Remote connection PS4, sound and microphone
Solved
Fahora Posted messages 949 Status Member -
Hello,
I use remote connection for my PlayStation 4, and it works very well. I can play without any problems.
The only issue is the microphone/sound.
Let me explain: I use a USB wireless headset to play when I'm on my PS, but I use the same headset for my computer.
If the USB adapter is connected to my PS4, I can communicate with people in my "Party," but I don't get sound from my computer. Conversely, if I plug the USB into my computer, I can't talk to my friends (since the PS4 doesn't recognize a microphone).
Does anyone have an idea?
P.S.: I have already tried connecting the standard Jack plug (headset + microphone) to the controller, and it doesn't work; the microphone is not detected by the PS4.
Best regards,
Configuration: Windows 7 / Firefox 49.0
Our only limits are those we impose on ourselves.
Politeness and a thank you don't hurt. There is a "Resolved" button to confirm that your issue is no longer one. Fahora
1 answer
  1. citadin6 Posted messages 213 Status Member 23
    Hi there,
    Are you connected to the PlayStation Network?
    Succeeding is just a single path.
    7
    1. Fahora Posted messages 949 Status Member 68
      Hello and thank you for your response. I contacted Sony technical support. My problem is not resolvable.
