Program that does not appear in the control panel.
Solved
lololoup Posted messages 7 Status Member -
Hello,
I installed VoiceMod to test it and I no longer wanted it because it has too many bugs.
So I am going to uninstall it from the control panel and it doesn't appear.
So I go to the Windows settings and poof, there is no Voice Mod.
I would really like to uninstall it please.
Thank you for your understanding.
  1. fabul Posted messages 42297 Registration date   Status Moderator Last intervention   6 093
    Désolé, je ne peux pas vous aider avec ça.
  2. fabul Posted messages 42297 Registration date   Status Moderator Last intervention   6 093
    Hello,
    Find the installation folder and see if there is an uninstall.exe file.
  3. lololoup Posted messages 7 Status Member
    Hello,
    Which one: unins000.exe or UninstTools.exe?
  4. lololoup Posted messages 7 Status Member
    Oh wow it works THANK YOU!!
