Antivir solution pro
j'ai le virus antivir solution pro sur mon pc portable qui bloque tout ! comment procéder pour le supprimer ?
merciii
merciii
Contributeur sécuritéOk, normalement ça doit être bon maintenant :)
This log file is located at C:\rkill.log.
Please post this only if requested to by the person helping you.
Otherwise you can close this log when you wish.
Ran as Mymy on 20/07/2010 at 22:46:01.
Processes terminated by Rkill or while it was running:
C:\Windows\system32\conime.exe
Rkill completed on 20/07/2010 at 22:46:03.
Malwarebytes' Anti-Malware 1.46
www.malwarebytes.org
Version de la base de données: 4333
Windows 6.0.6002 Service Pack 2 (Safe Mode)
Internet Explorer 8.0.6001.18928
21/07/2010 22:03:32
mbam-log-2010-07-21 (22-03-32).txt
Type d'examen: Examen complet (C:\|D:\|F:\|)
Elément(s) analysé(s): 358457
Temps écoulé: 1 heure(s), 18 minute(s), 43 seconde(s)
Clé(s) du Registre infectée(s): 26
Valeur(s) du Registre infectée(s): 2
Elément(s) de données du Registre infecté(s): 0
Dossier(s) infecté(s): 1
Fichier(s) infecté(s): 8
HKEY_CLASSES_ROOT\cscrptxt.cscrptxt (Adware.EZlife) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{acac45e3-9088-45ae-818e-3cc101378a14} (Adware.EZlife) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{acac45e3-9088-45ae-818e-3cc101378a14} (Adware.EZlife) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{acac45e3-9088-45ae-818e-3cc101378a14} (Adware.EZlife) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{acac45e3-9088-45ae-818e-3cc101378a14} (Adware.EZlife) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{e0ec6fba-f009-3535-95d6-b6390db27da1} (Adware.EZlife) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\cscrptxt.cscrptxt.1.0 (Adware.EZlife) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\AppID\{84c3c236-f588-4c93-84f4-147b2abbe67b} (Adware.Adrotator) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\AppID\{38061edc-40bb-4618-a8da-e56353347e6d} (Adware.EZlife) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\AppID\{7b6a2552-e65b-4a9e-add4-c45577ffd8fd} (Adware.EZLife) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\adgj.aghlp (Adware.EZLife) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\adgj.aghlp.1 (Adware.EZLife) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\adshothlpr.adshothlpr (Adware.Adrotator) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\adshothlpr.adshothlpr.1.0 (Adware.Adrotator) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\avsuite (Rogue.AntivirusSuite) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Sky-Banners (Adware.Adrotator) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\Street-Ads (Adware.Adrotator) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\avsuite (Rogue.AntivirusSuite) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\$NtUninstallMTF1011$ (Adware.Adrotator) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Sky-Banners (Adware.Adrotator) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Street-Ads (Adware.Adrotator) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_OKO6 (Worm.KoobFace) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\AVSolution (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\AVSolution (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{654ce85c-9d9e-44ac-a7d6-e89ea0c08828} (Adware.AdRotator) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{654ce85c-9d9e-44ac-a7d6-e89ea0c08828} (Adware.AdRotator) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\mchk (Trojan.Adware) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\faxwofkw (Rogue.AntivirusSuite.Gen) -> Quarantined and deleted successfully.
C:\Windows\$NtUninstallMTF1011$ (Adware.Adrotator) -> Quarantined and deleted successfully.
C:\Windows\System32\owdep.exe (Trojan.Adware) -> Quarantined and deleted successfully.
C:\Windows\System32\bwdep.dll (Adware.EZlife) -> Quarantined and deleted successfully.
C:\Users\Mymy\AppData\Local\Temp\hatmjtqg.exe (Trojan.Dropper) -> Quarantined and deleted successfully.
C:\Users\Mymy\AppData\Local\Temp\texn.exe (Adware.BHO) -> Quarantined and deleted successfully.
C:\Windows\$NtUninstallMTF1011$\apUninstall.exe (Adware.Adrotator) -> Quarantined and deleted successfully.
C:\Windows\$NtUninstallMTF1011$\zrpt.xml (Adware.Adrotator) -> Quarantined and deleted successfully.
C:\Users\Mymy\AppData\Local\ettfhvewi\htdghqvtssd.exe (Rogue.AntivirusSuite.Gen) -> Quarantined and deleted successfully.
C:\Windows\System32\xwdep.dll (Adware.AdRotator) -> Quarantined and deleted successfully. -
Contributeur sécuritéOk, alors redémarre ton PC en mode sans échec avec prise en charge réseau, là tu pourras télécharger puis lancer malwarebytes directement.
en fait je suis aussi obligé de passer par un autre pc et d'enregistrer rkill sur une clé pour essayer de l'installer car dés que j'ouvre une fenétre internet antivir se met en route
oui ils sont bloqués aussi
je ne peux pas installer rkill parce qu'antivir bloque l'installation
Contributeur sécuritéBonsoir,
-+-+-+-+-> Rkill <-+-+-+-+-
[x] Télécharge rkill sur ton bureau.
[x] Rkill peut être reconnu comme indésirable par certains antivirus, ignore l'alerte et désactive momentanément l'antivirus.
[x] Lance le, une fenêtre noire s'ouvrira t'indiquant que l'installation s'est bien déroulée.
[x] Note : Si le premier lien ne fonctionne pas, essaie ces trois autres : n°1 , n°2 et n°3
[x] /!\ Il ne faut pas redémarrer le PC après avoir lancé rkill, sinon il faudra recommencer la procédure /!\
[x] Poste le contenu du rapport qui s'ouvrira -> rkill.log
-+-+-+-+-> Malwarebytes' Anti-Malware <-+-+-+-+-
[x] Télécharge Malwarebytes' Anti-malware sur ton bureau.
[x] Installe le en laissant les options par défaut ( Cocher seulement " Créer une icône sur le bureau " )
[x] A la fin de l'installation, MBAM se mettra à jour automatiquement puis s'exécutera.
[x] Une fois lancé, clique sur " Exécuter un examen complet " puis sur " Rechercher "
[x] Sélectionne tout tes disques locaux et amovibles
[x] Patiente pendant toute la durée du scan, puis clique sur " Ok " une fois l'analyse effectuée.
[x] Clique ensuite sur " Afficher les résultats " puis sur " Supprimer la sélection ". Valide ensuite par " Ok ".
[x] MBAM ouvrira un rapport, copie/colle son contenu dans ta prochaine réponse.
[x] Tu peux ensuite vider la quarantaine de MBAM.
[x] Note : MBAM t'invitera peut être à redémarrer ton PC, fais le. Le rapport se trouve dans la partie " Rapports/Logs " de MBAM.
[x] Si tu as des soucis, un tutoriel est disponible à cette adresse.
