000000016dd6000 JavaThread "Attach Listener" daemon [_thread_blocked, id=10440, stack(0x0000000017560000,0x0000000017660000)]
0x0000000016dd4800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=5448, stack(0x0000000017220000,0x0000000017320000)]
0x00000000169c4000 JavaThread "Surrogate Locker Thread (Concurrent GC)" daemon [_thread_blocked, id=9700, stack(0x0000000017390000,0x0000000017490000)]
0x0000000016962800 JavaThread "Finalizer" daemon [_thread_blocked, id=4956, stack(0x0000000016cd0000,0x0000000016dd0000)]
0x000000001695b000 JavaThread "Reference Handler" daemon [_thread_blocked, id=10984, stack(0x0000000016ab0000,0x0000000016bb0000)]
0x000000000229a800 JavaThread "Client thread" [_thread_in_Java, id=2292, stack(0x0000000002400000,0x0000000002500000)]
Other Threads:
0x0000000016953000 VMThread [stack: 0x0000000015d90000,0x0000000015e90000] [id=9460]
0x0000000016e58800 WatcherThread [stack: 0x0000000017d20000,0x0000000017e20000] [id=10180]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap:
par new generation total 118016K, used 18429K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
eden space 104960K, 14% used [0x00000000c0000000, 0x00000000c0efa2e0, 0x00000000c6680000)
from space 13056K, 23% used [0x00000000c6680000, 0x00000000c6985128, 0x00000000c7340000)
to space 13056K, 0% used [0x00000000c7340000, 0x00000000c7340000, 0x00000000c8000000)
concurrent mark-sweep generation total 867020K, used 448142K [0x00000000c8000000, 0x00000000fceb3000, 0x0000000100000000)
Metaspace used 44705K, capacity 45195K, committed 45440K, reserved 1089536K
class space used 5121K, capacity 5241K, committed 5248K, reserved 1048576K
Card table byte_map: [0x0000000012320000,0x0000000012530000] byte_map_base: 0x0000000011d20000
Marking Bits: (CMSBitMap*) 0x00000000022f5028
Bits: [0x0000000012b40000, 0x0000000013940000)
Mod Union Table: (CMSBitMap*) 0x00000000022f50e8
Bits: [0x0000000000410000, 0x0000000000448000)
Polling page: 0x00000000003e0000
CodeCache: size=245760Kb used=33017Kb max_used=35146Kb free=212742Kb
bounds [0x00000000029c0000, 0x0000000004c60000, 0x00000000119c0000]
total_blobs=8564 nmethods=7709 adapters=765
compilation: enabled
Compilation events (10 events):
Event: 677.192 Thread 0x00000000169cf000 nmethod 10980 0x00000000039dce90 code [0x00000000039dd040, 0x00000000039dd618]
Event: 677.192 Thread 0x00000000169cf000 10981 3 java.util.Collections$UnmodifiableMap$UnmodifiableEntrySet$UnmodifiableEntry::getKey (10 bytes)
Event: 677.193 Thread 0x00000000169cf000 nmethod 10981 0x0000000002d905d0 code [0x0000000002d90740, 0x0000000002d90968]
Event: 677.193 Thread 0x00000000169cf000 10982 3 java.util.Collections$UnmodifiableMap$UnmodifiableEntrySet$UnmodifiableEntry::getValue (10 bytes)
Event: 677.193 Thread 0x00000000169cf000 nmethod 10982 0x000000000333cd90 code [0x000000000333cf00, 0x000000000333d128]
Event: 677.210 Thread 0x0000000016dd7800 nmethod 10973 0x0000000003e36c90 code [0x0000000003e375e0, 0x0000000003e3d2b8]
Event: 677.289 Thread 0x00000000169cf000 10983 3 net.minecraft.client.particle.EntityFlameFX::<init> (188 bytes)
Event: 677.290 Thread 0x00000000169cf000 nmethod 10983 0x00000000042f30d0 code [0x00000000042f33e0, 0x00000000042f4628]
Event: 677.357 Thread 0x00000000169cf000 10984 ! 3 sun.reflect.GeneratedConstructorAccessor43::newInstance (49 bytes)
Event: 677.357 Thread 0x00000000169cf000 nmethod 10984 0x0000000002c23a50 code [0x0000000002c23c00, 0x0000000002c240a8]
GC Heap History (10 events):
