32" LED TV PIN Code (80 cm) - CL32LED23B - Black CLAYTON - Ca
Zuniga
txiki Posted messages 6514 Registration date Status Contributeur Last intervention -
Hello, I just bought a 32" LED TV (80 cm) - CL32LED23B - Black CLAYTON - Carrefour.fr. Upon turning it on, I am asked for a PIN code that is not mentioned anywhere. Thank you for shedding light on this code. Best regards.
Hello,
During the first installation, you need to set a 4-digit PIN code. See the manual on page 7 under the First Installation section.
Excerpt from the manual for the CL32DLED15B model (which should not differ too much from yours)
Hello everyone,
If the issue is resolved, please remember to:
► report it using the gear icon in the original message.
► also specify how this issue was resolved, it will help others.
Thank you in advance!
