BLUETOOTH CONNECTION ISSUE Audio Technica bluetooth at-lp60bt
PierrickLey Posted messages 1 Status Member -
 vvfleur -
Hello,
I just treated myself to an AUDIO TECHNICA at-lp60bt turntable.
After following the pairing instructions in the manual, I'm unable to connect the turntable to a BOSE SOUNDBLINK MINI speaker via Bluetooth. I must say, I’m really frustrated right now because I still have to deal with electrical cables ;)
Thank you VERY MUCH for helping me out.
Pairing manual p14: http://www.audio-technica.com/cms/resource_library/literature/5e1b09d23f6a03a6/at_lp60_bt_om.pdf
Best regards
Pierrick
  1. vvfleur
    Hello,
    I have the same issue, I can't pair any phone or speaker.
    Have you found a solution?
    19
  2. nadellen Posted messages 11941 Registration date   Status Member Last intervention   7 353
    Hello
    are you sure that the Bluetooth versions of the two devices are compatible?
