[java] probleme avec applet
quand j'ai compillé ce prg,ce dernier me donne erreur message veuillez m'aidez svp
<code>
import java.awt.*;
import java.applet.*;
public class UserIn extends Applet
TextField text1, text2;
public void init( )
text1=new TextField(8);
text2=new TextField(8);
add (text1);
add (text2);
text1.setText("0");
text2.setText("0");
public void paint( Graphics g)
int x=0, y=0, z=0;
String s1, s2, s;
g.drawString ("Input a number in each box", 10, 50);
try
s1=text1.getText();
x=Integer.parseInt(s1);
s2=text2.getText();
y=Integer.parseInt(s2);
catch(Exception e )
z=x+y;
s=String.valueOf(z);
g.drawString( "THE SUM IS:", 10, 75);
g.drawString(s, 100, 75);
public Boolean action(Event event, Object object)
repaint( );
return true;
</code
erreur message sont:
Exception in thread "AWT-EventQueue-1" java.lang.Error: Unresolved compilation problems:
Illegal modifier for parameter action; only final is permitted
Syntax error on token "(", ; expected
Syntax error on token ",", ; expected
Syntax error on token ")", ; expected
Void methods cannot return a value
at UserIn.paint(UserIn.java:34)
at sun.awt.RepaintArea.paintComponent(RepaintArea.java:264)
at sun.awt.RepaintArea.paint(RepaintArea.java:240)
at sun.awt.windows.WComponentPeer.handleEvent(WComponentPeer.java:347)
at java.awt.Component.dispatchEventImpl(Component.java:4937)
at java.awt.Container.dispatchEventImpl(Container.java:2287)
at java.awt.Component.dispatchEvent(Component.java:4687)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:703)
at java.awt.EventQueue.access$000(EventQueue.java:102)
at java.awt.EventQueue$3.run(EventQueue.java:662)
at java.awt.EventQueue$3.run(EventQueue.java:660)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87)
at java.awt.EventQueue$4.run(EventQueue.java:676)
at java.awt.EventQueue$4.run(EventQueue.java:674)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:673)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:244)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:163)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:151)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:147)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:139)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:97)
merci d'avance
  1. j'ai inséré
    private static final long serialVersionUID = 1;
    à la fin de prg
    rien ne changé
      Le serialVersionUID c'est pour corriger le premier avertissement :
      warning: [serial] serializable class UserIn has no definition of serialVersionUID
      Mais le deuxième avertissement concerne un tout autre problème, qu'il faut aussi corriger :
      warning: [deprecation] action(Event,Object) in Component has been deprecated
      public boolean action (Event evt, Object arg)
      Mais j'insiste sur le fait que ce ne sont que des avertissements, ton programme fonctionnera sans problème dans la plupart des cas.
  2. j'ai compilé comme vous dites,j'ai message suivante:
    UserIn.java:34: warning: [deprecation] action<Event,Object>in component has been deprecated
    public boolean action<Event evt,Object arg>
    1 warning
      Oui, c'est le deuxième problème dont je parlais, mais le message est assez explicite !
  3. Modérateur
    Ton message ce n'est qu'un avertissement, et tu peux en avoir le détail en suivant les instructions qui te sont afficher à savoir compiler comme ceci : javac -Xlint UserIn.java
    Je te laisse regarder ce qui s'affiche, voici comment corriger ça : il faut ajouter un numéro de version pour la sérialisation : private static final long serialVersionUID = 1;
    Remarque : si tu utilisais un IDE comme Eclipse ou NetBeans, ce genre de problème se corrigerait en un clic, il faudrait peut-être penser à te simplifier la vie...
    Il y a un autre problème, c'est que action(Event, Object) est dépréciée et ne devrait donc plus être utilisée, il y a d'autres mécanismes (les ActionListener) qui ont été mis en place et qui sont plus performants, ils devraient donc être utilisés à la place.La confiance n'exclut pas le contrôle
    1. j'ai corrigé mon prg ainsi
      import java.awt.*;
           public void init( )
                    add (text1);
                    add (text2);
                    text1.setText("0");
                    text2.setText("0");
           public void paint(Graphics g)
             int x=0, y=0, z=0;
             String s1, s2, s;
             try
                    s1=text1.getText();
                    s2=text2.getText();
              catch(Exception e )
                   z=x+y;
              repaint( );
                 return true;
      et j'ai essayé le compiler dans l'invite de commande avec
      javac Userin.java,
      ce dernier me donnes ce message:
      note:UserIn uses or overrides a deprecated API.
      note:Recompile with -Xlint:deprecation for details.
      et j'ai essayé compilé avec
      le résultat de mon calcul s'affiche pas
      où est ce que j'ai pu faire erreur?
      quelqu'un peut m'aider svp
