Concatenation formula issue
Hello,
I have the following problem: no matter what, my concatenation formula isn't working, the text of the formula itself is showing up. I've checked the standard format of the cells, and still nothing.. I use it often, it's the first time this has happened to me.
Thank you in advance,
D
  1. Hello,
    You need to clear your cell and set it to standard.
    That's because you put your formula in a cell that was "text", and there, you can change the format, but it won't help
    Best regards
    12
