Connection SSL par CURL ?
je viens de télécharger la librairie libcurl me permettant d'effectuer des connections SSL a travers mon programme C++.
J'ai réussi à créer des connections simple par protocole HTTP, mais lorsque je dois en faire par HTTPS (par SSL), le programme n'arrive a rien et j'obtiens l'erreur :
Unsupported Protocol
Est-ce que quelqu'un aurait une idée pour m'aider a avancer ?
Je n'arrive pas non plus a faire marcher le code exemple présent avec la librairie :
curl = curl_easy_init();
if(curl) {
/* what call to write: */
curl_easy_setopt(curl, CURLOPT_URL, "HTTPS://your.favourite.ssl.site");
curl_easy_setopt(curl, CURLOPT_WRITEHEADER, headerfile);
while(1) /* do some ugly short cut... */
if (pEngine) /* use crypto engine */
if (curl_easy_setopt(curl, CURLOPT_SSLENGINE,pEngine) != CURLE_OK)
{ /* load the crypto engine */
fprintf(stderr,"can't set crypto engine\n");
break;
if (curl_easy_setopt(curl, CURLOPT_SSLENGINE_DEFAULT,1L) != CURLE_OK)
{ /* set the crypto engine as default */
/* only needed for the first time you load
a engine in a curl object... */
fprintf(stderr,"can't set crypto engine as default\n");
break;
/* cert is stored PEM coded in file... */
/* since PEM is default, we needn't set it for PEM */
curl_easy_setopt(curl,CURLOPT_SSLCERTTYPE,"PEM");
/* set the cert for client authentication */
curl_easy_setopt(curl,CURLOPT_SSLCERT,pCertFile);
/* sorry, for engine we must set the passphrase
(if the key has one...) */
if (pPassphrase)
curl_easy_setopt(curl,CURLOPT_KEYPASSWD,pPassphrase);
/* if we use a key stored in a crypto engine,
we must set the key type to "ENG" */
curl_easy_setopt(curl,CURLOPT_SSLKEYTYPE,pKeyType);
/* set the private key (file or ID in engine) */
curl_easy_setopt(curl,CURLOPT_SSLKEY,pKeyName);
/* set the file with the certs vaildating the server */
curl_easy_setopt(curl,CURLOPT_CAINFO,pCACertFile);
/* disconnect if we can't validate server's cert */
curl_easy_setopt(curl,CURLOPT_SSL_VERIFYPEER,1L);
res = curl_easy_perform(curl);
break; /* we are done... */
/* always cleanup */
curl_easy_cleanup(curl);
curl_global_cleanup();
Est-ce que j'aurais oublié de configurer quelque chose ?
J'ai gardé les même configurations de compilation entre les différents protocol, le pbleme viendrait-il de là ?
Merci d'avance.
  1. J'ai trouvé une solution a mon probleme :
    Ma librairie était mal installé sous Windows.
    Lorsque j'ai fait les essai sous Linux RedHat, la connection s'est effectué.
    Donc, après la réinstallation de curl sous Windows, le programme fonctionne.
    En esperant que cela serve a qqun plus tard.
