Car radio overheating issue
Dragon -
 girgols -
Hello everyone;
I’m writing because I have an issue with my car radio, let me explain:
I just got a TAKARA GPV 1004 car radio, it works pretty well but the problem is that it heats up very quickly which triggers a whistling noise from the fan that is very annoying. I went back to where I bought it but they can’t do anything because it’s a new model and they themselves don’t know if this whistling is normal or not.
And I was wondering if it could be related to the ground?
(since I connected my car radio myself and I took the ground from the screw at the back of the unit, wouldn’t it be better to take it from the black wire (ground) of the car radio)
Could having a poor ground cause my unit to heat up?
What other reasons could cause my unit to heat up?
I want to point out that the car radio plays DVDs and normally I should connect the ground to the handbrake but then I can’t watch DVDs while driving (I want to be able to watch DVDs while driving specifically for the kids (my daughter in this case))
Thank you for your help
  • 1
  • 2
  1. dad
    Hello
    I have the same problem as you, I don’t think it’s due to the weight
    personally I think I will return it to the store (boostore) for an exchange
    otherwise maybe unplugging the fan and connecting a larger, quieter one, but then the warranty is void (to be considered)
    if you have solved the problem, please post the answer
    best regards
    2
    1. Anonymous user
      Everywhere, everyone is saying tokai tamashi roadstar takara run away don't buy!!!
  • 1
  • 2