Event: 663.148 GC heap before
{Heap before GC invocations=75 (full 31):
par new generation total 118016K, used 111872K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
eden space 104960K, 100% used [0x00000000c0000000, 0x00000000c6680000, 0x00000000c6680000)
from space 13056K, 52% used [0x00000000c7340000, 0x00000000c7a00330, 0x00000000c8000000)
to space 13056K, 0% used [0x00000000c6680000, 0x00000000c6680000, 0x00000000c7340000)
concurrent mark-sweep generation total 867020K, used 444577K [0x00000000c8000000, 0x00000000fceb3000, 0x0000000100000000)
Metaspace used 44560K, capacity 45077K, committed 45440K, reserved 1089536K
class space used 5115K, capacity 5232K, committed 5248K, reserved 1048576K
Event: 663.152 GC heap after
Heap after GC invocations=76 (full 31):
par new generation total 118016K, used 5578K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
eden space 104960K, 0% used [0x00000000c0000000, 0x00000000c0000000, 0x00000000c6680000)
from space 13056K, 42% used [0x00000000c6680000, 0x00000000c6bf2858, 0x00000000c7340000)
concurrent mark-sweep generation total 867020K, used 447620K [0x00000000c8000000, 0x00000000fceb3000, 0x0000000100000000)
Event: 665.305 GC heap before
{Heap before GC invocations=76 (full 32):
par new generation total 118016K, used 104265K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
eden space 104960K, 94% used [0x00000000c0000000, 0x00000000c605fdc8, 0x00000000c6680000)
Metaspace used 44629K, capacity 45095K, committed 45440K, reserved 1089536K
class space used 5118K, capacity 5235K, committed 5248K, reserved 1048576K
Event: 665.308 GC heap after
Heap after GC invocations=77 (full 32):
par new generation total 118016K, used 4216K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
from space 13056K, 32% used [0x00000000c7340000, 0x00000000c775e3c0, 0x00000000c8000000)
concurrent mark-sweep generation total 867020K, used 447840K [0x00000000c8000000, 0x00000000fceb3000, 0x0000000100000000)
Event: 668.669 GC heap before
{Heap before GC invocations=77 (full 32):
par new generation total 118016K, used 109176K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
concurrent mark-sweep generation total 867020K, used 447383K [0x00000000c8000000, 0x00000000fceb3000, 0x0000000100000000)
Metaspace used 44662K, capacity 45165K, committed 45440K, reserved 1089536K
class space used 5119K, capacity 5236K, committed 5248K, reserved 1048576K
Event: 668.672 GC heap after
Heap after GC invocations=78 (full 32):
par new generation total 118016K, used 4110K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
from space 13056K, 31% used [0x00000000c6680000, 0x00000000c6a83ab0, 0x00000000c7340000)
concurrent mark-sweep generation total 867020K, used 447936K [0x00000000c8000000, 0x00000000fceb3000, 0x0000000100000000)
Event: 673.459 GC heap before
{Heap before GC invocations=78 (full 33):
par new generation total 118016K, used 109070K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
Metaspace used 44682K, capacity 45183K, committed 45440K, reserved 1089536K
class space used 5120K, capacity 5239K, committed 5248K, reserved 1048576K
Event: 673.464 GC heap after
Heap after GC invocations=79 (full 33):
par new generation total 118016K, used 3424K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
from space 13056K, 26% used [0x00000000c7340000, 0x00000000c7698110, 0x00000000c8000000)
concurrent mark-sweep generation total 867020K, used 448103K [0x00000000c8000000, 0x00000000fceb3000, 0x0000000100000000)
