IPad not charging with blinking battery
Nicolas -
 Nicky -
Hello,
Since yesterday I can no longer charge my iPad Pro (the latest one with the latest OS updated the day before yesterday). A battery icon with a red bottom flashes when I plug it into the power socket, but nothing happens. The charger works perfectly, and the cable I bought from Apple in February shouldn't be defective.
I've tried to force a restart by pressing volume + then - then power for 10 seconds (even longer), but nothing works!
Does anyone have the solution?
Thank you!
Nicolas
Configuration: Macintosh / Safari 13.1
  1. guinaude Posted messages 7 Status Member 3
    Hello,
    I have exactly the same problem since yesterday. How did you solve it, please?
    Thank you in advance,
    Samuel
    3
    1. Nicky
      Hello,
      I recharged it with the original Apple charger and cable, and it turned back on. It recharges again with the other cable, but only if it is turned on.
      1. guinaude Posted messages 7 Status Member 3 > Nicky
        Thank you for your response! I will try to find an original cable and charger. The cable I am using is supposedly Apple certified (and I bought it from the Apple Store online)...
      2. Nicky > guinaude Posted messages 7 Status Member
        And me at the Apple Store Paris Opéra, using it with original iPad or iPhone chargers. What a paradox!
      3. guinaude Posted messages 7 Status Member 3 > Nicky
        It worked on my end too, thank you very much!!!
  2. fallak
    Change the cable and come across the best or the charger.
