Probleme minecraft
bonjour je vous contact aujourd'hui car j'ai un problème quand je veut jouer a minecraft cela s'affiche
Client> [13:12:59] [main/INFO]: Setting user: kidjetkar
Client> [13:12:59] [main/INFO]: (Session ID is token:-:sessionId)
Client> [13:13:00] [Client thread/INFO]: LWJGL Version: 2.9.1
Client> [13:13:16] [Client thread/INFO]: Reloading ResourceManager: Default
Client> #
Client> # A fatal error has been detected by the Java Runtime Environment:
Client> #
Client> # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x690f7a9e, pid=884, tid=2424
Client> #
Client> # JRE version: Java(TM) SE Runtime Environment (7.0_45-b18) (build 1.7.0_45-b18)
Client> # Java VM: Java HotSpot(TM) Client VM (24.45-b08 mixed mode, sharing windows-x86 )
Client> # Problematic frame:
Client> # C [vticd.dll+0xf7a9e]
Client> #
Client> # Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
Client> #
Client> # An error report file with more information is saved as:
Client> # C:\Documents and Settings\Utilisateur\Application Data\.minecraft\hs_err_pid884.log
Client> #
Client> # If you would like to submit a bug report, please visit:
Client> # https://bugreport.java.com/bugreport/crash.jsp
Client> # The crash happened outside the Java Virtual Machine in native code.
Client> # See problematic frame for where to report the bug.
Client> #
Game ended with bad state (exit code 1)
Ignoring visibility rule and showing launcher due to a game crash
Deleting C:\Documents and Settings\Utilisateur\Application Data\.minecraft\versions\1.7.4\1.7.4-natives-13195456618927
pouvaient vous m aider merci.
14 réponses
  1. comment met on les pilote de notre chipset a jour merci maintenant un autre message apparais:
    [15:29:43 INFO]: Client> [15:29:43] [main/INFO]: Setting user: Player
    [15:29:43 INFO]: Client> [15:29:43] [main/INFO]: (Session ID is token:db455afaffd6438cb548223dcff9a512:00000000-0000-0000-0000-000000000000)
    [15:29:45 INFO]: Client> [15:29:45] [Client thread/INFO]: LWJGL Version: 2.9.1
    [15:29:48 INFO]: Client> [15:29:48] [Client thread/INFO]: Reloading ResourceManager: Default
    [15:29:48 INFO]: Client> #
    [15:29:48 INFO]: Client> # A fatal error has been detected by the Java Runtime Environment:
    [15:29:48 INFO]: Client> # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x690f7a9e, pid=2760, tid=3972
    [15:29:48 INFO]: Client> # JRE version: Java(TM) SE Runtime Environment (7.0_45-b18) (build 1.7.0_45-b18)
    [15:29:48 INFO]: Client> # Java VM: Java HotSpot(TM) Client VM (24.45-b08 mixed mode, sharing windows-x86 )
    [15:29:48 INFO]: Client> # Problematic frame:
    [15:29:48 INFO]: Client> # C [vticd.dll+0xf7a9e]
    [15:29:48 INFO]: Client> # Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
    [15:29:48 INFO]: Client> # An error report file with more information is saved as:
    [15:29:48 INFO]: Client> # C:\Documents and Settings\Utilisateur\Application Data\.minecraft\hs_err_pid2760.log
    [15:29:48 INFO]: Client> # If you would like to submit a bug report, please visit:
    [15:29:48 INFO]: Client> # https://bugreport.java.com/bugreport/crash.jsp
    [15:29:48 INFO]: Client> # The crash happened outside the Java Virtual Machine in native code.
    [15:29:48 INFO]: Client> # See problematic frame for where to report the bug.
    [15:29:49 ERROR]: Game ended with bad state (exit code 1)
    [15:29:49 INFO]: Deleting C:\Documents and Settings\Utilisateur\Application Data\.minecraft\versions\1.7.4\1.7.4-natives-987641466722
    [15:29:49 INFO]: Ignoring visibility rule and showing launcher due to a game crash
    1. mais a jour java et les pilote de ton chipset et apre dis moi si sa fonctionne
      1. es tu es sur un pc portable ta carte graphique et un chipset intégré
        1. voila ma carte graphique: VIA/S3G UniChrome Pro IGP
          1. window xp je regarde pour la carte graphique
            1. c'est un raport de crash solution
              -mais les driver a jour si sait dejas fait regarde la version de java
              -c'est peux etre un probleme dans la version que tu as pris (1.7.4)
              mais pars exemple 1.7.2
              apre ce crash et juste un crash raport de java donc pour moi c'est a cause de java
              regarde bien ton raport
              il as bien un probleme sur les codage il ne connait pas ce langage si je me ne trompe pas
              quel et ton windows ? ta carte graphique stp
              1. Pour les mod en faite je n'ait jamais réussi a jouer tout court donc je n'ai jamais mi de mod
                1. Si tu as des Mod, essaye des les enlevés et après teste le jeu sans. Si il marche toujours pas, contacte le support.
                  1. Déjà fait sa beug a chaque fois
