32" LED TV PIN Code (80 cm) - CL32LED23B - Black CLAYTON - Ca
Zuniga -
txiki Posted messages 6514 Registration date   Status Contributor Last intervention   -
Hello, I just bought a 32" LED TV (80 cm) - CL32LED23B - Black CLAYTON - Carrefour.fr. Upon turning it on, I am asked for a PIN code that is not mentioned anywhere. Thank you for shedding light on this code. Best regards.
  1. baladur13 Posted messages 47354 Registration date   Status Moderator Last intervention   14 400
    Hello,
    During the first installation, you need to set a 4-digit PIN code. See the manual on page 7 under the First Installation section.
    Excerpt from the manual for the CL32DLED15B model (which should not differ too much from yours)
    It's very difficult to catch a black cat in a dark room.
    Especially when it's not there...
  2. Lili
    Hello, did you manage to get your TV up and running?
    Best regards
  3. txiki Posted messages 6514 Registration date   Status Contributor Last intervention   609
    Hello everyone,
    If the issue is resolved, please remember to:
    ►  report it using the gear icon in the original message.
    ►  also specify how this issue was resolved, it will help others.
    Thank you in advance!
  4. seb
    Hello, I just bought this television.
    To install the selected pin code, choose your pin code by pressing confirm and re-enter your code.
    1. txiki Posted messages 6514 Registration date   Status Contributor Last intervention   609
      Hello Seb,
      I think he must have found the solution by now!!!!!
      Best wishes for this new year 2024!