Event: 677.005 GC heap before
{Heap before GC invocations=79 (full 33):
par new generation total 118016K, used 108384K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
Metaspace used 44702K, capacity 45195K, committed 45440K, reserved 1089536K
Event: 677.007 GC heap after
Heap after GC invocations=80 (full 33):
par new generation total 118016K, used 3092K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
Deoptimization events (10 events):
Event: 667.695 Thread 0x000000000229a800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x00000000045d859c method=CustomColorizer.getColorMultiplier(Lnet/minecraft/block/Block;Lnet/minecraft/world/IBlockAccess;III)I @ 225
Event: 667.697 Thread 0x000000000229a800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x00000000045d859c method=CustomColorizer.getColorMultiplier(Lnet/minecraft/block/Block;Lnet/minecraft/world/IBlockAccess;III)I @ 225
Event: 668.417 Thread 0x000000000229a800 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x0000000003de95c4 method=net.minecraft.world.World.func_147447_a(Lnet/minecraft/util/Vec3;Lnet/minecraft/util/Vec3;ZZZ)Lnet/minecraft/util/MovingObjectPosition; @ 163
Event: 668.419 Thread 0x000000000229a800 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x0000000003de95c4 method=net.minecraft.world.World.func_147447_a(Lnet/minecraft/util/Vec3;Lnet/minecraft/util/Vec3;ZZZ)Lnet/minecraft/util/MovingObjectPosition; @ 163
Event: 668.422 Thread 0x000000000229a800 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x0000000003de95c4 method=net.minecraft.world.World.func_147447_a(Lnet/minecraft/util/Vec3;Lnet/minecraft/util/Vec3;ZZZ)Lnet/minecraft/util/MovingObjectPosition; @ 163
Event: 668.424 Thread 0x000000000229a800 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x0000000003de95c4 method=net.minecraft.world.World.func_147447_a(Lnet/minecraft/util/Vec3;Lnet/minecraft/util/Vec3;ZZZ)Lnet/minecraft/util/MovingObjectPosition; @ 163
Event: 670.147 Thread 0x000000000229a800 Uncommon trap: reason=unreached action=reinterpret pc=0x000000000339e5ac method=net.minecraft.client.Minecraft.func_90020_K()I @ 4
Event: 670.150 Thread 0x000000000229a800 Uncommon trap: reason=unreached action=reinterpret pc=0x00000000030a1c94 method=net.minecraft.client.Minecraft.func_90020_K()I @ 4
Event: 670.242 Thread 0x000000000229a800 Uncommon trap: reason=unreached action=reinterpret pc=0x00000000034e9b68 method=net.minecraft.util.ChatStyle.func_150235_h()Lnet/minecraft/event/ClickEvent; @ 4
Event: 670.243 Thread 0x000000000229a800 Uncommon trap: reason=unreached action=reinterpret pc=0x0000000004400c48 method=net.minecraft.util.ChatStyle.func_150235_h()Lnet/minecraft/event/ClickEvent; @ 4
Internal exceptions (10 events):
Event: 677.330 Thread 0x0000000034cc8800 Exception <a 'java/lang/InterruptedException': sleep interrupted> (0x00000000c0ad3100) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jvm.cpp, line 3141]
Event: 677.334 Thread 0x0000000034cc8800 Exception <a 'java/lang/InterruptedException': sleep interrupted> (0x00000000c0ad3300) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jvm.cpp, line 3141]
Event: 677.339 Thread 0x0000000034cc8800 Exception <a 'java/lang/InterruptedException': sleep interrupted> (0x00000000c0ad3500) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jvm.cpp, line 3141]
Event: 677.343 Thread 0x0000000034cc8800 Exception <a 'java/lang/InterruptedException': sleep interrupted> (0x00000000c0ad3700) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jvm.cpp, line 3141]
