Suppression définitive de system speedup et advanced system prot
Aprés avoir parcouru maintes et maintes forum et post, avoir essayé au moins une demi-douzaine de procéder pour désinstaller ces 2 malwares, ils reviennent sans cesse !
Quelqu'un aurait une idée pour le supprimer définitivement ?
Merci d'avance pour votre aide !
PS : J'ai essayé adw cleaner, ZHP fix, revo uninstaller, spy hunter... Sans succés !
il y a un autre rapport qui est apparu au redémarrage du PC :
========== OTL ==========
C:\Users\Geoffrey\AppData\Local\Google\Chrome\User Data\Default\Extensions\gmookaamlkjilnemkglmedgieblahbcn\0.1_0 folder moved successfully.
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{70C53538-9F82-42BC-A327-74F7A46E700C}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{70C53538-9F82-42BC-A327-74F7A46E700C}\ deleted successfully.
C:\Program Files (x86)\Deeal\ScriptHost.dll moved successfully.
C:\Users\Geoffrey\AppData\Roaming\betadeeal folder moved successfully.
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Advanced System Protector folder moved successfully.
C:\ProgramData\Systweak\Advanced System Protector\updates folder moved successfully.
C:\ProgramData\Systweak\Advanced System Protector\signatures folder moved successfully.
C:\ProgramData\Systweak\Advanced System Protector\2.1.1000.12580 folder moved successfully.
C:\ProgramData\Systweak\Advanced System Protector folder moved successfully.
C:\ProgramData\Systweak folder moved successfully.
C:\Program Files (x86)\Advanced System Protector\Troubleshooter folder moved successfully.
C:\Program Files (x86)\Advanced System Protector\clamunpack folder moved successfully.
Folder move failed. C:\Program Files (x86)\Advanced System Protector scheduled to be moved on reboot.
C:\Users\Geoffrey\AppData\Roaming\System Speedup folder moved successfully.
C:\Windows\SysNative\roboot64.exe moved successfully.
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\System Speedup folder moved successfully.
C:\Users\Geoffrey\AppData\Roaming\systweak\ssd folder moved successfully.
C:\Users\Geoffrey\AppData\Roaming\systweak\Advanced System Protector\Logs folder moved successfully.
C:\Users\Geoffrey\AppData\Roaming\systweak\Advanced System Protector\Backup folder moved successfully.
C:\Users\Geoffrey\AppData\Roaming\systweak\Advanced System Protector\2.1.1000.12580 folder moved successfully.
C:\Users\Geoffrey\AppData\Roaming\systweak\Advanced System Protector folder moved successfully.
C:\Users\Geoffrey\AppData\Roaming\systweak folder moved successfully.
C:\Program Files (x86)\System Speedup folder moved successfully.
C:\Program Files (x86)\Deeal folder moved successfully.
C:\Users\Public\Desktop\Advanced System Protector.lnk moved successfully.
C:\Windows\Tasks\System Speedup_DEFAULT.job moved successfully.
C:\Windows\Tasks\System Speedup_UPDATES.job moved successfully.
C:\Users\Public\Desktop\System Speedup.lnk moved successfully.
C:\Users\Geoffrey\AppData\Roaming\~rfbizkg.exe moved successfully.
C:\Users\Geoffrey\AppData\Roaming\~jxhuwgj.exe moved successfully.
File C:\Users\Public\Desktop\System Speedup.lnk not found.
C:\Users\Geoffrey\AppData\Roaming\~aweiaky.exe moved successfully.
========== FILES ==========
C:\Users\Geoffrey\AppData\Local\Microsoft\WinU\main folder moved successfully.
C:\Users\Geoffrey\AppData\Local\Microsoft\WinU folder moved successfully.
========== COMMANDS ==========
OTL by OldTimer - Version 3.2.69.0 log created on 07022014_212026
Files\Folders moved on Reboot...
PendingFileRenameOperations files...
Registry entries deleted on Reboot... -
ModérateurRelance OTL.
o sous Personnalisation (Custom Scan), copie_colle le contenu ci dessous (bien prendre :OTL en début).
