Help for programming CAME remote control
Solved
Hello,
I can't manage to program my second gate remote control of the brand CAME TAM 432SA. Does anyone have a detailed manual or a descriptive diagram? The manual is too simplistic to understand.
Configuration: Windows Me! Firefox 2.0.0.16
  • Descending date
  1. Here is the methodology for programming a Came TOP 432 NA or 432 SA remote control:
    To make your new remote control work, you need to code it as follows:
    1- Press both buttons on the new remote control simultaneously until the
    LED blinks faster. Release the buttons.
    2- Press the first button: the LED lights up continuously.
    3- Within 10 seconds, place your old remote control against your new
    remote control (as shown in the diagram below: the nose of the old one against the bottom of the
    new one) and press the first button on your old remote control. The new
    remote control will blink 3 times: the operation is successful.
    4- Release all buttons.
    5- With the first button coded, repeat the same operation for the second button on the
    remote control.
    6- Check the proper functioning of your remote control.
    If it does not work, contact Telecommande Express at 01 44 70 04 06.
    1. It works perfectly! Thank you all.
    2. Thank you, I was struggling, it was poorly explained in the manual, especially the arrangement of the remote controls in relation to each other.
    3. thank you very effective,
      the manual is very poorly done
    4. Well done. Very clear.
    5. Thank you! Very explicit.