Event: 677.346 Thread 0x0000000034cc8800 Exception <a 'java/lang/InterruptedException': sleep interrupted> (0x00000000c0ad3900) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jvm.cpp, line 3141]
Event: 677.350 Thread 0x0000000034cc8800 Exception <a 'java/lang/InterruptedException': sleep interrupted> (0x00000000c0ad3b00) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jvm.cpp, line 3141]
Event: 677.354 Thread 0x0000000034cc8800 Exception <a 'java/lang/InterruptedException': sleep interrupted> (0x00000000c0ad3d00) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jvm.cpp, line 3141]
Event: 677.358 Thread 0x0000000034cc8800 Exception <a 'java/lang/InterruptedException': sleep interrupted> (0x00000000c0ad3f00) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jvm.cpp, line 3141]
Event: 677.361 Thread 0x0000000034cc8800 Exception <a 'java/lang/InterruptedException': sleep interrupted> (0x00000000c0ad4100) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jvm.cpp, line 3141]
Event: 677.365 Thread 0x0000000034cc8800 Exception <a 'java/lang/InterruptedException': sleep interrupted> (0x00000000c0ad4300) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jvm.cpp, line 3141]
Events (10 events):
Event: 676.479 Thread 0x0000000016dd7800 flushing nmethod 0x0000000004a22450
Event: 677.005 Executing VM operation: GenCollectForAllocation
Event: 677.007 Executing VM operation: GenCollectForAllocation done
Event: 677.190 Thread 0x000000001aed8800 Thread added: 0x000000001aed8800
Event: 677.190 Thread 0x000000001aede800 Thread added: 0x000000001aede800
Event: 677.192 Thread 0x000000001aeda000 Thread added: 0x000000001aeda000
Event: 677.194 Thread 0x000000001aedc000 Thread added: 0x000000001aedc000
Event: 677.194 Executing VM operation: RevokeBias
Event: 677.194 Executing VM operation: RevokeBias done
Event: 677.241 Thread 0x000000001aedf000 Thread added: 0x000000001aedf000
Dynamic libraries:
0x000000013f770000 - 0x000000013f7a4000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\javaw.exe
0x0000000077570000 - 0x000000007771a000 C:\Windows\SYSTEM32\ntdll.dll
0x0000000077450000 - 0x000000007756f000 C:\Windows\system32\kernel32.dll
0x000007fefd500000 - 0x000007fefd56a000 C:\Windows\system32\KERNELBASE.dll
0x000007fefd660000 - 0x000007fefd73b000 C:\Windows\system32\ADVAPI32.dll
0x000007fefdba0000 - 0x000007fefdc3f000 C:\Windows\system32\msvcrt.dll
0x000007fefe620000 - 0x000007fefe63f000 C:\Windows\SYSTEM32\sechost.dll
0x000007fefe4f0000 - 0x000007fefe61d000 C:\Windows\system32\RPCRT4.dll
0x0000000077350000 - 0x000000007744a000 C:\Windows\system32\USER32.dll
0x000007fefe0d0000 - 0x000007fefe137000 C:\Windows\system32\GDI32.dll
0x000007feff660000 - 0x000007feff66e000 C:\Windows\system32\LPK.dll
0x000007feff730000 - 0x000007feff7fa000 C:\Windows\system32\USP10.dll
0x000007fefb820000 - 0x000007fefba14000 C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18837_none_fa3b1e3d17594757\COMCTL32.dll
0x000007fefd740000 - 0x000007fefd7b1000 C:\Windows\system32\SHLWAPI.dll
0x000007feff800000 - 0x000007feff82e000 C:\Windows\system32\IMM32.DLL
0x000007fefdfc0000 - 0x000007fefe0c9000 C:\Windows\system32\MSCTF.dll
0x000007fee0320000 - 0x000007fee042f000 c:\program files (x86)\razer\ingameengine\64bit\rzdspsrv.dll
0x000007fee9e20000 - 0x000007fee9e23000 C:\Windows\system32\api-ms-win-core-synch-l1-2-0.DLL
0x0000000077730000 - 0x0000000077737000 C:\Windows\system32\psapi.dll
