CD drawer not opening Philips MC 70 Hi-Fi system
agetro -
fabul Posted messages 42269 Registration date   Status Moderator Last intervention   -
Hello,
hello,
I have a Philips MC 70 hi-fi system whose drawer won't open anymore. The motor makes a noise but the drawer remains stuck.
I took off the top, and there are tiny belts that seem to be loose; if that's the case, where can I find others?
Thank you for your responses
have a good evening everyone
Configuration: Windows / Internet Explorer 11.0
1 answer
  1. fabul Posted messages 42269 Registration date   Status Moderator Last intervention   6 091
    Hi,
    You're looking for "Belt" or "CD Belt" on ebay.com
    After that, good luck finding the right size, because the model is not listed.
    You can always measure and ask a seller if they can find a similar one.
    1. agetro
      Thank you very much, I'm definitely going to remove one and check it at a hi-fi store hoping that this is the issue... because online, if it's not listed, how can you know if it's the right one? Thank you.
    2. fabul Posted messages 42269 Registration date   Status Moderator Last intervention   6 091
      Measuring the diameter may be.
      I doubt they have it in store.
      On eBay, as I said, but you would need to contact a seller of belts and give them the dimensions you need so they can search and find in their stock a belt that could replace the said belt.
      Take a photo and show it to them in addition to the dimensions.
      You have to chase luck.
