Red CPU and DRAM LED
Special37 Posted messages 7 Status Member -
 PastequeAllongerParterresale -
Hello, in January 2022, I bought all the components to build a little PC. Once assembled, my PC was working perfectly, but 5 months later, while I was on my PC watching videos on YouTube, it abruptly shut down by itself. A few hours earlier, I had played a game of Fortnite, and the PC was working perfectly as well. After my PC turned off, I tried to turn it back on, and it restarted but shut down immediately. I tried again, but nothing happened. I unplugged it and waited a few seconds, then plugged it back in, and it started up, but two red LEDs were lit on the motherboard, "CPU and DRAM."
So if anyone can help me, I would appreciate it because I don't understand why or how.
Thanks to those who will help me ????????
Spx
  1. epango Posted messages 36739 Registration date   Status Member Last intervention   Ambassador 4 271
    First, tell us the composition of your PC.
    Misnaming things adds to the world's misfortune (Albert Camus)
    3
    1. Special37 Posted messages 7 Status Member
      I have a Ryzen 5 5600G, an Asrock Pro4 B550 motherboard
      2x8GB DDR4 Corsair "Vengeance", a 240GB SSD and a 1TB HDD, and my power supply is an Aerocool Lux550, hoping you can help me :)
  2. epango Posted messages 36739 Registration date   Status Member Last intervention   Ambassador 4 271
    Look at the positioning of your RAM in the memory slots. Are the sticks in the recommended positions? That is to say A2/B2?
    To misname things is to add to the misery of the world (Albert Camus)
    2
      Yes, they are.
  3. epango Posted messages 36739 Registration date   Status Member Last intervention   Ambassador 4 271
    You don't have a dedicated GPU. The issue lies with the CPU and RAM. Make sure the CPU power supply is still plugged in.
    Naming things incorrectly adds to the misery of the world (Albert Camus)
      Well, that’s the problem, I feel like there’s no power from the power supply to the motherboard for the processor, and also my RAM stick has RGB and it lights up, so it is receiving power?
  4. epango Posted messages 36739 Registration date   Status Member Last intervention   Ambassador 4 271
    Apparently, judging by the photo, the essentials seem to be correctly connected. It may be the power supply itself that is problematic.
      Sure, thank you :) But is it possible for the problem to appear 5 months later?? Like the issue came up suddenly and everything was working perfectly before.
  5. Special37 Posted messages 7 Status Member
    My varnish didn't apply, but it's next to it
    Spx
  6. PastequeAllongerParterresale
    Do you have the same problem as me????
