Big problem
Fermé
salut j ai fais une analyse avec hijackthis :
Scan saved at 17:34:44, on 12/02/2009
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\SOUNDMAN.EXE
C:\WINDOWS\system32\sistray.EXE
C:\WINDOWS\Paizhao.EXE
C:\WINDOWS\Recovery.EXE
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Internet Explorer\IEXPLORE.EXE
C:\WINDOWS\system32\mmc.exe
C:\Program Files\Internet Explorer\iexplore.exe
C:\Program Files\Windows NT\Accessoires\WORDPAD.EXE
C:\WINDOWS\system32\NOTEPAD.EXE
C:\Documents and Settings\tazebama.dl_
C:\Program Files\Trend Micro\HijackThis\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = http://www.google.fr/toolbar/ie8/sidebar.html
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = https://www.google.fr/?gws_rd=ssl
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = https://www.google.fr/?gws_rd=ssl
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant = http://www.google.fr/toolbar/ie8/sidebar.html
R1 - HKCU\Software\Microsoft\Internet Explorer\SearchURL,(Default) = http://www.google.fr/search?q=%s
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [SiS Tray] C:\WINDOWS\system32\sistray.EXE
O4 - HKLM\..\Run: [SiS KHooker] C:\WINDOWS\system32\khooker.exe
O4 - HKLM\..\Run: [VMSnap3] C:\WINDOWS\Paizhao.EXE
O4 - HKLM\..\Run: [Domino] C:\WINDOWS\Recovery.EXE
O4 - HKLM\..\Run: [BigDog303] C:\WINDOWS\VM303_STI.EXE VIMICRO USB PC Camera (ZC0301PLH)
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\ctfmon.exe
O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SERVICE LOCAL')
O4 - HKUS\S-1-5-19\..\RunOnce: [nlsf] cmd.exe /C move /Y "%SystemRoot%\System32\syssetub.dll" "%SystemRoot%\System32\syssetup.dll" (User 'SERVICE LOCAL')
O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SERVICE RÉSEAU')
O4 - HKUS\S-1-5-20\..\RunOnce: [nlsf] cmd.exe /C move /Y "%SystemRoot%\System32\syssetub.dll" "%SystemRoot%\System32\syssetup.dll" (User 'SERVICE RÉSEAU')
O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'Default user')
O7 - HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System, DisableRegedit=1
O8 - Extra context menu item: + &Mass Downloader: download this file - E:\setup\Add_Url.htm
O8 - Extra context menu item: + Mass Downloader: download &All files - E:\setup\Add_All.htm
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Console Java (Sun) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_06\bin\ssv.dll
O9 - Extra button: Diminuer la page - {A0E6D3BD-A661-447D-8634-0751467857F3} - C:\Program Files\UTILS\EasyRead\ZoomOut.js (file missing)
O9 - Extra button: Agrandir la page - {AEBB571B-4C48-438D-808D-999F168CDECE} - C:\Program Files\UTILS\EasyRead\ZoomIn.js (file missing)
O17 - HKLM\System\CCS\Services\Tcpip\..\{57CCA5AD-081D-427B-869A-2C02111E528D}: NameServer = 193.251.169.165 196.20.77.165
O17 - HKLM\System\CCS\Services\Tcpip\..\{74BB0888-6968-4498-A138-BAABE0CCE1B0}: NameServer = 192.168.1.1
End of file - 4091 bytes
Boot mode: Normal
Running processes:
9 réponses
Modérateur
a ok, j'ai deja fais un rapport hijack, et aprés j'ai du telecharger un logiciel nettoyeur, regarde sur un autre forum ou il y a eu un virus ;)
merci c est trop gentill de votre part mais si tu connues ce virus (tazebama.dll) il ne me permet pas de installer un anti virus ....
a voila aussi, installe avast il est gratuit
je n ai pas et je n arrive pas l installer .
ton antivirus ne peut pas le supprimé?
il y a une solution
merci d'avance -
virus tazibama.dll
j ai fais l analyse de hijathis -
quel probleme a tu sur ton pc?
