Optical cable for soundbar from a jack cable
A_1708 Posted messages 5 Status Member -
baladur13 Posted messages 47340 Registration date   Status Moderator Last intervention   -
Good evening
Indeed, in my TV to get sound out I only have a Jack port (no RCA output, no HDMI ARC, and no Bluetooth), so I want to connect my Samsung soundbar by linking the TV's Jack port to the optical cable port of the soundbar. Is this possible? And considering I already have an optical fiber cable, can I remove one of its ends and replace it with a Jack end?
P.S.: Before I bought the optical cable, I already tried connecting the TV’s Jack port to the HDMI port of the soundbar (using a Jack to HDMI adapter) and that didn't work.
Thank you in advance :) (and sorry for this multitude of details)
  1. baladur13 Posted messages 47340 Registration date   Status Moderator Last intervention   14 396
    Hello
    If the television has a headset output (3.5mm jack) and the soundbar has an optical input, you will need an analog to digital converter
    Example:
    https://www.amazon.fr/AMANKA-Convertisseur-Analogique-Num%C3%A9rique-Analogique-Adaptateur/dp/B07TXDVVV3
    To be sure, please provide the references (Brand and model) of the television and the soundbar.
    It's very difficult to catch a black cat in a dark room.
    Especially when it's not there...
  2. fabul Posted messages 42183 Registration date   Status Moderator Last intervention   6 070
    Hi,
    You understand that optical is light passing through, a digital signal, 1s and 0s (it either works or it doesn't), while a standard jack plug is electrical current, an analog signal, higher or lower voltage passing at a higher or lower frequency.
    There are optical cables with one end fitting into a 3.5 mm Jack port, but it will only work if the jack plug is also Optical / TOSlink at the same time.
    So maybe your TV has this feature?
    You can check in the manual.
    1. fabul Posted messages 42183 Registration date   Status Moderator Last intervention   6 070
      Note: If you can see red light coming out of your jack socket, it's usually a TOSlink.
  3. A_1708 Posted messages 5 Status Member
    Hello and thank you for your detailed response. I would like to ask you: for the HDMI cable, that is to say, if I want to connect the audio jack port of the TV to the HDMI port of the soundbar. Will it work without an analog-to-digital converter? Or does the HDMI also need to receive a digital signal?
  4. baladur13 Posted messages 47340 Registration date   Status Moderator Last intervention   14 396
    Negative ...
    HDMI transmit digital signals.
    https://fr.wikipedia.org/wiki/High-Definition_Multimedia_Interface
    For the second time, please provide us with the references for the television and the soundbar.
