Black screen and "Power saving mode" issue
Solved
juantgo Posted messages 55 Status Member -
 Mahai -
Hello, "Power saving mode" issue!
As soon as I start my computer, my screen goes black (sleep mode (the button switches from green to orange), and an error message appears saying "Power saving mode"
How do I fix this, considering I can't access safe mode since my screen doesn't work as it goes to sleep immediately? Thanks for your help as soon as possible! (I'm a beginner, so if we can avoid technical terms or explain them in detail, I would prefer. (Yes, I know I'm a pain, but I've been without my screen for 3 months, so no computer) Configuration: Windows XP
  1. teddy.at Posted messages 283 Status Member 113
    Hello,
    if the screen turns off, it means the computer is not starting. To make sure the problem isn't with the screen, try it on another machine.
    To see if the computer is booting, check if the hard drive light is blinking (it is usually red or orange).
    Otherwise, as soon as you turn on your machine, press the "del" or "f2" key to enter the BIOS. This key may vary depending on the manufacturer.
    46
    1. Paki
      bonjour, j'ai changé ma carte graphique. Le PC démarre, le ventilateur de la carte graphique se met en route, mais mon écran LG reste noir et affiche "mode économies d'énergie". Merci de me dire quoi faire.
      20
    2. sanaa
      Thank you, it worked well for me.
    3. Heheh
      Nothing works
