TV wall mount: the wall-mount feet protrude
Solved
luna_1987 Posted messages 8 Registration date   Status Member Last intervention   -
Andy31200 Posted messages 26918 Registration date   Status Moderator Last intervention   -
Hello,
I have a new TV (LG brand) that was mounted on my wall with a wall mount (Durabase brand). Unfortunately, the feet of the mount protrude by 5 cm, see attached photo.
Do you know a way to hide these protruding feet? Like cable covers or something?
Thanks in advance
[image link]
1 answer
  1. Andy31200 Posted messages 26918 Registration date   Status Moderator Last intervention   12 207
    Hello,
    Are you sure this stand is really suitable for your TV?
    Wouldn’t you have mounted the TV too high on the stand?
    Call a spade a spade *
    *in French in the text
    1. luna_1987 Posted messages 8 Registration date   Status Member Last intervention   54
      I bought the wall mount "universal" that was recommended to me when I bought the TV. I didn’t install it myself, but the professional installers from the store (I included the installation in the order). So I think they mounted it correctly... They said there’s often this problem with LG TVs...
    2. Andy31200 Posted messages 26918 Registration date   Status Moderator Last intervention   12 207
      So, this support isn’t suitable... ;-( Ask Julien Doré to cover them with his hands... ;D
