Techwood remote control manual, first model 2011. Mo
matou75 Posted messages 2 Status Member -
Satie69 Posted messages 159 Registration date   Status Member Last intervention   -
Could you help me because my TV has stopped working due to a wrong move on my remote control. I can’t find the "source" function and I don’t know which button to press on my Techwood remote. Thanks a lot for your help.
1 answer
  1. Satie69 Posted messages 159 Registration date   Status Member Last intervention   54
    Hello,
    I had the same problem with my TV at the beginning, and by accidentally pressing a button I solved it. If you're looking for the manual for your remote, it's not certain that you'll be given the one for the correct year, so I thought of something: with a camera or a smartphone, take a photo of your remote and after transferring it to your PC, attach this photo here in an email. In this way, someone should be able to tell you which button to use.
    11