0x000007fee7470000 - 0x000007fee7490000 c:\program files (x86)\razer\ingameengine\64bit\RazerHook64.dll
0x000007fee7530000 - 0x000007fee764d000 C:\Windows\system32\Opengl32.DLL
0x000007fee7a60000 - 0x000007fee7a8d000 C:\Windows\system32\GLU32.dll
0x000007fee7300000 - 0x000007fee73f1000 C:\Windows\system32\DDRAW.dll
0x000007fee7a50000 - 0x000007fee7a58000 C:\Windows\system32\DCIMAN32.dll
0x000007fefdde0000 - 0x000007fefdfb7000 C:\Windows\system32\SETUPAPI.dll
0x000007fefd330000 - 0x000007fefd366000 C:\Windows\system32\CFGMGR32.dll
0x000007fefe410000 - 0x000007fefe4ea000 C:\Windows\system32\OLEAUT32.dll
0x000007fefe640000 - 0x000007fefe843000 C:\Windows\system32\ole32.dll
0x000007fefd610000 - 0x000007fefd62a000 C:\Windows\system32\DEVOBJ.dll
0x000007fefc2d0000 - 0x000007fefc2e8000 C:\Windows\system32\dwmapi.dll
0x000007fefa2b0000 - 0x000007fefa30d000 C:\Windows\system32\dxgi.dll
0x000007fefc400000 - 0x000007fefc40c000 C:\Windows\system32\VERSION.dll
0x000007fee7430000 - 0x000007fee746c000 C:\Windows\system32\dinput8.dll
0x000007fee9e40000 - 0x000007feea03f000 C:\Windows\system32\d3d9.dll
0x000007fee9e30000 - 0x000007fee9e37000 C:\Windows\system32\d3d8thk.dll
0x0000000078800000 - 0x00000000788d2000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\msvcr100.dll
0x000000006fbe0000 - 0x000000007043a000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\server\jvm.dll
0x000007fef87b0000 - 0x000007fef87b9000 C:\Windows\system32\WSOCK32.dll
0x000007feff830000 - 0x000007feff87d000 C:\Windows\system32\WS2_32.dll
0x000007fefdc40000 - 0x000007fefdc48000 C:\Windows\system32\NSI.dll
0x000007fefad60000 - 0x000007fefad9b000 C:\Windows\system32\WINMM.dll
0x000007fefb7c0000 - 0x000007fefb816000 C:\Windows\system32\uxtheme.dll
0x0000000067ef0000 - 0x0000000067eff000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\verify.dll
0x0000000050980000 - 0x00000000509a8000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\java.dll
0x0000000050060000 - 0x0000000050076000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\zip.dll
0x000007fefe850000 - 0x000007feff5da000 C:\Windows\system32\SHELL32.dll
0x000007fefd2a0000 - 0x000007fefd2af000 C:\Windows\system32\profapi.dll
0x00000000511d0000 - 0x00000000511dd000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\management.dll
0x0000000050030000 - 0x000000005004a000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\net.dll
0x0000000180000000 - 0x000000018006d000 C:\Windows\system32\LavasoftTcpService64.dll
0x000007fefca40000 - 0x000007fefca95000 C:\Windows\system32\MSWSOCK.dll
0x000007fefc420000 - 0x000007fefc447000 C:\Windows\system32\IPHLPAPI.DLL
0x000007fefc410000 - 0x000007fefc41b000 C:\Windows\system32\WINNSI.DLL
0x000007fefd0b0000 - 0x000007fefd0d5000 C:\Windows\system32\SspiCli.dll
0x000007fefd140000 - 0x000007fefd14f000 C:\Windows\system32\CRYPTBASE.dll
0x000007fefca30000 - 0x000007fefca37000 C:\Windows\System32\wship6.dll
0x000000006f3b0000 - 0x000000006f3c1000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\nio.dll
0x000007feff690000 - 0x000007feff729000 C:\Windows\system32\CLBCatQ.DLL
0x000007fefcaa0000 - 0x000007fefcab8000 C:\Windows\system32\CRYPTSP.dll
0x000007fefc7a0000 - 0x000007fefc7e7000 C:\Windows\system32\rsaenh.dll
0x000007fefd1f0000 - 0x000007fefd204000 C:\Windows\system32\RpcRtRemote.dll
0x000007fefd150000 - 0x000007fefd1e1000 C:\Windows\system32\SXS.DLL
0x000007fefaa10000 - 0x000007fefaa25000 C:\Windows\system32\NLAapi.dll
0x000007fef25c0000 - 0x000007fef25d5000 C:\Windows\system32\napinsp.dll
