Probleme minecraft aidez moi svp
Bonjour, j'ai mon nouvo pc et je peut jkouer a minecraft depui mais aujourdhui j'ai u cette erreur la voici :
Minecraft has crashed!
Minecraft has stopped running because it encountered a problem; Rendering screen
A full error report has been saved to C:\Users\vincent\AppData\Roaming\.minecraft\crash-reports\crash-2012-12-28_21.49.54-client.txt - Please include a copy of that file (Not this screen!) if you report this crash to anyone; without it, they will not be able to help fix the crash :(
--- BEGIN ERROR REPORT f90b8f66 --------
Full report at:
Please show that file to Mojang, NOT just this screen!
Generated 28/12/12 21:49
-- Head --
Stacktrace:
at bey.b(SourceFile:236)
at bey.c(SourceFile:323)
at bey.a(SourceFile:357)
-- Screen render details --
Details:
Screen name: bey
Mouse location: Scaled: (261, 31). Absolute: (522, 416)
Screen size: Scaled: (427, 240). Absolute: (854, 480). Scale factor of 2
Stacktrace:
at ban.b(SourceFile:774)
at net.minecraft.client.Minecraft.J(SourceFile:605)
at net.minecraft.client.Minecraft.run(SourceFile:534)
at java.lang.Thread.run(Unknown Source)
-- System Details --
Details:
Minecraft Version: 1.4.6
Operating System: Windows 7 (x86) version 6.1
Java Version: 1.7.0_10, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 433450872 bytes (413 MB) / 518979584 bytes (494 MB) up to 1037959168 bytes (989 MB)
JVM Flags: 2 total; -Xms512m -Xmx1024m
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
LWJGL: 2.4.2
OpenGL: AMD 760G GL version 3.2.9606 Compatibility Profile Context, ATI Technologies Inc.
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Texture Pack: Default
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null
java.lang.NoClassDefFoundError: org/lwjgl/util/glu/GLU
Caused by: java.lang.ClassNotFoundException: org.lwjgl.util.glu.GLU
at java.net.URLClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
... 7 more
--- END ERROR REPORT 59451eb ----------
dure , dure sera de trouver la réponse .
Full report at:
-- Head --
Stacktrace:
Details:
Screen name: bey
Stacktrace:
Details:
LWJGL: 2.4.2
... 7 more
salut les mecs
d'abors il se peux que votre java est en 64bit alors c'est mieux pour la visibiliter a distance mais je conseil le 32bit deplus il se peux que si vous avez instaler un mode (manuellement) vous vouez ete planté avec les fichier...si vous laver instaler avec un utilisateur (pipix etc) verifier que vous avez mi la bonne vertion ! si ceux n'es rien de cela fait un force update si apres sa sa ne marche toujour pas ouvre votre roamig (menu windose plus R) tape %appdata% tu trouvera ".minecraft"
rentre dedant prend le dossier "save" (c'est tes saugarde de monde solo) apres supprime ton .minecraft et relance ton lanceur minecraft.. moi c'est se que jai fait et sa a remarcher
j'esper avoir aider.. -
Même problème depuis quelques temps...
Up :)
