Problème lancement Minecraft
J'ai un problème, sur mon ordi (un peu vieux), j'ai installé minecraft mais lorsque je le lance j'ai un "crash report" Erreur:
---- Minecraft Crash Report ----
// My bad.
Time: 10/10/15 13:13
Description: Initializing game
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:247)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at ave.ap(SourceFile:534)
at ave.am(SourceFile:363)
at ave.a(SourceFile:310)
at net.minecraft.client.main.Main.main(SourceFile:124)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.8.8
Operating System: Windows 7 (x86) version 6.1
Java Version: 1.8.0_25, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 103530784 bytes (98 MB) / 157687808 bytes (150 MB) up to 523501568 bytes (499 MB)
JVM Flags: 6 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx512M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: 1.8.8
LWJGL: 2.9.4
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
GL Caps:
Using VBOs: No
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Resource Packs:
Current Language: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
CPU: <unknown>
SVP aidez moi !
  1. mmmhhh c'est souvent la ram le probleme, t'a combien de ram exactement,
    et en fonction de ça , augmente le xmx , tu va dans edit profile, puis en bas , il y a JVM Arguments, tu coche, et tu supprimes les nombres suivant leXmx et tu les remplace par quelque chose de plus grand, "1G" correspond à 1GIgaOCtet de ta Ram utilisé, toi tu dois avoir 499M, tu peux mettre "1G" et tu supprime aussi le M en meme , puisque tu change d'unité
    look le screen, moi j'ai mis 14G en bas à gauche
    http://puu.sh/kF2Dd/b520f1398e.png
    1. ChrisRes j'ai 4GO de RAM et y'a déjà 1G dans mon profile..! Les erreurs sont au niveau du ogl et du language mais je sais pas comment les résoudre :(