0x000007fef25a0000 - 0x000007fef25b9000 C:\Windows\system32\pnrpnsp.dll
0x000007fefc8c0000 - 0x000007fefc91b000 C:\Windows\system32\DNSAPI.dll
0x000007fef2590000 - 0x000007fef259b000 C:\Windows\System32\winrnr.dll
0x000000006e810000 - 0x000000006e836000 C:\Program Files\Bonjour\mdnsNSP.dll
0x000007fefc3e0000 - 0x000007fefc3e7000 C:\Windows\System32\wshtcpip.dll
0x000007fef2580000 - 0x000007fef2588000 C:\Windows\system32\rasadhlp.dll
0x000007fef9a30000 - 0x000007fef9a83000 C:\Windows\System32\fwpuclnt.dll
0x00000000509b0000 - 0x00000000509c7000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\unpack.dll
0x0000000001ed0000 - 0x0000000001f21000 C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.4.1558-1.7.10\1.7.10-Forge10.13.4.1558-1.7.10-natives-1101030637048\lwjgl64.dll
0x000007fefd630000 - 0x000007fefd64f000 C:\Windows\system32\USERENV.dll
0x000007fef9a00000 - 0x000007fef9a11000 C:\Windows\system32\dhcpcsvc6.DLL
0x000007fef99e0000 - 0x000007fef99f8000 C:\Windows\system32\dhcpcsvc.DLL
0x000000006cc00000 - 0x000000006cd98000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\awt.dll
0x0000000068d60000 - 0x000000006ab35000 C:\Windows\system32\nvoglv64.DLL
0x000007fefc500000 - 0x000007fefc511000 C:\Windows\system32\WTSAPI32.dll
0x000007feeade0000 - 0x000007feeaf05000 C:\Windows\system32\dbghelp.dll
0x000007fefd2c0000 - 0x000007fefd2fb000 C:\Windows\system32\WINTRUST.dll
0x000007fefd390000 - 0x000007fefd4fd000 C:\Windows\system32\CRYPT32.dll
0x000007fefd2b0000 - 0x000007fefd2bf000 C:\Windows\system32\MSASN1.dll
0x000007fefaf80000 - 0x000007fefafad000 C:\Windows\system32\ntmarta.dll
0x000007fefd7c0000 - 0x000007fefd812000 C:\Windows\system32\WLDAP32.dll
0x000007fefd060000 - 0x000007fefd09d000 C:\Windows\system32\WINSTA.dll
0x000007fefa440000 - 0x000007fefa4dc000 C:\Windows\system32\mscms.dll
0x000007fee4cd0000 - 0x000007fee4d12000 C:\Windows\system32\icm32.dll
0x0000000070a40000 - 0x0000000070adc000 C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.4.1558-1.7.10\1.7.10-Forge10.13.4.1558-1.7.10-natives-1101030637048\avutil-ttv-51.dll
0x0000000065980000 - 0x00000000659d6000 C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.4.1558-1.7.10\1.7.10-Forge10.13.4.1558-1.7.10-natives-1101030637048\swresample-ttv-0.dll
0x000000006eb80000 - 0x000000006ec50000 C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.4.1558-1.7.10\1.7.10-Forge10.13.4.1558-1.7.10-natives-1101030637048\libmp3lame-ttv.dll
0x000007fedc350000 - 0x000007fedd6f4000 C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.4.1558-1.7.10\1.7.10-Forge10.13.4.1558-1.7.10-natives-1101030637048\libmfxsw64.dll
0x000007fedf630000 - 0x000007fedf75b000 C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.4.1558-1.7.10\1.7.10-Forge10.13.4.1558-1.7.10-natives-1101030637048\twitchsdk.dll
0x000007fefd820000 - 0x000007fefdaf2000 C:\Windows\system32\WININET.dll
0x000007fefd300000 - 0x000007fefd304000 C:\Windows\system32\api-ms-win-downlevel-user32-l1-1-0.dll
0x000007fefd380000 - 0x000007fefd384000 C:\Windows\system32\api-ms-win-downlevel-shlwapi-l1-1-0.dll
0x000007fefd320000 - 0x000007fefd324000 C:\Windows\system32\api-ms-win-downlevel-version-l1-1-0.dll
0x000007fefd650000 - 0x000007fefd653000 C:\Windows\system32\api-ms-win-downlevel-normaliz-l1-1-0.dll
0x0000000077740000 - 0x0000000077743000 C:\Windows\system32\normaliz.DLL
0x000007fefe140000 - 0x000007fefe409000 C:\Windows\system32\iertutil.dll
