Probleme avec lo.st et eorezo encombrant
Je voudrais supprimer lost de ma page de démarage internet.
Voici le rapport effectué par ad remover
Aidez moi.
======= RAPPORT D'AD-REMOVER 2.0.0.0,D | UNIQUEMENT XP/VISTA/7 =======
Mis à jour par C_XX le 19/05/10 à 19:20
Contact: AdRemover.contact@gmail.com
Site web: http://pagesperso-orange.fr/NosTools/ad_remover.html
Lancé à: 20:43:40 le 29/05/2010 | Mode normal | Option: SCAN
Exécuté de: C:\Ad-Remover\ADR.exe
SE: Microsoft Windows 7 Édition Familiale Premium ( - X64)
Nom du PC: CHATELAIN-PC (HP-Pavilion WE279AA-ABF p6361fr)
Utilisateur actuel: chatelain
============== ÉLÉMENT(S) TROUVÉ(S) ==============
C:\Program Files (x86)\Ask.com
C:\Program Files (x86)\EoRezo
C:\Users\CHATEL~1\AppData\Local\Temp\AskSearch
C:\Users\CHATEL~1\AppData\Local\Temp\ASKSUTBLOG
C:\Users\chatelain\AppData\Local\AskToolbar
C:\Users\chatelain\AppData\Local\EoRezo
C:\Users\chatelain\AppData\LocalLow\AskToolbar
C:\Users\chatelain\AppData\Roaming\EoRezo
C:\Windows\Installer\{86D4B82A-ABED-442A-BE86-96357B70F4FE}
HKCU\Software\AppDataLow\AskToolbarInfo
HKCU\Software\AppDataLow\Software\AskToolbar
HKCU\Software\Ask.com
HKCU\Software\AskToolbar
HKCU\Software\EoRezo
HKCU\Software\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{A5AA24EA-11B8-4113-95AE-9ED71DEAF12A}
HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{171DEBEB-C3D4-40b7-AC73-056A5EBA4A7E}
HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{00000000-6E41-4FD3-8538-502F5495E5FC}
HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{C10DC1F4-CCDF-4224-A24D-B23AFC3573C8}
HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{D4027C7F-154A-4066-A1AD-4243D8127440}
HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{00000000-6E41-4FD3-8538-502F5495E5FC}
HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{C10DC1F4-CCDF-4224-A24D-B23AFC3573C8}
HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{D4027C7F-154A-4066-A1AD-4243D8127440}
HKLM\Software\Classes\AppID\{9B0CB95C-933A-4B8C-B6D4-EDCD19A43874}
HKLM\Software\Classes\AppID\{AFBB7970-789A-4264-BA70-E8127DECE400}
HKLM\Software\Classes\AppID\EoEngineBHO.DLL
HKLM\Software\Classes\AppID\GenericAskToolbar.DLL
HKLM\Software\Classes\CLSID\{00000000-6E41-4FD3-8538-502F5495E5FC}
HKLM\Software\Classes\CLSID\{C10DC1F4-CCDF-4224-A24D-B23AFC3573C8}
HKLM\Software\Classes\CLSID\{D4027C7F-154A-4066-A1AD-4243D8127440}
HKLM\Software\Classes\EoEngineBHO.EOBHO
HKLM\Software\Classes\EoEngineBHO.EOBHO.1
HKLM\Software\Classes\GenericAskToolbar.ToolbarWnd
HKLM\Software\Classes\GenericAskToolbar.ToolbarWnd.1
HKLM\Software\Classes\Installer\Products\A28B4D68DEBAA244EB686953B7074FEF
HKLM\Software\Classes\Interface\{6C434537-053E-486D-B62A-160059D9D456}
HKLM\Software\Classes\Interface\{91CF619A-4686-4CA4-9232-3B2E6B63AA92}
HKLM\Software\Classes\Interface\{AC71B60E-94C9-4EDE-BA46-E146747BB67E}
HKLM\Software\Classes\Interface\{DF76E9B7-35EC-46FC-AF56-5B79DED9D64F}
HKLM\Software\Classes\TypeLib\{18AF7201-4F14-4BCF-93FE-45617CF259FF}
HKLM\Software\Classes\TypeLib\{2996F0E7-292B-4CAE-893F-47B8B1C05B56}
HKLM\Software\EoRezo
HKLM\Software\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{A5AA24EA-11B8-4113-95AE-9ED71DEAF12A}
HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{C10DC1F4-CCDF-4224-A24D-B23AFC3573C8}
HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{D4027C7F-154A-4066-A1AD-4243D8127440}
HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\{86D4B82A-ABED-442A-BE86-96357B70F4FE}
HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\EoRezo_is1
HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\SoftwareUpdate_is1
HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser|{D4027C7F-154A-4066-A1AD-4243D8127440}
HKLM\Software\Microsoft\Internet Explorer\Toolbar|{D4027C7F-154A-4066-A1AD-4243D8127440}
HKLM\Software\Microsoft\Windows\CurrentVersion\Run|Eorezo
============== SCAN ADDITIONNEL ==============
* Internet Explorer Version 8.0.7600.16385 *
[HKCU\Software\Microsoft\Internet Explorer\Main]
Do404Search: 0x01000000
Enable Browser Extensions: yes
Local Page: C:\Windows\system32\blank.htm
Search bar: Preserve
Search Page: hxxp://go.microsoft.com/fwlink/?LinkId=54896
Show_ToolBar: yes
Start Page: hxxp://y.lo.st
[HKLM\Software\Microsoft\Internet Explorer\Main]
AutoHide: yes
Default_Page_URL: hxxp://g.uk.msn.com/HPDSK/3
Default_Search_URL: hxxp://go.microsoft.com/fwlink/?LinkId=54896
Delete_Temp_Files_On_Exit: yes
Local Page: C:\Windows\SysWOW64\blank.htm
Start Page: hxxp://g.uk.msn.com/HPDSK/3
[HKLM\Software\Microsoft\Internet Explorer\ABOUTURLS]
Tabs: hxxp://y.lo.st
Blank: res://mshtml.dll/blank.htm
C:\Ad-Remover\Quarantine: 0 Fichier(s)
C:\Ad-Remover\Backup: 0 Fichier(s)
C:\Ad-Report-SCAN[1].txt - 4872 Octet(s)
Fin à: 20:46:08, 29/05/2010
============== E.O.F - SCAN[1] ==============
  1. Merci.Il semble que sa a marché et que je suis enfin débarrassé de lo.st.
    1. Re
      Je m'en occupe si ton problème est résolu.
  2. Re
    Tu relances Ad Remover et tu passes à cette option.
    1. Comment fait on pour signaler que le probleme est résolu?
