Probleme nation zoom
Bonjour, même problème avec nation zoom merci
# AdwCleaner v3.018 - Report created 29/01/2014 at 15:21:26
# Updated 28/01/2014 by Xplode
# Operating System : Windows 7 Ultimate Service Pack 1 (32 bits)
# Username : Laure - LAURE-PC
# Running from : C:\Users\Laure\Downloads\adwcleaner-3.018.exe
# Option : Clean
***** [ Services ] *****
***** [ Files / Folders ] *****
***** [ Shortcuts ] *****
***** [ Registry ] *****
***** [ Browsers ] *****
-\\ Internet Explorer v9.0.8112.16502
-\\ Mozilla Firefox v26.0 (fr)
[ File : C:\Users\Laure\AppData\Roaming\Mozilla\Firefox\Profiles\ljkt03a6.default-1390999377915\prefs.js ]
Line Deleted : user_pref("aol_toolbar.default.homepage.check", false);
Line Deleted : user_pref("aol_toolbar.default.search.check", false);
Line Deleted : user_pref("extensions.BabylonToolbar.prtkDS", 0);
Line Deleted : user_pref("extensions.BabylonToolbar.prtkHmpg", 0);
Line Deleted : user_pref("sweetim.toolbar.scripts.1.domain-blacklist", "");
Line Deleted : user_pref("sweetim.toolbar.searchguard.UserRejectedGuard_DS", "");
Line Deleted : user_pref("sweetim.toolbar.searchguard.UserRejectedGuard_HP", "");
Line Deleted : user_pref("sweetim.toolbar.searchguard.enable", "");
Line Deleted : user_pref("sweetim.toolbar.previous.browser.search.defaultenginename", "");
Line Deleted : user_pref("sweetim.toolbar.previous.browser.search.selectedEngine", "");
Line Deleted : user_pref("sweetim.toolbar.previous.keyword.URL", "");
Line Deleted : user_pref("sweetim.toolbar.previous.browser.startup.homepage", "");
AdwCleaner[R0].txt - [4914 octets] - [29/01/2014 15:05:37]
AdwCleaner[R1].txt - [1807 octets] - [29/01/2014 15:20:49]
AdwCleaner[S0].txt - [4931 octets] - [29/01/2014 15:11:21]
AdwCleaner[S1].txt - [1752 octets] - [29/01/2014 15:21:26]
########## EOF - C:\AdwCleaner\AdwCleaner[S1].txt - [1812 octets] ##########
# Option : Clean
Si cela ne suffit pas tu peut en plus d'ADWCLEANER passer roguekiller et malwarbytes. Ainsi que vérifier (avec CCleaner par exemple) si nation zoom (ou autre saloperie dans le même genre) n'est pas installer sur la machine.
Puis comme la dit Malekal_morte- vérifie que dans les navigateurs il n'y a pas d'extension ou page de démarrage encore présente.
J'espère que cela marchera pour toi,
Les logiciel que j'ai citer sont complémentaire a votre solution (comme je les indiquer dans mon message).
Je sais que cela ne sert pas a grand chose contre nation-zoom en lui même mais si nation zoom et installer il se peut très bien que d'autre Malware ou saloperie qui se sont incrusté aussi.
Ma solution est complémentaire et permet de limiter la casse et le risque que cela ce réinstalle. -
ModérateurSalut,
réinitialise tes navigateurs:
Réinitialise tes navigateurs et ou manuellement reparamètre tes navigateurs WEB (page de démarrage, moteur de recherche etc) mais aussi supprimer/désactiver les extensions inutiles/parasites :
* Internet Explorer et modules complémentaires / moteurs de recherche : https://forum.malekal.com/viewtopic.php?t=41399&start=
* Firefox : https://www.malekal.com/reparer-firefox/?t=36057&start=
* Google Chrome : https://www.malekal.com/reparer-google-chrome/?t=35837&start=
NOTE : Pour Firefox et Google Chrome - si rien ne va, il y a la possibilité de les désinstaller/réinstaller, voir liens explicatifs ci-dessus.
et enfin et surtout :
Tu peux le faire automatiquement avec ce programme : https://forum.malekal.com/viewtopic.php?t=46433&start=
ou manuellement au cas où :
il faut nettoyer les raccourcis (icones) de lancement des navigateurs WEB.
Comme expliqué dans les liens précédents, faire un clic droit sur les icones de raccourcis de lancement des navigateurs puis propriétés.
Dans cible, à la fin, une adresse http a été ajoutée (exemple https://www.malekal.com/fichiers/forum/malavida_22find_7.png ) pour que le site s'ouvre au démarrage du navigateur, supprimer cette adresse http ET SEULEMENT cette adresse http.