0x000007fefd310000 - 0x000007fefd315000 C:\Windows\system32\api-ms-win-downlevel-advapi32-l1-1-0.dll
0x000000006fa50000 - 0x000000006fa81000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\jpeg.dll
0x0000000011db0000 - 0x0000000011dec000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\lcms.dll
0x0000000012180000 - 0x00000000121e4000 C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.4.1558-1.7.10\1.7.10-Forge10.13.4.1558-1.7.10-natives-1101030637048\OpenAL64.dll
0x000007fefbff0000 - 0x000007fefc03b000 C:\Windows\System32\MMDevApi.dll
0x000007fefbec0000 - 0x000007fefbfec000 C:\Windows\System32\PROPSYS.dll
0x000007fee74a0000 - 0x000007fee7528000 C:\Windows\system32\dsound.dll
0x000007fefc2f0000 - 0x000007fefc31c000 C:\Windows\system32\POWRPROF.dll
0x000007fefaca0000 - 0x000007fefacef000 C:\Windows\system32\AUDIOSES.DLL
0x0000000070470000 - 0x0000000070494000 C:\Program Files (x86)\Minecraft\runtime\jre-x64\1.8.0_25\bin\sunec.dll
VM Arguments:
jvm_args: -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx1G -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M -Djava.library.path=C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.4.1558-1.7.10\1.7.10-Forge10.13.4.1558-1.7.10-natives-1101030637048
java_command: net.minecraft.launchwrapper.Launch --username 3KD --version 1.7.10-Forge10.13.4.1558-1.7.10 --gameDir C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft --assetsDir C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\assets --assetIndex 1.7.10 --uuid 32236b47e08d4868acb1997e479816f2 --accessToken 796512e516d944aba0095ed750c7fe20 --userProperties {} --userType legacy --tweakClass cpw.mods.fml.common.launcher.FMLTweaker --nativeLauncherVersion 307
java_class_path (initial): C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\libraries\net\minecraftforge\forge\1.7.10-10.13.4.1558-1.7.10\forge-1.7.10-10.13.4.1558-1.7.10.jar;C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\libraries\net\minecraft\launchwrapper\1.12\launchwrapper-1.12.jar;C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\libraries\org\ow2\asm\asm-all\5.0.3\asm-all-5.0.3.jar;C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\libraries\com\typesafe\akka\akka-actor_2.11\2.3.3\akka-actor_2.11-2.3.3.jar;C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\libraries\com\typesafe\config\1.2.1\config-1.2.1.jar;C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-actors-migration_2.11\1.1.0\scala-actors-migration_2.11-1.1.0.jar;C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-compiler\2.11.1\scala-compiler-2.11.1.jar;C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\libraries\org\scala-lang\plugins\scala-continuations-library_2.11\1.0.2\scala-continuations-library_2.11-1.0.2.jar;C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\libraries\org\scala-lang\plugins\scala-continuations-plugin_2.11.1\1.0.2\scala-continuations-plugin_2.11.1-1.0.2.jar;C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-library\2.11.1\scala-library-2.11.1.jar;C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-parser-combinators_2.11\1.0.1\scala-parser-combinators_2.11-1.0.1.jar;C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-reflect\2.11.1\scala-reflect-2.11.1.jar;C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-swing_2.11\1.0.1\scala-swing_2.11-1.0.1.jar;C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-xml_2.11\1.0.2\scala-xml_2.11-1.0.2.jar;C:\Users\ZarioXx (Martin)\AppData\Roaming\.minecraft\libraries\lzma\lzma\0.0.1\lzma-0.0.1.