Clic Correction (Fix), un rapport apparraitra, copie/colle le contenu ici:
:OTL
CHR - Extension: Design Float = C:\Users\Geoffrey\AppData\Local\Google\Chrome\User Data\Default\Extensions\gmookaamlkjilnemkglmedgieblahbcn\0.1_0\
O2 - BHO: (Deeal) - {70C53538-9F82-42BC-A327-74F7A46E700C} - C:\Program Files (x86)\Deeal\ScriptHost.dll (Deeal)
[2014/07/02 17:03:13 | 000,000,000 | ---D | C] -- C:\Users\Geoffrey\AppData\Roaming\betadeeal
[2014/07/02 20:21:35 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Advanced System Protector
[2014/07/02 20:21:31 | 000,000,000 | ---D | C] -- C:\ProgramData\Systweak
[2014/07/02 20:21:24 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Advanced System Protector
[2014/07/02 20:20:28 | 000,000,000 | ---D | C] -- C:\Users\Geoffrey\AppData\Roaming\System Speedup
[2014/07/02 20:20:27 | 000,019,544 | ---- | C] (System Speedup) -- C:\windows\SysNative\roboot64.exe
[2014/07/02 20:20:25 | 000,000,000 | ---D | C] -- C:\ProgramData\Microsoft\Windows\Start Menu\Programs\System Speedup
[2014/07/02 20:20:23 | 000,000,000 | ---D | C] -- C:\Users\Geoffrey\AppData\Roaming\systweak
[2014/07/02 20:20:18 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\System Speedup
[2014/07/02 19:56:06 | 000,000,000 | ---D | C] -- C:\Program Files (x86)\Deeal
[2014/07/02 20:21:35 | 000,001,216 | ---- | M] () -- C:\Users\Public\Desktop\Advanced System Protector.lnk
[2014/07/02 20:20:45 | 000,000,290 | ---- | M] () -- C:\windows\tasks\System Speedup_DEFAULT.job
[2014/07/02 20:20:44 | 000,000,298 | ---- | M] () -- C:\windows\tasks\System Speedup_UPDATES.job
[2014/07/02 20:20:26 | 000,001,089 | ---- | M] () -- C:\Users\Public\Desktop\System Speedup.lnk
[2014/03/20 11:00:12 | 000,492,208 | ---- | C] () -- C:\Users\Geoffrey\AppData\Roaming\~rfbizkg.exe
[2014/02/27 15:26:57 | 000,493,272 | ---- | C] () -- C:\Users\Geoffrey\AppData\Roaming\~jxhuwgj.exe
[2014/07/02 19:55:29 | 000,001,089 | ---- | C] () -- C:\Users\Public\Desktop\System Speedup.lnk
[2014/07/02 17:03:12 | 000,667,648 | ---- | C] () -- C:\Users\Geoffrey\AppData\Roaming\~aweiaky.exe
:files
:Commands
[reboot]
* poste le rapport ici
Redémarre l'ordinateur
Merci.
voici le lien de l'OTL : http://pjjoint.malekal.com/files.php?id=20140702_b10n12c8h7r12 -
ModérateurSalut,
Faire un Scan OTL - Temps : Environ 40min
OTL permet de diagnostiquer les programmes qui tournent et déceler des infections - Le programme va générer deux rapports OTL.txt et Extras.txt
Fournir les deux rapports :
Tu peux suivre les indications de cette page pour t'aider : https://www.malekal.com/tutorial-otl/
* Télécharge http://www.geekstogo.com/forum/files/file/398-otl-oldtimers-list-it/ sur ton bureau.
(Sous Vista/Win7, il faut cliquer droit sur OTL et choisir Exécuter en tant qu'administrateur)
Dans le cas d'Avast!, ne pas lancer le programme dans la Sandbox (voir lien d'aide ci-dessus).
* Lance OTL
* En haut à droite de Analyse rapide, coche "tous les utilisateurs"
* Sur OTL, sous Personnalisation, copie-colle le script ci-dessous :
netsvcs
msconfig
safebootminimal
safebootnetwork
activex
drivers32
%ALLUSERSPROFILE%\Application Data\*.
%ALLUSERSPROFILE%\Application Data\*.dll /s
%APPDATA%\*.
%PROGRAMFILES%\*.
%PROGRAMDATA%\*.
%APPDATA%\*.exe /s
%temp%\*.exe /s
%SYSTEMDRIVE%\*.exe
%systemroot%\*. /mp /s
%systemroot%\system32\consrv.dll
%windir%\Tasks\*.job /lockedfiles
%systemroot%\system32\drivers\*.sys /lockedfiles
%systemroot%\System32\config\*.sav
/md5start
explorer.exe
winlogon.exe
services.exe
wininit.exe
/md5stop
HKEY_CLASSES_ROOT\CLSID\{F3130CDB-AA52-4C3A-AB32-85FFC23AF9C1}\InprocServer32 /s
HKEY_LOCAL_MACHINE\SYSTEM\SYSTEM\CurrentControlSet\Services\lanmanserver\parameters /s
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\SubSystems /s
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\AppCertDlls /s
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList /s
HKEY_LOCAL_MACHINE\Software\Microsoft\Command Processor /s
HKEY_CURRENT_USER\Software\Microsoft\Command Processor /s
CREATERESTOREPOINT
nslookup www.google.fr /c
ping www.google.fr /c
ipconfig /all /c
SAVEMBR:0
hklm\software\clients\startmenuinternet|command /rs
hklm\software\clients\startmenuinternet|command /64 /rs
* Clique sur le bouton Analyse.
**** Si durant le scan - OTL ne répond pas, ne touche à rien et laisse le scan se poursuivre ****
* Quand le scan est fini, utilise le site http://pjjoint.malekal.com/ pour envoyer le rapport OTL.txt (et Extra.txt si présent).
Donne le ou les liens pjjoint qui pointent vers ces rapports ici dans une réponse.
Je répète : donne le lien du rapport pjjoint ici en réponse.
NE PAS COPIER/COLLER LE RAPPORT ICI - DONNER LE LIEN PJJOINT DANS UN NOUVEAU MESSAGE
