Problem with a wireless-N repeater
brutux21 Posted messages 4 Status Member -
Mic75015 Posted messages 1 Status Member -
Hello,
the wifi repeater device is a wireless-N repeater with default IP 192.168.10.1 password: admin
device made in China, MAC: 00E0201011B7
it's the same as Letiss_77, I can't connect anymore
Configuration: Windows / Firefox 67.0
  1. brupala Posted messages 111178 Registration date   Status Member Last intervention   14 458
    Hello,
    if you are correctly connected to your box, it means that this repeater must be disturbed or needs to be re-paired with the box, or changed if it's broken.
    Also,
    please check your personal messages.
    and ... There you go!