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Razer Chroma SDK\bin;C:\Program Files\Razer Chroma SDK\bin;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Skype\Phone\;C:\Program Files (x86)\AMD\ATI.ACE\Core-Static
USERNAME=ZarioXx (Martin)
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 60 Stepping 3, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 7 , 64 bit Build 7601 Service Pack 1
CPU:total 4 (4 cores per cpu, 1 threads per core) family 6 model 60 stepping 3, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, avx2, aes, clmul, erms, lzcnt, tsc, tscinvbit, bmi1, bmi2
Memory: 4k page, physical 8250632k(3066264k free), swap 16499404k(8573712k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (25.25-b02) for windows-amd64 JRE (1.8.0_25-b18), built on Oct 7 2014 14:25:37 by "java_re" with MS VC++ 10.0 (VS2010)
time: Tue Nov 01 12:06:36 2016
elapsed time: 677 seconds (0d 0h 11m 17s)
Aidez moi SVPPPP
Registers:
C [net.dll+0x758b]
Other Threads:
Heap:
Events (10 events):
Dynamic libraries:
VM Arguments:
OS=Windows_NT
Aidez moi SVPPPP
8 réponses
Oui
Le problème persiste
Comment dois-je donc faire ?
Bon des raisons de sécurité, je n'indiquerai pas ici comment désactiver l'User Account Control.
Sinon, essayez de démarrer le launcher (cela ne fonctionne qu'avec une version OFFICIELLE du jeu), en mode de comptabilité 32 bits. Clic droit sur le launcher > Propriétés > Compatibilité. C'est normalement dans cet onglet. -
@greg160Je viens de desactivé l'User Account Control
Très bien !
Nous sommes donc dans le cas mystérieux et incorrigeable du Exception_ACCESS_VIOLATION
Il se pourrait qu'il puisse être corrigé en désactivant l'User Account Control, mais c'est surtout dû à la version 64 bits de Windows.
http://textup.fr/180200zk Voila
Même problème... -
Tout d'abord merci pour ta réponse !
Et oui la casse JVM Arguments est coché: -Xmx2G -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M -
Bonjour, pour commencer, on ne poste JAMAIS un rapport de cette longueur sur un message d'un forum, utilisez des hébergeurs de texte en ligne.
Minecraft est un jeu qui demande relativement beaucoup de ressources notamment côté mémoire. Il n'est donc pas rare que, si on demande à Minecraft d'utiliser moins de RAM, celui ci crash.
Le rapport semble indiquer que vous étiez en plein jeu, vu notamment la durée de lancement du programme mesurée : 11 minutes et 17 secondes.
Bon, pour passer au problème pur, la Java Runtime Environnement, ou JRE, ce qui fait tourner les codes compilés en Java, à relevé une Exception (une erreur), qui ne peut pas vraiment être empêchée. Celle ci dit clairement :
Le processus "Minecraft.exe" a essayé d'accéder à des zones de la mémoires requises pour son exécution inexistantes ou dont l'accès lui est refusé.
Vu que tu as 8 Go de RAM et que tu en donnes 4 à Minecraft, je pense que tu as modifié les "JVM Arguments" dans ton launcher :
Comme l'ignorent la plupart des gamins qui jouent à minecraft et qui y touchent sans même savoir à quoi ça correspond, cela contraint Minecraft à s'éxécuter dans un processus légèrement différent de son fonctionnement habituel. La Java Virtual Machine est ce qui fait tourner le jeu. Donc, pas toucher.
Si tu as le Launcher Officiel (et dans le cas contraire, nous ne sommes pas en moyen de t'aider vu que ce post serait contraire à la charte), cliques sur "Edit Profile" avant de démarrer le jeu, et en bas, vérifie que "JVM Arguments" n'est pas coché, et si il est coché, merci de poster ce qu'il y a dedans.
Cordialement,
