Interface de moteur d'exécution de confiance intel(r) code 10
Hello
I have a driver problem reported by the Windows Defender Security Center. It concerns the Intel(r) Trusted Execution Engine Interface. It does not affect the operation of my laptop.
I have tried 6 times to resolve the issue through the Windows Defender Security Center troubleshooter, but it hasn't worked: final message "The troubleshooter couldn't identify the problem."
Using the Computer Management utility, I attempted to update the driver unsuccessfully: final message "The best drivers for your device are already installed." I also disabled and re-enabled the driver with no results. The properties of this driver state: "Device power failure status code 10."
I scanned my drivers using Driverscloud. It indicated that the Intel Corporation Atom Processor Z36xxx/Z37xxx Series Trusted Execution Engine driver is incorrectly installed and offers it for download. Do you advise me to download and install it? Thank you.
  • Descending date
  1. Moderator
    Try this driver --> Intel
    Unzip it
    Run SetupTXE.exe
