How to deactivate wifi on b-box? need help thanks
Solved
jova
ft -
ft -
Hello,
I would like to know if it is possible to temporarily disable the wifi on my b-box, hoping for a response. Thank you in advance.
To enable/disable WiFi on the Bbox, here is the procedure to follow:
- type 192.168.1.254 (this is the IP address of your Bbox) in the address bar of your internet browser
- on the homepage, click on "Expert Mode" on the left and log in by entering admin (make sure to use lowercase letters) as the username and password
- you will access the configuration options of the Bbox in administrator mode (full rights)
- click on "Home Network," still on the left side of the screen, then on "WiFi"
- on the WiFi information page, click on "Configure" in the top right corner (small gray link)
- all you have to do is check or uncheck the "WiFi enabled" option according to your choice...
