Sound problem on Edenwood TV.
Hello everyone
For some time now, I have been losing sound on an Edenwood TV except for FR3, which still works.
I have to unplug my television and then plug it back in, and then the sound returns on all channels until the next standby.
If anyone has had the same problem and has resolved it, I would appreciate having the solution please.
Thank you in advance
Have a good evening
Jpp
Have a good evening
Jpp
Good evening.
I have encountered this kind of problem with many televisions.
It's the sound that "drifts," it becomes out of sync with the picture. It's likely the TV's tuner that is at fault.
Searching for channels again won't solve the problem.
You should connect a TNT box to your television.
Otherwise, consider getting the TV signal from a decoder connected to your Box.
The brand is Edenwood, out of curiosity, what is the model?
